T-SB for 2022 needle bearing?
Discussion in '5th Gen 4Runners (2010-2024)' started by Wildfish, Dec 12, 2024.
  1. Dec 12, 2024 at 9:07 AM
    Wildfish
    Wildfish [OP] New Member
    2022 4Runner TRD Off-Road
    Hi all,
    I have a 2022 trd orp and recently it's been rattling a bit at low speeds in the front driver wheel. It has aftermarket suspension lift, so worried about getting warranty work done. My off road shop says there's play in the front axle indicative of a needle bearing issue (although I still notice it in 4wd).
    I called the local toyota dealer and they say they've never heard of a needle bearing issue. I need the TSB to prove it before they charge me to dx a car still under warrenty.
    Anyone have it handy? Not the one for 16-19, but the 22 year.
    Thanks!
  2. Dec 12, 2024 at 9:42 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Whether you find the TSB or not, chances are it's going to be on your dime because of the aftermarket suspension lift. And, any Toyota dealer that hasn't heard of the needle bearing issue is one to be avoided.
    Rocko9999 likes this.
  3. Dec 12, 2024 at 9:55 AM
    Not even worth it if lifted and its making noise its probably going to come back.
    I'd just do the ECGS and be done with it. Anyone half decent with hand tools can do it at home. And you don't have to go to the dealer and wait.
  4. Dec 12, 2024 at 9:55 AM
    1. The T-SB for this issue states there was a production change that fixed the issue, so your '22 should not have the problem.
    2. The T-SB for the 2016 - 2019 can be found here:
    3. I am always leery when a dealer tells me they haven't heard about a T-SB for a vehicle they sell.
    Also, like @catbrown357 mentioned, once the dealership spots your after market lift, they are going to tell you to go pound sand. Even if there is a recall.
    Toy4X4 likes this.
  5. Dec 12, 2024 at 10:05 AM
    LunarTR4
    LunarTR4 New Member
    22’ TR4 ORP LR
    2022 ORP model year here w/ a lift. ECGS bushing and be done with it.
    Toy4X4 likes this.
  6. Dec 12, 2024 at 10:11 AM
    salvojimmy
    salvojimmy New Member
    Glen Allen VA
    2022 SR5P
    No Mods Yet
    T-SB-0075-23 Covers the 2022. Note there are different fixes depending on build date of front diff
  7. Dec 12, 2024 at 10:13 AM
    You found it! I'll upload the PDF here.
  8. Dec 12, 2024 at 11:17 AM
    Wildfish
    Awesome find, thanks!
    My symptoms don't match. It's a jiggling/loose noise, mostly happens at low speed, maybe more on a right turn (all drives side) and putting in 4wd doesn't fix it. However, the axle has play, which the 4x4 shop says is usually the first symptom. It's not the CV, there's no clicking.
    Also, regarding warranty: I'll be pretty pissed if they try to deny a warrantied dif bushing bc of a small suspension lift. The two have nothing to do with each other. You can lift a jeep like 3 inches and put tires up to 35" before they even bat an eye at warranty voiding. I'll be pretty frustrated if Toyota is worse than Stellantis!
  9. Dec 12, 2024 at 12:26 PM
    joshdub
    joshdub New Member
    2020 TRD ORP
    I can tell you from first hand experience the Toyota warranty process is a joke. It is not worth the paper it's printed on. I was told directly from Toyota that their warranty does not cover defects in workmanship or materials.
    Toy4X4 likes this.
  10. Dec 12, 2024 at 12:31 PM
    I can tell you this is bull shit.
    I've gotten tons of stuff warrantied from my dealer over multiple vehicles. I've even had my dealer warranty a battery which is clearly a wear and tear item but it died in less than a year.
    If "Toyota" directly told you this show it.
    Toy4X4 likes this.
  11. Dec 12, 2024 at 12:48 PM
    Tooly
    Tooly New Member
    Okanagan, BC Canada
    2024 4Runner OR Solar Octane
    Reading this pdf, it appears that 4R's built after April 11 2022 do not have the front diff replaced as part of the fix but rather a "dynamic damper" part #41196-60020 installed.
    Does anyone have a picture of what that looks like? I googled the part number but can't seem to find an actual picture of it. Is this a part that is already on the truck?
    *Edit* Found this on a Lexus parts site but not a real picture. Is it some type of counter weight?
    https://lexus.oempartsonline.com/oem-parts/lexus-dynamic-damper-4119660060
  12. Dec 13, 2024 at 1:18 AM
    joshdub
    joshdub New Member
    2020 TRD ORP
    Neat story. I thought your toyotas were so great and never had any issues.
  13. Dec 13, 2024 at 5:20 AM
    Warranty action is only as good as the service manager allows it to be. If you go to a different dealership you might get a different answer. I talked to 3 different dealerships and basically got 3 different responses, one said there was a problem, instead of the 50/50 chance of having a short/long term fix, opted for the ECGS bushing.. long term fix.
  14. Dec 13, 2024 at 6:54 AM
    salvojimmy
    Glen Allen VA
    2022 SR5P
    No Mods Yet
    And as I read it, if you get the diff replaced you also get the damper.
  15. Dec 13, 2024 at 6:56 AM
    Mr.DRZ
    Mr.DRZ Newish member
    2024 ORP
    *our Toyotas ;)
  16. Dec 13, 2024 at 9:06 AM
    Its ok you tried to lie.
  17. Dec 13, 2024 at 12:34 PM
    Tooly
    Tooly New Member
    Okanagan, BC Canada
    But what changed after April 11 2022 that doesn't require the diff to be changed, just the damper added? That's what I'm wondering.
    TRoosevelt likes this.
  18. Dec 14, 2024 at 5:56 AM
    salvojimmy
    Glen Allen VA
    2022 SR5P
    No Mods Yet
    Me too
