Suspension savvy people & Bilstein experts: can u raise spring seat above 0" w/ OME 3" lift springs
Discussion in '5th Gen 4Runners (2010-2024)' started by djwantke, Mar 26, 2023.
  1. Mar 26, 2023 at 1:56 PM
    djwantke [OP] New Member
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    To all suspension savvy people, and Bilstein experts: can you or can't you raise the spring seat from 0" stock groove if you have non-OEM 3" lift springs?? (I run 5100's w/ OME 2884 3" lift springs - stock weight). Am I near 3" w/ 33's centre wheel to fender approx. 22"?
  2. Mar 26, 2023 at 4:12 PM
    DIRTRCR13
    DIRTRCR13 New Member
    Jerm
    The 405
    '16 Sierra Romeo Cinco
    Knew a guy that did a 2" lift spring and set the clip on the 3rd (1.7") setting and the ride was stiff as crap. So I guess my point is, if you dont mind possibly having a rough ride and you are not worrying about over compressing the springs, anything is possible.
    Does your truck have any added weight up front? 22" measurement does seem a little low for a 3" lift. What was the measurement before the shock/ spring replacement?
  3. Mar 26, 2023 at 11:06 PM
    Interesting, I see. So not much added weight just 3 piece skid plate kit + transfer case skid. And I'm not sure of my measurement at stock I didn't measure. Really appreciate the help
  4. Mar 27, 2023 at 5:43 AM
    BobbyB
    Bob
    Marietta, GA
    2021 White TRD Off Road
    At stock height, my 2021 TRD OR measured 19 7/8 from hub to fender on both left and right front. Others have reported similar measurements generally around 20" from hub to fender but it does vary from vehicle to vehicle.
    I upgraded to Bilstein 5100's shortly after purchase and set the shocks at the .85" setting which is one ring above OEM height and measured a 1 1/8" gain on OEM springs and this leveled my rig. Later, after I added weight to the vehicle (bumper, winch, skids, sliders), I upgraded the springs to carry the additional weight. I went with Dobinsons springs that were advertised to give a 2" lift over OEM with the weight I had added with the Bilstein 5100's set at OEM ride height. I got pretty close to the advertised lift.
    This is my opinion so take it for what its worth but I would not use adjustable shocks to add additional lift to springs that already provide the lift. Let your springs do the lifting and your shocks do the dampening. If you add weight to your rig as I did, consider springs that can carry the weight at the ride height you want...
    Cheers,
    Bob
    anthonydotb and djwantke[OP] like this.
  5. Mar 30, 2023 at 1:32 PM
    @BobbyB
    So I'm at exactly 38" with 33's (33" diameter) from ground to fender.
    With stock 31" (31.6" diameter) ride height of 34-1/2, it means I'm sitting at only 2.1" lift (38 minus 34-1/2+1.4).
    OME 2884 approx 3" lift springs are 590lbs and I have barely any added weight. Rear end is at 39-1/2". So why am I at 2"
  6. Mar 30, 2023 at 2:17 PM
    BobbyB
    Bob
    Marietta, GA
    Op,
    Generally, we measure lift height from center of hub to fender to remove any ground to fender differences that a tire size change would cause.
    As I look at your ground to fender calculation, it seems that you have deducted the full 1.4” difference between the 33’s and 31.6 tires. Your calculation is (38 minus 34 1/2 + 1.4) giving you a delta of 2.1”.
    Since only half of the difference in tire diameter lifts the vehicle, I think you should have only used .7” (half of the difference) in your calculation. I believe your calc should be (38 minus 34.5 + .7) or 2.8” instead of the 2.1.
    I think you have close to the 3” advertised lift for the springs…
    Cheers,
    Bob
    djwantke[OP] and Thatbassguy like this.
  7. Mar 30, 2023 at 3:41 PM
    I took math 11 twice, lol, thank you for this!
    I have posted the wheel hub to fender measurement as well but din think about its 0.7" if you're going ground to fender
  8. Mar 30, 2023 at 3:43 PM
    @BobbyB do you know anything about suspension settling? I had another dude said his suspension settled 1.5" after a week which seems crazy to me
  9. Mar 30, 2023 at 5:49 PM
    BobbyB
    Bob
    Marietta, GA
    When I lifted my rig with new springs, shocks and upper control arms, my goal was a 2” lift in front and 1” in the rear. My measurements shortly after the lift showed right at 2” both front and rear and I’ve experienced minimal settling, maybe 1/4”.
    Clearly, some see more settling than others but I’ve not heard of anyone seeing more than about 1/2”. If it settles more than that, I would question the installation.
    The advertised lift heights of spring/shock combos are approximate and are subject to weight of installed accessories, gear in the vehicle and even how much gas there is in the tank.
    Cheers,
    Bob
    djwantke[OP] likes this.
  10. Mar 30, 2023 at 5:55 PM
    @BobbyB very much appreciated sir
  11. Mar 30, 2023 at 7:25 PM
    Superdave1.0
    Superdave1.0 New Member
    LX470
    For a couple of reasons, no. You will be riding topped out in the shock travel. Leading to constant banging/clunking of the shock after hitting a dip or going off road.
    The spring will be under a ton of pressure. When you compress it more by hitting a dip, it will naturally want to spring back/out at a fast rate. Leading to even more topping out.
    I know because I did this for a customer. I advised against it, but they insisted. They test drove around the block and came right back. Begging me to lower the clip setting. They had zero up travel, tons of lift though.
  12. Mar 30, 2023 at 7:37 PM
    Really appreciate that context and info, I believe it. I see all over the web ppl saying they ride in the upper groove settings, usually their lift springs are no more than 2" tho. Question, any idea if Bilstein 5100's can accommodate longer than 3" lift springs ?
  13. Mar 30, 2023 at 8:02 PM
    Superdave1.0
    LX470
    No for the same reason. You will have no up travel. If you are 2wd can run maxtrac 4" lift spindles. Otherwise for over 3" lift your options are basically limited to drop bracket lifts.
  14. Mar 30, 2023 at 8:36 PM
    I see, I hear ya. Appreciate that. So I've chopped and trimmed what's needed to fit 35's next, prolly adding a 1" body lift with that. Perhaps dreams of higher than 3" suspension lift entails new longer travel suspension !
    Superdave1.0 likes this.
