Stuttering past ¼ throttle
Discussion in '1st Gen 4Runners (1984-1989)' started by Weld-everything, Jul 26, 2023.
  1. Jul 26, 2023 at 9:21 AM
    Weld-everything
    Weld-everything [OP] New Member
    Eric
    86 SR5 4runner
    86, 22re, manual. Having a problem pinpointing this issue.
    It drives fine until I push more than ¼ throttle. At that point it feels like it's stuttering like the timing is out. Sometimes it will push thru the issue and power comes back, sometimes it doesn't.
    Timing is correct, new cap, rotor, plugs, and wires, fuel filter. Fuel pressure does not deviate at any point and stays steady at 35psi.
    No difference if the fuel tank is low or full.
    No vacuum leaks either. Stumped at this point.
  2. Jul 26, 2023 at 12:30 PM
    se7enine
    se7enine New Member
    1984 4Runner
    3RZ
    Throttle Position Sensor tested?
  3. Jul 26, 2023 at 2:39 PM
    Weld-everything
    Eric
    86 SR5 4runner
    Nope. Overlooked that. Thanks!
  4. Jul 26, 2023 at 4:16 PM
    Check that the intake tubing doesn't have any leaks or cracks also.
  5. Jul 26, 2023 at 6:13 PM
    LadeDruck
    LadeDruck New Member
    2022 Pearl Effect White Ltd.
    Sounds like a maf sensor all day.
    2018 Limited likes this.
  6. Jul 27, 2023 at 2:46 AM
    2018 Limited
    2018 Limited New Member
    BDR
    2018 Limited
    You beat me to it. I was thinking the same as you. I had a similar issue with a different vehicle and a can of maf sensor cleaner spray fixed it.
    LadeDruck[QUOTED] likes this.
  7. Jul 27, 2023 at 2:54 AM
    LadeDruck
    does BDR for you name stand for big pickle Rick?
    if so, hats my friend.
  8. Jul 27, 2023 at 4:27 AM
    2018 Limited
    BDR
    2018 Limited
    https://youtu.be/ravi4YtUTxo
    “You have a gift my friend “
  9. Jul 27, 2023 at 9:18 AM
    Weld-everything
    Eric
    86 SR5 4runner
    Thanks guys. I believe I have a spare MAF that I will try.
    LadeDruck likes this.
  10. Jul 27, 2023 at 9:28 AM
    LadeDruck
    let us know
  11. Jul 27, 2023 at 11:47 AM
    LadeDruck
  12. Jul 27, 2023 at 12:22 PM
    MartianArmada
    MartianArmada New Member
    Alex
    Harford County, MD
    2021 Venture
    Wildpeaks
    I'd also look into your new plugs - shuddering under load can be caused by cracked plug ceramic
    CygnusX-4 and RumHamRunner73 like this.
  13. Jul 27, 2023 at 12:25 PM
    LadeDruck
    If that were the case it wouldn’t be so load dependent.
    but still possible
  14. Jul 28, 2023 at 7:27 AM
    MartianArmada
    Alex
    Harford County, MD
    2021 Venture
    Wildpeaks
    The symptoms are nearly identical to when I made the same mistake on a previous vehicle. You could somewhat "push through" the stumbling but it would still fall on its face now and again during acceleration. Luckily this was a built engine turbo Mazda and I always had like 2-3 sets of extra plugs on hand.
  15. Jul 28, 2023 at 8:40 AM
    LadeDruck
    We shall see….
    if you have to keep 3 sets of plugs on hand, you did something wrong….worked on many of the speed 3 motors and they were quite reliable.
    only issue was when you had to actually break it open it was much easier to pull than work on in place.
  16. Jul 28, 2023 at 9:00 AM
    Weld-everything
    Eric
    86 SR5 4runner
    I found that the spring clip was missing from the tps plug, so I ordered a new plug harness. Not stating that as the culprit, but who knows. I'm going to tackle the truck this weekend and will let you all know.
  17. Jul 28, 2023 at 9:03 AM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    I would have assumed fuel filter. But that's old school i guess.
  18. Jul 28, 2023 at 10:21 AM
    Daddykool
    Also check the airflow meter (as it was called back in the day) if so equipped. My 1988 had a similar problem and the butterfly was binding. WD-40 on the pivot points fixed it.
    Oops, thought I had posted this yesterday.
    Thatbassguy and LadeDruck like this.
  19. Jul 28, 2023 at 10:39 AM
    MartianArmada
    Alex
    Harford County, MD
    2021 Venture
    Wildpeaks
    I made a lot of changes and generally would swap plugs every 1,000mi or so and/or any time I modified the tune/dyno'd the vehicle or went to the track.
    I built the motor myself after popping it at 160k running a GT3076r on meth. After the rebuild made about 600 to the wheels on a Precision 6062 around ~32psi lol
    Anywho back to the original post. Just wanted to share my experience and always have fun reminiscing on my days in the Mazda world.
  20. Jul 28, 2023 at 10:47 AM
    Weld-everything
    Eric
    86 SR5 4runner
    I already changed the fuel filter and hooked up a fuel pressure test tool, then took it for a drive and the pressure stayed solid at 35 psi even when the stuttering was happening. I've ruled out the fuel system on this situation now.
  21. Jul 28, 2023 at 10:54 AM
    Velociraptor4x4
    Velociraptor4x4 New Member
    Joe
    2017 SR5
    I spent a lot of time on my 86 with erratic stutter and stalling. Ended up being a valve adjustment issue. The exhaust side valves were too tight. Adjusted all of them to factory spec and it’s ran great ever since.
  22. Jul 28, 2023 at 10:58 AM
    LadeDruck
    well you didn’t get to have to fancy with it….
    here I thought my hx35 1.8t @ 23 pounds on pump was gonna show you…..
    edit: who did the tubular manifold?
  23. Jul 28, 2023 at 11:09 AM
    MartianArmada
    Alex
    Harford County, MD
    2021 Venture
    Wildpeaks
    It was made by FJ performance (some random shop in PA). I believe they bought the design off of someone though. It flowed very nicely and sounded awesome.
  24. Jul 28, 2023 at 11:16 AM
    Weld-everything
    Eric
    86 SR5 4runner
    On my list now. Thanks!
  25. Jul 30, 2023 at 11:06 AM
    Weld-everything
    Eric
    86 SR5 4runner
    Update..... Cleaned the MAF, cleaned throttle body, checked the plugs, and replaced the TPS pigtail.
    Not sure where the blame belongs, but I'm pretty sure the TPS plug being loose and the connectors in it looking to far open was most likely the issue.
    Glad to report the motor does not stutter any more.
    Currently doing a valve adjustment check to just be sure all is well.
    Thank you all for your help!
  26. Aug 5, 2023 at 9:19 AM
    Weld-everything
    Eric
    86 SR5 4runner
    And it's back. Found out the ecu is from a 85 2wd auto. May be an issue.
  27. Aug 5, 2023 at 11:42 AM
    jmkulbeth
    jmkulbeth Have you tried turning it off and on again?
    Jeffrey (KE5HDB)
    Siloam Springs, AR
    2020 4Runner Offroad Premium, Nautical Blue
    Bone stock!
    Years ago I had an old Dodge truck ('88 D100) with a similar problem. At idle and light throttle it was fine. Anything past that and it would stumble and nearly die. Turned out to be the EGR valve. Diagnosis was easy: disconnect it and all was well. Once replaced everything was fine.
    Just a thought. Not sure that's applicable here.
