Strange sounds from the motor
Discussion in '2nd Gen 4Runners (1990-1995)' started by grousehunter 61, Feb 24, 2016.
  1. Feb 24, 2016 at 4:08 PM
    grousehunter 61
    grousehunter 61 [OP] New Member
    Rodger
    1995 4 runner
    I got the toy running and found a strange sound in the motor. I pulled the valve covers and tested each lifter while running, no change. It sounds great at idle but when you pick up the rpm's it starts making noise. If it was a spun bearing wouldn't it do it at all speeds ? if it was a piston, again wouldn't it be at all speeds. I am stumped so I took a video of it and let you listen.
    Hope someone can pick it out, sure hate to pull the motor to find out I have an exhaust leak
  2. Feb 24, 2016 at 4:16 PM
    grousehunter 61
    Rodger
    1995 4 runner
    I can't get the video to come up, hope someone on here can.
  3. Feb 24, 2016 at 5:06 PM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    2007 4runner SR5 4WD
    Doesn't sound good that's for sure.....
    Never heard a knocking like that:notsure:. I would guess pushrod or bearing. Have you checked the compression on each cylinder?
    Good luck and let us know what you find......
  4. Feb 25, 2016 at 9:24 AM
    grousehunter 61
    Rodger
    1995 4 runner
    Ron, do you think it may be an exhaust leak? No, I did not check all the cyl. just the ones on the easy side. They were around 150 psi stock is 170 +-. No push rods in there, double over head cam's. If its a bearing wouldn't it sound off at the start and not just when running a high rpm's. Same with a broken ring, I don't know just grasping at straws. I have taken a pipe and listened all over the motor, it doesn't sound any different anywhere, but it sounds louder at the rear rather then the front. If the crossover pipe is loose or broken would it make that sound.?????? the video is slow to open, give it a chance.
  5. Feb 25, 2016 at 12:14 PM
    1STorder
    1STorder New Member
    Matt
    Milwaukee, WI
    2016 4runner TRD Pro
    Just leveled out
    It sounds like a rod knock.
  6. Feb 25, 2016 at 1:21 PM
    grousehunter 61
    Rodger
    1995 4 runner
    So you think it could be a bearing gone bad? I have been a chevy man all my life, when one of those goes out it knocks from the get-go, but I am open to suggestions. Keep them coming........
  7. Feb 25, 2016 at 1:29 PM
    1STorder
    1STorder New Member
    Matt
    Milwaukee, WI
    Just leveled out
    Most of my experience is in the Subaru world, but it is not uncommon for a bad rod bearing to only make a noise under a load or off idle. Judging from what I can hear through my speakers that is what I hear.
  8. Feb 25, 2016 at 3:17 PM
    wnelax04sr5
    wnelax04sr5 New Member
    Ethan
    CT
    2004 SR5 4X4 Galactic Gray
    i second this motion. i just rebuilt a motor that had rod knock and it sounded exactly the same and had the exact symptoms. it generally is normal at idle but any load on the motor and it sounds like your video.
  9. Feb 25, 2016 at 4:26 PM
    grousehunter 61
    Rodger
    1995 4 runner
    Thank you guys for answering, I was afraid that was what it was. I guess the motor is coming out, not something I wanted to do.......
  10. Feb 25, 2016 at 5:34 PM
    ThatFenwickGuyFromTW
    ThatFenwickGuyFromTW Hillbilly
    Fenwick
    Chesapeake, VA
    2 2nd Gen T4R's, 96 Tacoma 5 Lug
    Work in progress!
    I must agree with what the others have stated- sounds like a rod knock to me. :(
  11. Mar 1, 2016 at 8:18 PM
    Jason
    Jason New Member
    Jason
    1992 black 4runner
    still stock
  12. Mar 12, 2016 at 9:28 AM
    grousehunter 61
    Rodger
    1995 4 runner
    I am fairly sure its a rod, I have good oil pressure and also changed the oil with no change. The only thing that confused me was the fact that it would start and idle with no noise, as long as I didn't rev it up it was quiet, as soon as I increased the RPM's the knock came back. Others on here said that they do that. the only way to check is to pull the motor and get inside.
  13. Mar 12, 2016 at 11:10 PM
    Kyle11863
    Kyle11863 King of the BS
    Big Bear California
    1990 Toyota 4Runner SR5 V6 5 Speed Manual
    Doug Thorley long tube headers and lots of mud
    Ouch. That hurt me to listen to. Sorry man.
    And not trying to be a no it all or anything but I'm pretty sure the 3vze is a SOHC not DOHC. From what I've read its the only SOHC V6 Toyota built. Just trying to pass on the knowledge. Hope it get fixed quickly and cheaply
  14. Mar 14, 2016 at 9:19 AM
    grousehunter 61
    Rodger
    1995 4 runner
    You are right, don't know just what I was thinking. One cam to the side, soooo thats double, wrong.
  15. Mar 14, 2016 at 9:21 AM
    grousehunter 61
    Rodger
    1995 4 runner
    Its going to be a while before I can work on it. I go in on the 12 of April for a knee replacement. Mid to late summer before I can do it.
  16. Apr 3, 2016 at 7:41 AM
    Fenwick
    Chesapeake, VA
    Work in progress!
    Ouch, man. Good luck with both the truck and the knee replacement.
  17. Apr 5, 2016 at 5:42 PM
    greenie3754
    greenie3754 New Member
    1995 4Runner Diesel
    VW ALH Engine (in process of installing)
    If it helps and if it's worth the trouble, I have a 3.0 in MT which is partially disassembled (transplanting a VW ALH TDI into it). Crank should be good. Just FYI
  18. Apr 6, 2016 at 11:34 AM
    grousehunter 61
    Rodger
    1995 4 runner
    Just how disassembled is it...??? It just may be worth it. the problem is, if you read my other posts, I am going in for a knee replacement in 5 days and will be layed up for some time. So it will be a few months before I can pull the bottom to see the crank. What was wrong with your motor??
  19. Apr 6, 2016 at 5:35 PM
    powersrp
    powersrp New Member
    Mackinaw City, MI
    2015 4runner black limited
    running boards, Husky floor liners
    good luck with the tkr, i had mine done jan 19, and unfortunatly i am of the 7% that had ended up with a stiff knee, my range of motion sucks, and im not done yett. make sure you have phy therapy set up for the very next day, and take one exlax everyday, dont ask me how i know this, lol.
  20. Apr 6, 2016 at 5:50 PM
    greenie3754
    1995 4Runner Diesel
    The bottom end (short block) is fully assembled, but the heads are off. They were taken off because the previous owner and his mechanic suspected head gaskets, but it turned out that one of the cylinders was rough. So he sold the vehicle to me, heads off, block in vehicle.
    I am in no rush; the engine is sitting around. There is no way to know how good or bad the crank and block are with out looking. According to the person I bought the 4Runner from, all indications were good as far as the crank is concerned. If you find you are interested, i will confirm this with him. However, until the block is further torn down and inspected, it will not be possible to be 100% sure.
    All in all,I am reasonably confident that the crank is fine and also reasonably confident that the block is fine, but would need to be bored to .010" oversize.
  21. Apr 7, 2016 at 11:06 AM
    grousehunter 61
    Rodger
    1995 4 runner
    Robert, this is the second knee that I am doing so I know all about the exlax, and why......lol but it wasn't at the time.
    green, I started the tear down yesterday, hope to have it out before I go into the hosp.
  22. Apr 7, 2016 at 5:48 PM
    Bob
    Bob Member Staff Member
    Bob
  23. Apr 8, 2016 at 4:51 PM
    grousehunter 61
    Rodger
    1995 4 runner
    I have the motor stripped down, the heads are still on and I will need to crawl under and unhook the trans, after that it will come out. Sure wish the toyota people would use the same disconnect on their electrical fittings, some are pull, some are squeeze, some are lift the lever, I got mad enough with one i just cut the wire, fix it later...........
  24. Apr 27, 2016 at 8:00 AM
    greenie3754
    1995 4Runner Diesel
    Sorry to have disappeared. Have you had your knee surgery? Anyway, engine/block in back of my truck. We should talk if you have any interest. Can I send you a private message with contact info? Thank you
