Stock SR5 and TRD PRO wheel 17x7"
Discussion in 'Wheels & Tires' started by szuyung3000, Aug 4, 2018.
  1. Aug 4, 2018 at 11:07 AM
    szuyung3000
    szuyung3000 [OP] New Member
    SYH
    2016 4runner SR5 4x4
    Hi, I want to get this question/myth out there and is pretty common:
    I know TONS of 4runner owners run 285/70R17 tires on TRD PRO wheels 17x7" and SR5 alloy 17x7" wheels. HOWEVER, 285/70R17 tires calls for rim width range of 7.5-9" so technically minimum of 7.5" of rim width is required. I know trail edition and TRD Offroad wheel is 17x7.5" so it is safe. BUT is it safe to run 285/70R17 on SR5 or TRD PRO wheels????
  2. Aug 4, 2018 at 12:32 PM
    These are the wheels i have TRD Pro and they are 7.5, i am running 285/70/17 Falken Wildpeak M/T with 44 psi front, and 38 psi rear. I just went out and took a measurement to be sure they are 7.5
    Strandskov and justinfro like this.
  3. Aug 4, 2018 at 12:45 PM
    I guess i am wrong once again, i looked the wheels up and they are 7 w. :homer::homer:
    Strandskov likes this.
  4. Aug 4, 2018 at 1:09 PM
    szuyung3000
    SYH
    so how were you able to measured the rim width w/o removing the tires??? Anyway they are listed as 17x7" not 17x7.5"
    Also will I need to do body mount cut on my 5th gen SR5 if I run 285/70R17 tires?? Did you had to? I have a 3" front strut spacer lift
  5. Aug 4, 2018 at 1:32 PM
    yeah i measured from out to out, and got about 8.5, then i took off a 1/2" for each bead. But anyway, yes i did the bmc. I do not have a spacer, but am at 2.5 in the front.
  6. Aug 4, 2018 at 1:59 PM
    szuyung3000
    SYH
    so you had to do a BMC to avoid rubbing from the 32.9 Wildpeak MT tires even though you already have a lift? Oh wow I guess I'll go w/ 275/70R17 to prevent it.
  7. Aug 4, 2018 at 5:56 PM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX4(Runner)60
    Yes the wheels are safe with 285s.
    No you don't need any mods to run 285s with a 2"+ lift except possibly the fender liner mod and removal of front flaps.
  8. Aug 4, 2018 at 5:58 PM
    szuyung3000
    SYH
    how do you know that for sure? I heard some people had to do BMC to prevent rubbing. Even w/ lift. For example:
  9. Aug 5, 2018 at 11:48 AM
    MeefZah
    Lexington, Ohio
    2020 GX4(Runner)60
    BECAUSE I HAVE THAT FUCKING SETUP and have done that install on THREE FIFTH GEN 4Rs. Look at my signature link if you want fucking references.
    ForRun and Strandskov like this.
  10. Aug 5, 2018 at 2:23 PM
    I had a shop do my install, Kings, built right UCAs. They trimmed the front, removed the mud flaps, and showed me they needed to do the bmc, i agreed. No need for anyone to be all pissy, my undertanding is not all the rigs are exactly the same. I trust this shop, and have had plenty of work done by them, they do this kind of work every day. I also have heard others that needed to get the bmc with my same conditions, and mods. Just sayin.
    WallyT4R, 2016Pro, Seekingzen and 3 others like this.
  11. Aug 5, 2018 at 5:45 PM
    szuyung3000
    SYH
    I was told the same thing by the shop that lifted my 4runner. They said I may or may not need a BMC if I run 285/70R17 tires. SlvrSlug did you try and see if they will rub first before you agree w/ the BMC? As I would imagine the shop was trying to earn more of your money by saying you need a BMC.
    MeefZah SlvrSlug is correct, not all setup are 100% the same. You didn't had to doesn't mean other won't need to...
    7385 and Strandskov like this.
  12. Aug 5, 2018 at 6:24 PM
    Yes, they showed me the wheel travel, and it would rub slightly. That is why i went with the bmc, they only charged like $100.00 for doing it, so they are not getting rich off that.
  13. Aug 5, 2018 at 8:27 PM
    szuyung3000
    SYH
    $100 is still money. I mean if I were you would've trying to see if they would rub first. And if did, THEN go back to the shop to do the BMC
  14. Aug 5, 2018 at 8:33 PM
    That is what i did.
  15. Aug 6, 2018 at 4:01 AM
    Oobaa47
    Oobaa47 New Member
    2018 sr5
    I have 285/70/17's and get slight rubbing at full lock reverse......haven't took it to my shop for the follow up visit...... falken wildpeak with a toytech boss lift......like what was said, every truck is different and will result in different scenarios based on the many factors involved.....
  16. Aug 6, 2018 at 7:56 AM
    MeefZah
    Lexington, Ohio
    2020 GX4(Runner)60
    I don't know that I would trust the experience of a guy who can't even measure - or Google - wheel specs.
    Of the 9 million 4R owners with 2.5/1.5 lifts and 285s you two may be the only ones who have needed a BMC.
  17. Aug 6, 2018 at 9:01 AM
    You know i searched the other 4-runner site, and there are several other people that have had to do the bmc. As far as the wheel info. I retracted that and owned it, which is more than some folks do. I do not not a lot about these runners, but i still try to help, and contribute if i can without being a dick.
  18. Feb 20, 2019 at 12:16 PM
    KGB_MoFo
    KGB_MoFo New Member
    2018 Runner
    From a 1/2” wheel width concern .. migrating into BMC s**t talking...
    I’d like to know from the Pro wheel and 285 running guys, how they look and handle? And any airing down issues at speed on Long trails (ie extra friction heat perhaps from the narrower rim versus 8 or 8.5?)
    I also like that look (it’s sexy) and am steering that way...
    Rims fairly light I understand?
  19. Feb 20, 2019 at 3:53 PM
    P226Navy
    P226Navy 2016 T4R
    Vee
    South San Francisco
    2016 Toyota 4Runner
    I think based on what I read. If you’re using 275/70R17 and also according to the guy that owns TOR. He installed this tire on a stock 4R without rubbing issue. If you decide to go on this route. I think or maybe there’s not that big difference between 285 and 275. I maybe wrong and let the experts give you that suggestions.
  20. Jul 22, 2019 at 4:55 PM
    costamesarunner
    costamesarunner New Member
    2019 Gray 4Runner TRD Off Road
    Leveling Kit TRD Wheels 285/70/17 Falken AT3’s
    I just put 285/70/17 Falken AT3's on my 2019 TRD Off Road and there is zero rubbing no matter how you are turning or back up and no cutting had to be done. The guys at the shop said it's 50/50, half of the 4runners that come in need and half dont. A little worried about how it will handle off-road given that I just did a spacer leveling kit for now, so will probably do proper suspension lift soon. In the meantime it drives great minus a slight loss in power and of course worse gas mileage.
  21. Jul 22, 2019 at 7:34 PM
    ForRun
    ForRun 4Runner
    2020 orp
    Turned out great!
  22. Jul 23, 2019 at 7:21 AM
    szuyung3000
    SYH
    Cool. I had to do a little fender liner mod and remove my mud flap to stop the rubbing. But do Body Mount Chop was needed.
    So how many inch front and rear spacer lift do you have on your TRD OFFROAD?
  23. Jul 23, 2019 at 7:27 AM
    costamesarunner
    It’s the 2.5” rugged off road spacer. The actual spacer is 1.25” and gives effective lift of 2.5”. And no rear lift yet but I’ll be adding that to correct the negative rake.
  24. Aug 22, 2019 at 6:57 PM
    Barcelona Trail
    Barcelona Trail New Member
    Colorado in Winter - SoCal in Summer
    '16 TEP w/ KDSS
    Bilstein 6112 & 5100 - Built Right UCAs - AFE Intake, TBS, & Exhaust - Pedal Cmndr - Icon Rebound - 285 BFG KO2
    The factory trd wheels are 7.0 The OR wheels are 7.5 - The FN TRD Pro-looking wheels are 7.5
  25. Aug 23, 2019 at 1:52 AM
    mynameistory
    mynameistory New Member
    Tory
    The same 4Runner everyone has
    Fixed that for ya.
    WallyT4R likes this.
  26. Aug 23, 2019 at 7:43 PM
    Hwnrunner
    Hwnrunner New Member
    Hawaii
    2019 4Runner SRS Prem 2wd
    TRD Pro Struts/ Coils, Toytec 1" spacer, Dobinsons C59-505 Springs,TRD Pro Sema Wheels, TRD Pro Lower Valances, Ceramic Tint
    There's a Cornfed 1" rear spring spacer avail the 4sale section!:rolleyes:
  27. Aug 24, 2019 at 7:00 AM
    LKN4Runner
    LKN4Runner New Member
    Lake Norman, NC
    2016 Magnetic Grey Metallic XP 4X4 with 20" Gunner rims and 275/55 R20 Nitto Grappler G2 Tires.
    LOL
  28. Aug 25, 2019 at 6:14 PM
    Barcelona Trail
    '16 TEP w/ KDSS
    Cheers!
  29. Aug 26, 2019 at 7:48 AM
    93civEJ1
    93civEJ1 New Member
    TN
    2014 LE 4Runner
    CALM YOUR TITS.
    schneiderttu likes this.
  30. Dec 24, 2019 at 10:26 PM
    SKT_07
    SKT_07 New Member
    Curious if you’ve upgraded the suspension yet?
    If so, what did you end up with? Thanks!
