Stock height question
Discussion in '5th Gen 4Runners (2010-2024)' started by Oldtoyotaguy, May 18, 2020.
  1. May 18, 2020 at 12:11 PM
    Oldtoyotaguy
    Oldtoyotaguy [OP] Paid cash for it
    2018 Toyota 4 Runner Offroad
    I’ve seen in various threads all kinds of quotes about stock ride height, as measured from the hub centre to the top of the fender edge. Is there a factory spec for this dimension? Of course, lifted heights vary a lot, as there are so many permutations and combinations for lifting these vehicles. Could we post some stock ride heights here, just to see what the variance is? Thanks!
  2. May 18, 2020 at 12:49 PM
    My stock height measurements, from hub ctr to fender edge :
    LF 19.25"
    RF 19.50"
    LR 21.75"
    RR 21.75"
    Oldtoyotaguy[OP] likes this.
  3. May 19, 2020 at 6:28 AM
    Oldtoyotaguy
    Mine is:
    LF 19.25
    RF 19.25
    LR 21.25
    RR 21.25
    However, that’s with a steel rear bumper, steel Front Runner roof rack, Aluminum front bumper/winch, and recovery bag in the cargo area. So it’s a stock suspension but carrying about 300lbs
  4. May 19, 2020 at 7:02 AM
    All i have extra is a set of RSG sliders, about 100# for the set. I measured before and after slider install, pre-lift, and the measurements didn't change afterward.
  5. May 22, 2020 at 6:31 PM
    ForRun
    ForRun 4Runner
    2020 orp
    You guys have unicorns. Out of 3 runners I've had they all have rear lean! the pro leaned 3/4", others 1/2"
  6. May 22, 2020 at 6:49 PM
    Oldtoyotaguy
    Hey ForRun - you need to take the four cases of beer that are loaded in one side out of the vehicle before measuring.
  7. May 23, 2020 at 5:27 AM
    71GS3504sp
    71GS3504sp New Member
    George
    2018 white 4runner
    My 18 4runner measurements, from the lower rim lip/thru the center of the hub and fender opening.
    Before level lift:
    LF-29.00"
    RF-29.25"
    LR-31.25"
    RR-31.25"
    After level lift:
    LF-30.75"
    RF-30.75"
    LR-31.25"
    RR-31.25"
    Yes most has a front lean down on the driver side.
    If you check out all the 4runner Pro's with the FOX shocks the left shock is set higher than the right side, this is to fix the lean!
    This was the same case with my 08 FJ.
    nimby and Oldtoyotaguy[OP] like this.
  8. May 23, 2020 at 10:43 AM
    Oldtoyotaguy
    It looks perfect, 71GS3504sp!
