Still have doubts for front recovery point~
Discussion in '5th Gen 4Runners (2010-2024)' started by exia, Oct 6, 2019.
  1. Oct 6, 2019 at 3:08 PM
    exia
    exia [OP] New Member
    2019 4runner TRD Pro
    Hi everyone, I’m still new here, and I know that this topic has been already discussed thousands of times. But I still want to get some fresh news about you professional guys.
    I have 2019 4R TRD Pro, For the front recovery point, many people say that two points are for shipping purposes and couldn’t be used as rated recovery point. Does it mean we can not attach there if we need to be towed by other cars.
    And I found Treaty Oak sell two brackets recovery point mount bolts on, is that useful or anyone has any reviews on it? Here is the link
    https://www.treatyoakoffroad.com/pr...ery-point?from=singlemessage&isappinstalled=0
    Could you guys make me more clearly which could be used and which shouldn’t be done at this point?
    Thanks a lot!!!
    WallyT4R likes this.
  2. Oct 6, 2019 at 3:16 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    People like to tell you they’re not recovery points. People also can’t reference a single documented failure of them being used as recovery points.
    Maybe if you plan on becoming a serous off-roader upgraded, otherwise I wouldn’t worry about it.
    A&P, DRobs, Han4Run and 1 other person like this.
  3. Oct 6, 2019 at 3:20 PM
    Firefly21
    Firefly21 New Member
    Duane Frazier
    18 off road premium trd
    Hid lows 3500 drl / high Led interior Led reverse Led oem fogs Sequential blinker Trd intake Unifilter pump mod Apex recover points BF Goodrich KO2 (matching trd spare) Kicker front tweeters Tvd overlays S2 yellow wide fogs Apex black sequential rear tails Cartrim home blue convex mirriors
  4. Oct 6, 2019 at 3:34 PM
    scottalot
    scottalot Stockalot
    Scott
    Charleston SC
    2018 T4R offroad
    To be determined
  5. Oct 6, 2019 at 6:01 PM
    exia
  6. Oct 6, 2019 at 6:02 PM
    exia
    Yes, I tried to find out some failed pictures for these two factory points, but can’t find them~
    Han4Run and (deleted member) like this.
  7. Oct 6, 2019 at 6:11 PM
    Firefly21
    Duane Frazier
    Sorry I just read this...I have an 18 OR no issues. Not sure what would change
    A&P likes this.
  8. Oct 6, 2019 at 6:14 PM
    exia
    Than you!
  9. Oct 6, 2019 at 6:21 PM
    exia
    Does this difficult to install?? Thank you.
    scottalot[QUOTED] likes this.
  10. Oct 6, 2019 at 9:19 PM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX4(Runner)60
    Just use the factory tie down loops. They are plenty stout.
    Most people that say they aren't useable haven't ever actually used them. I use them for winching (with a snatch block and in-bumper winch) and they are fine.
    If you want to bolt bling on to your truck you don't need an excuse to do it.
    A&P, DRobs, Han4Run and 2 others like this.
  11. Oct 7, 2019 at 2:11 AM
    scottalot
    scottalot Stockalot
    Scott
    Charleston SC
    2018 T4R offroad
    To be determined
    Not at all. Nothing more than a few bolts and about half an hour. Super straight forward
    DrewMan likes this.
  12. Oct 7, 2019 at 3:01 AM
    WallyT4R
    WallyT4R New Member
    "Bling" or not, (however they do look badass) the Apex Overland brackets are way stronger than the factory points and worth the money IMO. They also are lower by a little bit and will cause less damage if the line happens to run into the bumper for us that dont have an aftermarket bumper yet. On top of that they are only $144.
    4Runner fun, exia[OP] and scottalot like this.
  13. Oct 7, 2019 at 7:09 AM
    MeefZah
    Lexington, Ohio
    2020 GX4(Runner)60
    Interestingly, I don't think those will work with a winch since a hidden winch mounts to the same location as those appear to.
  14. Oct 7, 2019 at 8:56 AM
    scottalot
    scottalot Stockalot
    Scott
    Charleston SC
    2018 T4R offroad
    To be determined
    They go ahead n sale too.. I pd like 120 for my set
  15. Oct 7, 2019 at 9:50 AM
    exia
    Thanks!
  16. Oct 7, 2019 at 10:02 AM
    exia
    And I wonder which kind of damage could be done to the factory eyelets ? Or damage for the chassis if we over use these two points?
    Always hear not to use them, but never know which kind of damage could happen~
    Thank you’
  17. Oct 7, 2019 at 11:22 AM
    4x Old Guy
    4x Old Guy New Member
    Riverside, CA
    Big-O Bigfoot A/T tires
    I saw an episode of Mythbusters where they suspended a 70s era station wagon using Super Glue. I would think that the factory anchors would at least be as strong as Super Glue.
    A&P, Han4Run, DrewMan and 3 others like this.
  18. Oct 7, 2019 at 12:27 PM
    4x Old Guy
    Riverside, CA
    if you have a unibody vehicle with a factory anchor point attached to body thickness metal, it stands to reason that an aftermarket anchor would be stronger because, most likely, it spreads the force over a larger area because it’s probably attached to the body by multiple points.
    One of the big marketing points for the T4R, and a big reason why we bought them, is because they are one of the few vehicles that are still body on frame construction. With that in mind, if the anchors are attached to the frame, that’s the strongest point that any anchor can be attached to. If you’re in a situation where your recovery gear is damaging the frame, you’ve probably got bigger problems to worry about. I’m no metallurgist, but looking at the thickness of the metal that the factory anchors are made of and comparing with similar size recovery gear components, my guess is that they’re pretty strong. Geometry of aftermarket anchors so that attached cables are better positioned, kudos to them, maybe I’ll buy some.
    A&P likes this.
  19. Oct 7, 2019 at 5:14 PM
    4Runner fun
    Ryan
    Nebraska
    Along the like of my thinking. If Toyota says they are "recovery points" they open themselves to liabilities. If you get stuck or don't know how to use recovery gear, you can put a lot of stress & pressure on that weld (much more than rocking on a ship). If for any reason those welds fail there is now a metal projectile & they can get away from it by saying (not recovery points).
    Could you use for recovery. I bet.
    Would I trust it if I buried the axels or one wheel fell into a hole. Nope, too much force.
    As a business owner I see liabilities.
    My $0.02
    KSJ08 and WallyT4R like this.
  20. Oct 8, 2019 at 12:03 PM
    4x Old Guy
    Riverside, CA
    That sounds like the thing I had to sign when I bought my T4R that said I couldn’t run chains in the snow.
  21. Oct 8, 2019 at 3:24 PM
    exia
    Thank you for this long thought !
    KSJ08 likes this.
  22. Oct 27, 2019 at 6:27 PM
    Flyguy183
    Flyguy183 New Member
    I asked my Toyota dealer the same question. They said they are tie downs BUT...if you are stuck and are self winching out forward with a snatch you probably aren't pulling their capacity. But as other say, liability. Hopefully you aren't continually winching forward with a snatch block on your new 2019 TRD. Send your buddy to lead and winch off him.
  23. Oct 27, 2019 at 6:49 PM
    2020runner
    2020runner New Member
    4runner
    Always carry/use a recovery strap that takes the shock of getting pulled out.. I CANNOT STAND WATCHING dumazzess use chains. CHAINS CREATE SHOCK AND definetely will and can break stuff if yanked hard with speeD >>>> CLAK hitch moved a little or weldz somewhere can crack or dangerous situation.
    My pet peeves >>> vertical videos, chains for recovery, pop it in drive with reverse momentum, not using p brake, holding steering wheel when steering pump cries and trying to steer more, list too long...
    A&P and Flyguy183 like this.
  24. Oct 27, 2019 at 6:52 PM
    2020runner
    4runner
    Safest bet is to carry those orange plastic traxxx. Let the engine pull you out.
  25. Oct 27, 2019 at 6:56 PM
    Flyguy183
    But there is something to be said with the entertainment value of watching and placing bets of how it will turn out. Broken rear window of tow vehicle for the shock of a broken chain or attachment point.
    A&P and 2020runner like this.
  26. Oct 27, 2019 at 6:57 PM
    2020runner
    4runner
    Track grabbers for the win !!!
  27. Oct 28, 2019 at 5:05 AM
    DoubleRGirl
    DoubleRGirl New Member
    Rebecca
    2019 TRD Pro
    working on it
    This doesn't help if you're high centered on a flat rock between two trees. Ask me how I know
  28. Oct 28, 2019 at 6:29 AM
    2020runner
    4runner
    Well, getting pulled out while being high centered can break more stuff too.
  29. Oct 28, 2019 at 6:32 AM
    DoubleRGirl
    Rebecca
    2019 TRD Pro
    working on it
    it was a winch/hi-lift jack recovery
    KSJ08 and SlvrSlug like this.
  30. Oct 28, 2019 at 7:51 PM
    Lol! This example sounds pretty specific..:D
    A&P and DoubleRGirl[QUOTED] like this.
