Steering wheel went out
Discussion in '1st Gen 4Runners (1984-1989)' started by Chellecro9755, Oct 27, 2024 at 9:00 AM.
  1. Oct 27, 2024 at 9:00 AM
    Chellecro9755
    Chellecro9755 [OP] New Member
    Friday
    Lisa
    Silver 2020 4 runner
    1987 sr 22 put it in four wheel drive and went to back up and heard a loud pop , and now the steering wheel just went out ? Has been leaking transmission fluid and the whining sound of power steering pump has been happening for a while .
  2. Oct 27, 2024 at 11:16 AM
    gonpostal
    gonpostal New Member
    Scott
    Southeast NC
    2024 4Runner SR5 Premium Underground w/ XP Gunner pkg
    Your serpentine belt may have broken.
  3. Oct 27, 2024 at 11:21 AM
    Chellecro9755
    Friday
    Lisa
    Ok thanks for input it’s my dads truck he’s done a lot to it as far as replacements it happened when he put it in 4 wheel drive and he cut it pretty sharp and popped and then his steering wheel will turn completely around and around but no steering . Thought it might be the axle but I don’t know too much about vehicles .
  4. Oct 27, 2024 at 11:21 AM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    What exactly do you mean the "steering wheel went out", are you saying it's very hard to turn or it doesn't move the wheels when you turn the steering wheel?
  5. Oct 27, 2024 at 11:22 AM
    Chellecro9755
    Friday
    Lisa
    It turns freely but doesn’t turn the wheels
  6. Oct 27, 2024 at 11:24 AM
    Chellecro9755
    Friday
    Lisa
    Could it be the gear box?
  7. Oct 27, 2024 at 11:24 AM
    gonpostal
    Scott
    Southeast NC
    Sorry, I figured you meant that it was hard to turn the wheel. I've never heard of the steering wheel turning freely, there's probably something else going on.
  8. Oct 27, 2024 at 11:25 AM
    AuSeeker
    Skip
    South Carolina
    2004 Limited
    I just saw your reply above, it sounds like the "rag" joint and or the u-joint has sheared, look under the hood at the steering column, follow it down you should be able to see what broke by having someone turn the steering wheel while another looks at the column.
    Edit: Yes it could be the steering box, and or some of the linkage to the wheels.
  9. Oct 27, 2024 at 11:29 AM
    Chellecro9755
    Friday
    Lisa
    Ok thankyou I’m going to go down and look at it with my dad right now.
