Steering wheel lock
Discussion in '4th Gen 4Runners (2003-2009)' started by Matt2005_4Runner, Jul 11, 2024.
  1. Jul 11, 2024 at 4:58 PM
    Matt2005_4Runner
    Matt2005_4Runner [OP] New Member
    2005 4Runner SR5 V6
    I have a 2005 4Runner and the barrel rod broken in the ignition cylinder. I am trying to remove the steering column cover and accidentally locked the wheel before removing the last screw. Since I am not able to enter a key and turn to accessory is there another way to unlock the wheel?
    thanks
  2. Jul 11, 2024 at 5:11 PM
    Lars98
    Lars98 New Member
    Lars
    1986 Turbo SR5
    Wheeler
    All the way Inside of where the ignition barrel would meet the car you can pull out the small metal piece that the ignition barrel connects to and there might be a slide that moves up and down if you press on the bottom of it with a screwdriver and push it down it might release the slide lock. Just throwing out some info I have done this on older generations but don’t have experience with it on a 2005
  3. Jul 11, 2024 at 5:17 PM
    Matt2005_4Runner
    2005 4Runner SR5 V6
    Thanks! I will give that a shot.
