Starting up after sitting for 2 years, advise please!
Discussion in 'General 4Runner Talk' started by Mehash, Sep 26, 2023.
  1. Sep 26, 2023 at 2:45 PM
    Mehash
    Mehash [OP] New Member
    '99 T4R
    Hello folks!
    I'm just finishing installing a used engine (310,000 kms) onto my '99 Limited.
    I bought the engine from a good source and they ran it for me just before removal for me to see how smoothly it ran.
    This engine has had the valve covers off and oil pan off for about 5 months now with no oil in it.
    Now that I'm sealing it up again with new gaskets (didn't replace the head gasket) i wanted to get advice as to what I should do before I begin trying to start it up after install.
    Do I need to add any special lubricants to the cam lobes or squirt anything special into the cylinders first?
    I plan on emptying the gas with the fuel pump once electricals are assembled again as the truck has been sitting for 2 years.
    Not sure if I absolutely need to replace the Auto Transmission fluid?
    Thank you for your help!
  2. Sep 26, 2023 at 4:25 PM
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    Can you disable the ignition and just turn it over with the starter to pump oil around the engine and maybe build a little oil pressure?
  3. Sep 26, 2023 at 4:55 PM
    Mehash
    '99 T4R
    Yes that's a good idea, would I have to also disable to fuel system too so I don't flood the engine?
