SSO Hybrid Slimline Bumper on 2020 Pro - Skid Plate?
Discussion in '5th Gen 4Runners (2010-2024)' started by JollyGreenGiant, Oct 4, 2021.
  1. Oct 4, 2021 at 2:58 AM
    JollyGreenGiant
    JollyGreenGiant [OP] New Member
    T
    2020 Army Green TRD Pro 4Runner
    Westcott Lift
    Hey guys…
    Installed a hybrid slimline on my 2020 pro last night. Winch with access. Looks great.
    In SSO’s PDF instructions it specifically says to remove the TRD Pro skid. Well - I did. Installed the bumper. Went to go put the skid back and it doesn’t fit.
    There doesn’t seem to be a millimeter’s worth of clearance for it to fit under it alternatively and the two front bolts certainly aren’t tall enough to fit over it.
    I messaged SSO and they said there shouldn’t be any fitment issues with pretty much any skid out there - especially OEM. Waiting to hear back from their mechanic.
    That being said - I’m not sure what I did wrong here.
    Bumper is beautiful. Install wasn’t terrible (it’s just heavy as crap with the winch + light bar).
    thanks!
  2. Oct 4, 2021 at 5:18 AM
    newlife
    Knoxville TN
    2021 venture 22 JTR
    All of them.
    Can you post pics showing where it’s hitting. SSO is right it shouldn’t hit there should be quite a bit of clearance
  3. Oct 4, 2021 at 5:59 AM
    rickystl
    rickystl New Member
    Rick
    St. Louis, MO
    2021 TRD/Off-Road Premium
    Hope you figure it out. Great looking front end appearance.
  4. Oct 4, 2021 at 6:11 AM
    fajitas21
    fajitas21 New Member
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    I had to angle my front part of skid in, then lift. It wouldn't just go straight up.
  5. Oct 5, 2021 at 1:41 PM
    Big B
    Big B Out Exploring
    Reno/Tahoe
    2020 TRDOR
    KINGS! w/ adjust Method Race Wheels, Good Year Ultra-terrains 285/70/r17, GOBI Rack, Baja-Designs/Cali-Raised LED Lights, SSO stealth front bumper, RSG Sliders, FACTOR 55 ultrahook Smitty Bilt x20 winch (syn.), TYT TH9800, X Bull Recovery Boards
    It can be difficult, I bought longer front bolts to help, I've also found its better to get them all started then tighten...... then just wait til you break one of the weld nuts loose and have to do inserts because theres no way to fix the now loose nut inside a boxed tube.:mad::burnrubber:
    Jynarik likes this.
  6. Jan 23, 2022 at 7:37 AM
    Toyman2020
    Toyman2020 New Member
    4runner TRD Pro (Black)
    On a new 2020 4R TRD Pro Does the slimline bumper cover the Toyota TSS?
    CibolaLichen likes this.
  7. Jan 23, 2022 at 8:09 AM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    I had to change bolt sizes for my full c4. It fit my slim c4 no issues.
  8. Jan 23, 2022 at 1:30 PM
    BobbyB
    Bob
    Marietta, GA
    2021 White TRD Off Road
    OP,
    I just took delivery of an SSO slimline bumper with the high hoop for my 2021 OR.
    Noted in the instructions for those with a TRD Pro skid plate is to remove the lower panel from the bumper (screws into main bumper) before reinstalling the TRD Pro skid plate. This will allow the skid to bolt up. Then reinstall the lower panel on the bumper.
    I took a good look at my new SSO bumper and the panel referenced would interfere with the high front lip of the TRD Pro skid. Take a look and see if removing the panel will fix the issue for you..
    Cheers,
    Bob
  9. Jan 23, 2022 at 1:35 PM
    BobbyB
    Bob
    Marietta, GA
    No, the high hoop on the new SSO slimline bumper clears the TSS sensor. Several who have installed on 2020 & 2021 models have reported that TSS works fine.
    SSO also confirms that there is no interference. As soon as I Install the one I just purchased (delivered to me on Friday), I’ll follow up with my results but not expecting any issues..
    Cheers,
    Bob
  10. Jan 25, 2022 at 11:19 AM
    Metalsaber
    Metalsaber New Member
    So i have a SSO bumper in build atm, so I'm kind of interested to see how this will go. Also running the TRD Skid plate but I removed the upper portion which I'm guessing is what people are suggesting to remove.
  11. Jan 25, 2022 at 3:40 PM
    TRD Toy
    TRD Toy New Member
    David
    20' Toyota 4Runner TRD OR
    Looking at an SSO hybrid myself. What led light is that?
  12. Jul 24, 2022 at 5:42 PM
    Hi @ JollyGreenGiant,
    I had similar issue with my skid plate and had to remove it as I couldn't fit well the SSO bumper. Did you end up removing the TRD skid plate after all? In your picture at the top, I don't see it. Just trying to figure out how to proceed with my install. I am doing exactly the same as yours. Thanks!
  13. Aug 4, 2022 at 3:53 PM
    Just posting it here as well for completness of the thread. This is the SSO low profile bumper with the S2 clearance wings. I am not so thrilled about the Viper cut....but it is done.
    S8ULATR likes this.
  14. Aug 4, 2022 at 4:15 PM
    S8ULATR
    S8ULATR New Member
    CA
    2 Germans & a Beast
    Very nice looking truck, personally I think the slimline with the S2 clearance wings is the cleanest look of any front bumper situation that requires a viper cut. Your setup is what I plan to do to mine. That said, I haven't cut the truck yet, so I get it. Hopefully it becomes your new norm and you get used to it ? :cheers:
    ChessGuy[QUOTED] likes this.
  15. Nov 11, 2022 at 8:48 AM
    TrailSpecial22 New Member
    PA
    Not sure if there was a follow up on this thread but this appears to be a Trd pro with a SSO’s bumper and Trd skid plate fitting just fine
