SR5 Stock Height Measurements?
Discussion in '5th Gen 4Runners (2010-2024)' started by brochacho, Aug 16, 2016.
  1. Aug 16, 2016 at 8:35 AM
    brochacho
    brochacho [OP] New Member
    2018 Sequoia TRD Sport
    I'm an idiot and forgot to measure before my lift. Does anybody have their stock height measurement with stock SR5 wheels? I don't really care about the method used (hub to fender or ground to fender) and I know every truck is different but I'm hoping it should at least be in the ballpark. Thanks!
    Strandskov likes this.
  2. Aug 16, 2016 at 1:39 PM
    Bob
    Bob Member Staff Member
    Bob
    Sub'd so we can sticky it
  3. Aug 17, 2016 at 1:34 PM
    MaliciousClout
    MaliciousClout New Member
    Ian
    2015 TEP SuperWhite
    TRD garnish/PlastiDipped Valances/ N-Fab Steps/285-70-17/3 Inch ToyTec Lift/1.25 Spidertrax Spacers/Total LED Swap/6000K HID
    All T4R's heights vary from the factory. I'm interested though in seeing the differences albeit slight I'm sure. Sub'd as well.
  4. Aug 18, 2016 at 3:10 PM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    on my 2016 1K miles front ground to bottom of the fender @ center cap. 34-5/8inch rear 36-5/8 inch..
    I just adjusted the front tie rod pass side today added a little toe in .. had zero toe wandered too much. good now.
  5. Mar 16, 2019 at 3:52 PM
    P226Navy
    P226Navy 2016 T4R
    Vee
    South San Francisco
    2016 Toyota 4Runner
    Center cap to fender line is the most accurate measurement.
  6. Mar 16, 2019 at 7:05 PM
    JohnD
    JohnD New Member
    My 2018 SR5 was 19.6” front driver, 20” front pass, 21.5” rear driver, 22.1 rear pass. Center of cap to fender lip.
  7. Mar 17, 2019 at 7:08 AM
    j cat
    j cat New Member
    massachusetts
    yes you are correct for the accurate measurement of vehicle height .. but I did the spring spacer lift and I was not all that concerned about the exact height , was only interested in the amount of lift it/spacer created.
    the vehicle has now 25K miles on it and all my tires look exactly the same .. also the nose dive is still gone .. spring spacers holding up and also on the cheap .. cost $20 total..
    P226Navy[QUOTED] likes this.
  8. Mar 17, 2019 at 8:00 AM
    P226Navy
    P226Navy 2016 T4R
    Vee
    South San Francisco
    2016 Toyota 4Runner
    What spacers are they?
  9. Mar 17, 2019 at 2:04 PM
    j cat
    j cat New Member
    massachusetts
    the coil springs are different . the driver side is a stronger spring bigger so the gas tank will not cause the vehicle to droop on the driver side the pass side has a smaller coil spring spaces closer..
    I fabricated a 11/2 inch screw in spacer into the lower portion of the driver side spring. had to cut it and file the contour..
    ON the pass side I installed 2 1inch spacers on the lower portion of the coil .. one in front the other in rear of the pass coil .. had to fabricate the spacer so it would screw in and not whack the shock tube..
    perhaps when my front shocks need replacing and I have the tools I will install the bilstein adjustable shocks and use a strut spacer to stiffen the springs .. I am no toyota lift expert but so far I am doing good on the dive issue that many did not like..
