Squeaky front suspension
Discussion in '5th Gen 4Runners (2010-2024)' started by Shredder, Jul 23, 2024.
  1. Jul 23, 2024 at 8:16 PM
    Shredder
    Shredder [OP] New Member
    I have a 2023 OR 4runner with about 12,000 miles and today on some kinda rough two track roads the front end developed a squeak when going over bumps or holes. Is it a common problem and is there anything i can do to quiet it?
  2. Jul 23, 2024 at 10:20 PM
    Rick G.
    The Texas Hill Country
    2022 SR5 Premium 4WD
    A few weeks ago I developed a squeaking noise in the front of my 2022 SR5 Premium 4WD. I traced the squeak to the two adjustable rubber bump stops under the hood- one at each front corner of the engine compartment. You’ll see them when you have the hood open. They are adjustable by turning them clockwise or counter-clockwise. I spritzed the tops of both of those black rubber bump stops with some WD-40 and the squeaking noise stopped. This might be where your squeak is coming from. I also thought the noise was coming from my front suspension at first, before finding out otherwise. Other than WD-40, I suppose a couple dabs of white grease on the bump stops, or some silicone spray could also be used. Good luck.
    Guppy1301 and Shredder[OP] like this.
  3. Jul 23, 2024 at 10:33 PM
    Fortuner
    Fortuner New Member
    CA
    2021 4Runner TRD Off Road Premium w/KDSS
    If it’s not the hood adjusters or hood latch, check your engine splash guards.
  4. Jul 23, 2024 at 10:43 PM
    +1
  5. Jul 23, 2024 at 11:24 PM
    Gripster
    Gripster New Member
    2016 Trail Premium
    Splash guards is my vote.
  6. Jul 24, 2024 at 6:20 AM
    Shredder
  7. Jul 24, 2024 at 7:55 AM
    Fortuner
    Fortuner New Member
    CA
    I ended up replacing mine with aftermarket ones to avoid the noise. To diagnose it, I placed electric tape on them and drove around on a route I knew would make the noise…with the tape, the noise stopped. I ordered replacements from a place called “rad rubber designs”
    Shredder[QUOTED][OP] likes this.
  8. Jul 24, 2024 at 9:58 AM
    Shredder
    I went to a self serve car wash and was able to get a ton of dirt out of the wheel wells. Now I don’t hear the squeak.
    The looks like plastic screws holding the splash guard, are those like thumb screws? Is there a nut or a threaded hole behind the guard?
  9. Jul 24, 2024 at 10:43 AM
    It's just a clip.
    I think the part number is 90467-10186 (if I'm not mistaken).
