Squeaky brakes ??
Discussion in '5th Gen 4Runners (2010-2024)' started by 4runningMan, Dec 12, 2018.
  1. Dec 12, 2018 at 11:59 AM
    4runningMan
    4runningMan [OP] New Member
    New Mexico
    i have about 1000 miles on my truck and have been having intermittent squeaky brakes.
    Maybe twice a week I'll be rolling through a parking lot slowing down or in stop and go traffic and all of the sudden the brakes squeak terribly loud. And I can make it happen on-demand.
    If I ride the brake it will squeak indefinitely. And then after a few minutes, it goes away. Not to be heard for a few days or a week.
    Anyone know what could be causing it? When it does happen, it is LOUD.
    deaone123 likes this.
  2. Dec 12, 2018 at 3:21 PM
    BX22BR
    BX22BR New Member
    Hardy
    mine does the same thing...dealer checked it out and couldn't find anything. I have about 9000 miles on mine.
  3. Dec 12, 2018 at 4:08 PM
    4runningMan
    New Mexico
    I went to the dealer today when it started squeaking but by the time I got there it stopped. So I didn't go in. Ha I Figured they would just say they couldn't find anything wrong.
  4. Dec 12, 2018 at 4:09 PM
    4runningMan
    New Mexico
    I wonder if it's a moisture thing. It was foggy today. Taking a warm (garaged) truck out in to the cool foggy weather... maybe some condensation? I'll start to pay more attention to when this occurs.
    I'm not overly concerned. Mostly just curious.
  5. Dec 14, 2018 at 8:48 AM
    DGP1961
    DGP1961 New Member
    2018 SR5 Premium
    Interesting please post back if you nail it down would be good to know.
  6. Dec 14, 2018 at 12:00 PM
    4runningMan
    New Mexico
    I'm thinking it's condensation on the calipers or pads. Dependent on humidity and temp... when going from warmer to colder air. And then it stops after a few minutes or as surface temps equalize. Just a guess at this point.
  7. Jan 18, 2019 at 6:02 AM
    deaone123
    deaone123 4 runner 4 fishing
    19 4 runner lE nightshade
    My brakes on my 19 limited did this to it happened pnce or twice at 1000 miles but hasnt happened since
  8. Jan 18, 2019 at 7:50 AM
    Oey12
    Oey12 New Member
    Joey`
    2017 SR5
    Eibach Pro Sport leveling shocks, Firestone airbags, and Baja Design fog lights...
    It’s funny I have squeaky rear brakes as well on my 2017 and I was planning on scheduling an appointment to have them checked out. I currently have 31k on my truck and it started about 15 to 20k ago...but the performance hasn’t changed. Now it happens quite often but not consistently during certain conditions.
  9. Sep 29, 2019 at 9:10 PM
    toy33
    toy33 New Member
    T. Batey
    CA: OC LA SD BB
    2024 TRD Pro Tundra - Terra
    PPF Front end hood, grill and headlights
    Mine does this only on first braking in the morning, after it's been sitting for 15 hours or so. Then goes away … not even 3k miles on my 4Runner and I'm light on the brakes. Surface rust is my guess.
    KSJ08 likes this.
  10. Sep 30, 2019 at 7:18 AM
    Liv2Ride
    Liv2Ride New Member
    ’19 MGM Limited
    Eibach Stage 2, JBA UCA’s, K02 - 265/70, Ark guards, Sony XAV9500ES
    I noticed the same, although I have not measured the number of hours. It seems that the first time I drive it ('19 Limited), usually in the morning to go to work, it will occur with each brake application for about the first 300-500 yds or so. This is usually in low speed conditions e.g. navigating parking garage and closely spaced traffic lights. I have about 3,800 miles and it has done it from day one. Taking for service on Saturday, will see what they say. I have had many Toyota's and this is the first vehicle that made this sound.
    toy33[QUOTED] likes this.
  11. Sep 30, 2019 at 7:57 AM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    I have had brakes squeak over the years long ago. the caliper brake pads backing plate makes this noise.
    what I do when doing the brake job , I put a small amount of anti seize on the backing plate of both pads.just a small paint like amount that is all required..
    make sure the pads move easy in the caliper . I installing new pads had to file down the backing plate because the metal stamping machine was not properly setup .. pads can bind if not fabricated properly .. some had metal burrs sticking the pads.
    you have 1000 miles on it well I never had this problem with my 2016 runner. but I did check out the brakes when new .. I also removed the rotors so I put anti seize on the hub .. reason I do this is when I need the rotors replaced it is a b*tch to remove them, because they are rusted/locked in place on the hub..
    4scooter19 likes this.
  12. Sep 30, 2019 at 1:13 PM
    Compromised 4Runner
    Compromised 4Runner New Member
    2018 4Runner SR5
    I've noticed this too. In some cases I can see it being a condensation thing, but other times it does not make sense. Semi-related: Is there a way to check the breaks without taking the tires off? Can't seem to find a spot for my digital caliper.
  13. Mar 6, 2020 at 10:32 AM
    Rick Nevada
    Rick Nevada New Member
    Rick
    2020 TRD OFF-ROAD 4RUNNER
    Replaced 17” OEM WHEELS AND TIRES with 20” that came with my 2015 Limited. Tire size 275/55/R20 Nittos.
    Just took delivery of a 2020 TRD and am having the same problem w squeaking breaks after car sitting overnight. It does clear up after a few stops. Not really concerned as it’s been cold and rainy and I believe it’s from the moisture as it does not do it when weather is clear. Am a bit annoyed after paying in the $43,000 range. My 2015 never had a problem. I will be speaking to a tech at the dealer to see if this is a common occurrence. Hoping they’ll give me an honest answer.
    skull likes this.
  14. Mar 6, 2020 at 10:40 AM
    Daytonaviolet
    Daytonaviolet TRD Bro
    Bay Area, CA
    Blizzard Pearl TRD Bro
    Does anyone know the typical mileage or thickness when these pads should be changed ?
  15. Mar 6, 2020 at 1:16 PM
    Jack Diesel
    Jack Diesel New Member
    2020 TRD OR Premium
    7k on my 2020 ORP and I've had this issue from day 1. My dealership can't find any problems with the brakes but it's definitely annoying as hell!
    skull likes this.
  16. Mar 6, 2020 at 1:24 PM
    Pinegreen
    Pinegreen New Member
    2020 SR5 Premium. ~1,000 miles. Mine does this too. Usually squeaks in the morning for the first 100 yards or so, then stops. My guess is it's the pads/rotors that they are using. Mine only happens initially when it's cold.
  17. Mar 6, 2020 at 4:50 PM
    j cat
    j cat New Member
    massachusetts
    many that do not slam the brakes all day long the pads will last 75K miles..
    some had to change the pads 30K miles. brake slammers will also need rotors and pads .
    a few did do the pad changes over 100K miles because of operating in a back country area..
    if you live in Washington DC then need pad changes 25K miles..
    rotate tires then inspect the pad wear.. all should be worn the same amount ..if the pads are down to 1/8 inch or so then change them..if one pad is not the same wear as others , then this is a failure.
    Daytonaviolet[QUOTED] likes this.
  18. Mar 6, 2020 at 9:15 PM
    Tama1968
    Tama1968 New Member
    Florida
    T4R SR5 in Classic Silver
    If I leave my Runner outside overnight when it's below around 50 deg and the humidity is up, the first few stops are sqeaky as hell. then it gets back to normal. our other cars don't do this...just figured its a quirk for the 4Runner.
    skull likes this.
  19. Mar 7, 2020 at 3:02 AM
    skull
    skull New Member
    Karl
    NC
    2019 Trd ORP
    Mine too...dealership found nothing, of course. I took them all apart myself, scuffed pads with scotch brite and rotor edges, cleaned everything. It lasted a day and started again,very annoying so it must be new compound in pads and/or rotors. Next time I am going to try MOC brand brake quiet that soaks into pads if I can find some...
  20. Mar 7, 2020 at 4:30 AM
    Georgia Native
    Georgia Native New Member
    2019 OR Prem and 2017 Tacoma SR5 4x4
    Did you lube the metal plates between the caliper and pad?
  21. Mar 7, 2020 at 6:28 AM
    skull
    skull New Member
    Karl
    NC
    2019 Trd ORP
    Nope ,just cleaned really good.
  22. Mar 7, 2020 at 7:59 AM
    Georgia Native
    skull and toy33 like this.
