Speedometer Issues
Discussion in '2nd Gen 4Runners (1990-1995)' started by JH5370, Aug 25, 2017.
  1. Aug 25, 2017 at 9:33 AM
    JH5370
    JH5370 [OP] New Member
    Josh
    2016 White SR5 4Runner
    So my cousin has a 93 Limited 3.0 4x4 auto. He just picked it up for $2k with 110k miles. Pretty nice rig, but has a couple issues. One of which is the speedo. It reads incorrectly. It shows about 25-30 mph higher than you are actually driving. This also becomes an issue when at highway speed. It appears there is some sort of governor on the truck. When you reach 100 mph on the speedometer (somewhere around 65 mph) the throttle will cut out completely. It stays running but you have a dead pedal and the throttle shuts off until you slow down.
    It gets even wierder... If you are able to get into OD before you reach 100 on the speedo (about 65 mph) then you can continue to speed up and the the needle will max out. As you can imagine this is not only a pain in the ass but also dangerous as you have no idea how fast you are going, and you may get the dead pedal at anytime if you drop out of OD.
    Any ideas on the issue or how to fix this?
  2. Aug 25, 2017 at 12:06 PM
    Caltech90
    Caltech90 New Member
    '19 TRD OR
    Do you know the history on it? It does sound like it has some kind of governor. Post some pictures of the motor from all sides.
  3. Aug 25, 2017 at 12:37 PM
    JH5370
    Josh
    I don't know any history on it. I will get some pictures later today I have to swing by my cousin's house when I am off work to do so.
    Caltech90 likes this.
  4. Aug 25, 2017 at 7:28 PM
    JH5370
    Josh
    Here are some pictures of the runner. Looks to like it's been in a minor front end collision. There is definitely some bubba'd stuff on it.
  5. Aug 25, 2017 at 7:31 PM
    JH5370
    Josh
    Bubba'd for sure
  6. Aug 29, 2017 at 1:59 AM
    Caltech90
    '19 TRD OR
    Nothing sticks out to me, the wood block on the battery is a nice touch lol.
    JH5370[OP] likes this.
  7. Aug 29, 2017 at 8:28 AM
    JH5370
    Josh
    Haha yea that and it looks like a motorcycle battery. It's way too small.
  8. Oct 23, 2017 at 9:22 AM
    dwag
    dwag New Member
    dennis
    modified 1990, 4x4 , auto
    the last guy doesn't know about new batteries.
    for the speedo error,,,, is there still a cable going to the back of the speedo or is it electronic?
    are the tires the right diameter?
    check engine light??,, comes on at start up then goes off when all is ok??
    the governor effect can only come from the EFI computer??
    a dead gas pedal can only come from the injectors being shut off??
  9. Nov 9, 2017 at 8:25 AM
    JH5370
    Josh
    All stock with no check engine light. No other fueling issues to suggest a bad injector/injectors. I will have my cousin check on the speedo cable and get back to you.
