Speaking about front recovery points.........
Discussion in '5th Gen 4Runners (2010-2024)' started by afret, Feb 11, 2022.
  1. Feb 11, 2022 at 8:49 AM
    afret
    afret [OP] 2022 ORP, KDSS, Toyo AT3
    North Idaho
  2. Feb 11, 2022 at 9:04 AM
    iamincrediboy
    iamincrediboy New Member
    South FL
  3. Feb 11, 2022 at 9:13 AM
    afret
    North Idaho
  4. Feb 11, 2022 at 4:41 PM
    Gstick
    Gstick New Member
    19' TRD OFF ROAD
    Does anyone know where either of the above mentioned brands are made ?
  5. Feb 11, 2022 at 4:48 PM
    Tmiesowicz
    Tmiesowicz New Member
    The better half of New York
    veteran owned and family operated overland and off-road adventure supply company and install shop based out of Greensboro, North Carolina.
    It says they are a fab shop so I would hope USA :oldglory:
    A&P likes this.
  6. Feb 11, 2022 at 6:57 PM
    Gstick
    Gstick New Member
    19' TRD OFF ROAD
    You are correct ! I just got an email from apex & they said "right here in NC".
    I believe that I will order a pair !
  7. Feb 11, 2022 at 7:20 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    Just use your factory front tie down points. Shit won’t break, and if it does, no upgraded recovery points were gonna get you out.
  8. Feb 12, 2022 at 2:36 AM
    Matt83
    Matt83 New Member
    Northeast
    Exactly. Just pull straight and avoid side loading them.
  9. Feb 12, 2022 at 6:43 AM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
  10. Feb 14, 2022 at 6:49 AM
    It’s funny, I call the tie down points, but I was looking at the owners manual and saw that they refer to them there as front tow points. That surprised me. Although they said that they are for towing for a short tine on flat paved surfaces.
    The problem with these (apparently) tow points is that they are always going to be side-loaded in normal use. So the restrictions to use them on flat, paved surfaces for a short distance makes sense.
  11. Feb 18, 2022 at 8:16 AM
    polyguy79
    polyguy79 New Member
    LA County
    2021 White Runner ORP
    RCI aluminum skids (front, trans, TC, and gas), RCI steel sliders 20 degree no plates with kickout, Treaty Oak recovery points, LFD stainless crossbars, Greenlane ladder, Toyo Open Country AT III, Bilstein 5100s, OME (front 2” lift) and Eibach (rear 1”lift) coils
    I have the recovery points made my Treaty Oak installed. They are simple to put on and are rock solid bolted into the frame. These are about $150. Very highly recommended
    donnermel and Trail Runnah like this.
  12. Mar 19, 2022 at 10:13 PM
    donnermel
    donnermel New Member
    dita.yota
    Truckee/Tahoe
    ‘16 Trail Premium Super White w/ KDSS
    Dobinsons lift and UCA, RCI sliders and front engine skid, H9 bulb swap, Sprint Booster, KnN air filter, Canvasback covers, Raingler cargo net, AVS Window Shade deflectors, Heritage Grill with raptor lights Summer Wheels: Ryder RR03 matte gunmetal with Falken Wildpeaks 285/75/17 Winter Wheels: 18” KD Wheels with Blizzaks Rack is OEM - but changed to black with LFD crossbars Diode Dynamics Ss3 fogs
    Treaty Oak works with KDSS without having to drill any other holes or take off the front bumper like the Aprx?
  13. Mar 19, 2022 at 11:16 PM
    polyguy79
    LA County
    I have KDSS, no drilling and no bumper removal for installation. Just two very large screws that go into pretapped holes in the frame.
    donnermel[QUOTED] likes this.
  14. Mar 19, 2022 at 11:18 PM
    Any photos you could post?
  15. Mar 20, 2022 at 12:41 AM
    LA260
    LA260 New Member
    Wonder why they say soft shackles shouldn't be used with these ...
  16. Mar 20, 2022 at 7:29 AM
    afret
    North Idaho
    Sharp edges on the holes.
    donnermel and polyguy79 like this.
  17. Mar 20, 2022 at 8:06 AM
    polyguy79
    LA County
    The edges of the inside of the loop are 90 degrees, not rounded like a D ring
    LA260[QUOTED] likes this.
  18. Mar 20, 2022 at 10:27 AM
    polyguy79
    LA County
    Not much room to take a decent pic!
    DRobs and donnermel like this.
  19. Mar 20, 2022 at 11:03 AM
    I’ve done mechanical rigging for special effects and stunts for 25 years. I’ve seen hardware subjected to all kinds of high inertia abuse. I’ve never seen a properly rated steel shackle fail. I’ve seen them deform, but never fail.
    Has anyone here actually seen a rated screw pin anchor shackle fail?
    I’m not saying soft shackles don’t have their place. What I’m saying is that the decision to buy Treaty Oak recovery points shouldn’t be driven by whether or not they’ll take soft shackles.
    ashndirt, Trail Runnah, DRobs and 2 others like this.
  20. Mar 24, 2022 at 6:02 AM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    I'm stealing your Zip Tie idea. Smart!
    ashndirt likes this.
  21. Mar 24, 2022 at 7:17 AM
    polyguy79
    LA County
    Thanks! I know it won’t completely deter someone who is determined to take them, but if it thwarts the opportunist thief then I’ll be happy.
    DRobs[QUOTED] likes this.
  22. Mar 24, 2022 at 7:53 AM
    afret
    North Idaho
    There are some that have a type of lock and key to make them harder to steal:
  23. Mar 24, 2022 at 8:31 AM
    I keep mine in the vehicle until I need it. No sense in leaving it on and exposed to the weather and thieves.
  24. Mar 24, 2022 at 9:14 AM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    I like it because it will keep them from unscrewing. I check mine frequently for tightness.
