Spare tire question
Discussion in '5th Gen 4Runners (2010-2024)' started by 4runningMan, Aug 15, 2024.
  1. Aug 15, 2024 at 3:41 PM
    4runningMan
    4runningMan [OP] New Member
    New Mexico
    I have a flat tire. Gonna swap in the spare and take the other one to get fixed.
    Question- if my OEM spare Dunlap is like a half inch smaller diameter than the Michelins that are on the truck, can I still drive the truck around or could this cause a problem?
    Tire size is same on both tires. OEM size. I just suspect the Michelins could be a very slightly larger diameter.
  2. Aug 15, 2024 at 4:06 PM
    For short distances, you'll be fine. Your truck may pull a bit in the direction of the smaller tire, but that's it. It's totally safe.
  3. Aug 15, 2024 at 4:20 PM
    4runningMan
    New Mexico
  4. Aug 15, 2024 at 4:28 PM
    salvojimmy
    salvojimmy New Member
    Glen Allen VA
    2022 SR5P
    No Mods Yet
    You might want to check the date code on your spare. Depending on the brand mfg’s recommend replacement after so many years, regardless of mileage on the tire.
    4runningMan[OP] likes this.
  5. Aug 15, 2024 at 6:41 PM
    mac1usa
    mac1usa New Member
    Good time to spray some fluid film up there also while the spare is off and on the chain.
