So we bought our first 4Runner…
Discussion in '5th Gen 4Runners (2010-2024)' started by WillisFamily69, Jan 6, 2024.
  1. Jan 12, 2024 at 11:32 AM
    bronzestar1
    bronzestar1 New Member
    2023 Limited magnetic gray with redwood interior
    275/55-20s, Airaid CAI, Summit muffler, oil catch can
    Unless you're running a lot of boost, you don't have to mess with the internals, or the fuel pump, or the injectors, or...a positive-displacement style SC like the Magnuson builds boost from down low, while a centrifugal one like a Pro-Charger not so much down low.
    I ordered a throttle response controller to install on mine (Pedal Commander), and I think that will greatly improve its daily drivability. It's almost dangerous how slow the 4R is to get up to speed because of that throttle lag. I'm going to start in Sport mode (0 or 1, whichever is the lowest), and go from there. No Econ or Sport+ modes, so it'll be either some level of City or Sport.
  2. Jan 13, 2024 at 2:38 AM
    Newfy
    Newfy New Member
    Point Pleasant Beach, NJ
    2023 White TRD Pro
    Rust proofing and undercoating was my first thing to get along with a rubber cargo mat for the rear; other than that, probably vent shades and a hood protector and I'm good to go. I like it as it is, why mess with perfection?
    JS222STL likes this.
  3. Jan 13, 2024 at 10:41 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Like some have said, I'll reiterate: while it's so new, get the frame painted. I've read so many dudes on here who took rustproofing action at the best time, brand new. I did not :( !
    Big congratulations, 2024 is a heck of a machine
  4. Jan 13, 2024 at 10:48 AM
    Sin4R
    Sin4R New Member
    2024 Underground Limited
    Mall crawling kit.
    Please tell more. My understanding is that frame starts rusting from the inside. Can you even get the paint into these fold spots inside the frame?
  5. Jan 13, 2024 at 11:03 AM
    Yeah for sure, so when I say paint I mean straight up like rust paint the damn thing even (on the outside).
    The frame is painted but dudes have done it over. The rust that typically starts at the welds, body mounts, radiator support, below strut mounts, etc. will be prolonged for many more miles, even years.
    As for inside frame rails, absolutely yes rust starts there. I've began painting inside with nozzles, straws and wands. New Runners may have cavity wax applied, or maybe that's the new Tacos I'm thinking of. But at the very least, buy two Blaster Surface Shield or Fluid Film cans and spray inside as many frame holes as ya can. Inside my rails I've used black fluid film.
    Goodluck, and nice truck
    *Edit: almost forgot, if your region allows you access to a hose and unfrozen water. Rinse out your frame rails (like @McSpazatron) in the winter especially if salt used
    Sin4R[QUOTED] likes this.
  6. Jan 13, 2024 at 1:26 PM
    Too Stroked
    Too Stroked New Member
    Tom
    South shore of Lake Ontario
    2021 SR5 Premium
    Skip the paint and go straight to a corrosion inhibiting product. As many have said, Fluid Film or Woolwax are great options. Personally, I prefer Waxoyl. Whatever you do, do not use Ziebart.
    Sin4R[QUOTED] and djwantke like this.
  7. Jan 13, 2024 at 1:46 PM
    Not painting with actual paint, especially if it's new, but to spray it with a rust preventative such as fluid film, woolwax, or blaster shield. All of those are liquid and will seep into joints and cavities.
    I recently watched a YouTube video where somebody applied Fluid Film to a brand new truck, they had taken off all the plastic wheel well guards, fender flares, etc and sprayed into all the nooks and crannies. Very thorough job.
  8. Jan 13, 2024 at 8:55 PM
    Cowboy59
    Cowboy59 Enjoy the Adventure
    N. Florida
    Put a screen protector on the main console screen. They scratch easily and the screen looks sharper with the protector on.
    Welcome to a great forum.
    McSpazatron and Sin4R like this.
  9. Jan 13, 2024 at 11:37 PM
    Congrats and welcome.
    I would get it coated underneath to prevent rust and get some AT tires. That's it.
    LuLu likes this.
  10. Jan 14, 2024 at 12:48 AM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    Rustproofing as indicated by @ ChessGuy seems spot on.
    Since its now your Wife's gift... not yours.
    Why not let her drive it for a year and decide on what she would like upgraded.
    Just my 2c. No offence
  11. Jan 14, 2024 at 4:41 AM
    Too Stroked
    Tom
    2021 SR5 Premium
    Sin4R likes this.
  12. Jan 15, 2024 at 6:07 AM
    Sin4R
    Sin4R New Member
    Mall crawling kit.
  13. Jan 16, 2024 at 2:37 PM
    WillisFamily69
    WillisFamily69 [OP] New Member
    2024 ClS TRD OFP
    Wow, I did not expect such a large response. Thankyou all for taking the time out of your day to respond to such an open ended and whimsical question. I’ll be uploading pictures shortly, rest assured she is indeed a beauty. This level of response has been a boon to me, I’ve gone and made a list of all the upgrades I’m interested in. Rust inhibition/undercoating seems like a must, although on the back burner for a bit being that my Tacoma has been totally fine here on the eastern shore of Va. We don’t really salt the roads here but my wife does a lot of traveling with her girlfriends so maybe that will be something we look into eventually. As it would turn out, Northampton County has very little money to spend on Northampton County. Between the Cape Charles fire company and the Cheriton fire company, both of which I volunteer for; we received a gross total of 12k in county funding this year lol. That said, privateer snow plowing is big business here. The LED interior lights seems like a no brainer, I should’ve thought of that immediately duh. Although my experience in the electrical field is a constant party pooper when it comes to LED’s. 20% failure rate out of the box, but when they work; they look great. The screen protector is a must for my wife, she loves long fake nails and I’ve seen how her phone screen protectors hold up, that was a great suggestion. Also I must admit, I’ve always been pedal commander curious, but being that my daily is a 4banger 5sp, it never really made sense to play with. Wifey drives like a bat out of hell. Always has, probably always will. Might be worth looking into. As far as organization stuff goes, she is super type A so those are all great recommendations that I’ll be looking into. If anybody has any links to products they’re satisfied with, I’ll start there. Add on’s like first aid kits and basic survival tools are already covered, though I appreciate the thoughtful response regardless. My old man pounded the need for those things in my head as a child, we are all in agreement there. New tires however, are a must for me. I can’t believe how bad the Dunlops that came with it are, you’d think Toyota would at minimum take 500$ less profit off the top to make sure their trucks have decent rubber under them off the lot. She’s not going to be off-roading in this thing, and the taco is already setup to efficiently overland should the need arise. This truck is mainly a transportation device for our Great Dane and our eastern shore special. I figure some Michelin LTX’s will suffice for what she needs on the daily, but likely I will buy her a “winter set” of BFG’s just to keep in the garage and marvel at while I watch the hockey game, maybe throw on in the event of a terrible winter storm. Thankyou again for all the thoughtful and sage responses, this forum really does feel like a community of enthusiasts.
  14. Jan 16, 2024 at 2:43 PM
    bronzestar1
    She's going to be VERY disappointed with the acceleration of the 4R without some kind of throttle response gizmo...
  15. Jan 16, 2024 at 3:52 PM
    Photon_Chaser 49787 and counting…
    Sierra Nevada Mountains and the Central Coast
    Congratulations on your new purchase! I’m on my second 4Runner, my first one was a 3rd gen (2000 model year) Limited and the only reason I upgraded to a 2021 5th gen was because the 3rd gen was nearing ‘project’ status at over 350,000 miles and I really like having heated seats :D
    No joke these SUVs last with proper maintenance and you don’t drive it like a sports car, it really doesn’t need much in the way of mods other than what’s already been said about upgrading the factory supplied tires. Coming from a 3rd gen with its 3.4L engine I can honestly tell you that the +5th gen shines in many ways, acceleration is noticeably better and despite having a 4L engine and more than 1000 lbs added curb weight the 5th gen gets better gas mileage than my old 3rd gen, albeit not by much but still when you compare specs…
    The ride quality is way better (it feels more solid on the road than any of its predecessors most likely because of the added curb weight and tuned suspension straight from the factory. Your model year should be equipped with LED headlights and fogs so that part is taken care of. Depending upon which suspension package you have you might consider upgrading the factory shocks/springs if you are experiencing nose dive under moderate braking. Before I bought my 21 I test drove pretty much all of the 4Runner models and new I wouldn’t settle for less than the Fox suspension for that very simple reason. Of course the TRD Pro model that I ended up buying came with this setup but if I went with any other model (e.g. Trail or Offroad…) I would certainly have gone aftermarket (King, Bilstein, Eibach…)
    My old 4Runner was bone stock and served me well, ran the Sierra Trek (had winching help on a few gnarly boulder sections), tons of 3-5 class trails and just miles and miles of smiles. The ONLY issues I had with it was a blown spark plug (no engine damage!) and a failed alternator.
  16. Jan 16, 2024 at 4:21 PM
    To be honest, no way I’m hosing liquid water into the frame in winter. Too cold!
    I rinse the inside frame out well in the spring after things thaw out. You want to get the salt off once things start getting warmer, which is when oxidation/rust goes active. And usually after any off-road excursion that involves mud.
    I fully admit I a bit excessive with all this. But I’m doing it because the 4runner is generally quite durable and reliable for a long time, and it would suck if the frame is rotted away in 15 years, but the rest of the vehicle is perfectly serviceable.
    Also, I don’t paint inside the frame hollow areas. Use a cavity wax or fluid film or other wet film/non-drying rust protectant that can creep into all those sandwich weldments or other nooks. Use a wand to get it all in there, not just the straw on the can.
  17. Jan 20, 2024 at 3:36 PM
    @McSpazatron the region temperature is going to stay well above freezing for over a week. Salt used a lot on roads. I kinda wanna hose under the 4R lol what thinks you
    *Edit: 4r garage kept 24/7
  18. Jan 20, 2024 at 6:33 PM
    I’m crazy, but not that crazyZ. I’m too lazy to bring hoses inside for the winter, and even though I drain them out, there’s still chunky ice bits in there that clog them up. Not to mention all the joints/seals in the hose spools would leak. And I would have to dig them out of the snow they’re in. Nope.
    I’ll take it through a touchless carwash here and there.
  19. Jan 21, 2024 at 2:57 PM
    #49
    WillisFamily69
    2024 ClS TRD OFP
    You’d think that, but this is her only driving experience outside of mom sedans and my old man’s stupid lifted 2000’s suburban sitting on 33 bfgMT’s. You’d be amazed what a “few inches of lift”, lots of decent cup holders and a modern entertainment system can do for a lady. She’s very pleased with the machine, and the added reassurance of being able to crawl out of a nasty situation in a pinch seems to make her really happy. Her best friend has an 85 4R and it was so funny to see the two of them commiserate about their runners. She seems happy with it. However we will be doing a lot of traveling this year for weddings and funerals, which means I will be behind the wheel of this thing a lot. The acceleration sucks for sure, but I don’t have a lead foot anyway. I’m also quite pleased with it, minus the oil change procedure. I’ve always hated the oil filter housings that Toyota seems to love, I love my Tacoma’s spin on filter.
  20. Jan 21, 2024 at 2:59 PM
    #50
    WillisFamily69
    2024 ClS TRD OFP
    Pics of the newbie as promised.
  21. Jan 21, 2024 at 3:31 PM
    #51
    Beachguy
    2024 TRP ORP
