SMOKEYBEAR 2022 LR ORP
Discussion in '5th Gen 4Runners (2010-2024)' started by Spare Parts, Apr 3, 2022.
  1. Apr 3, 2022 at 6:22 PM
    Spare Parts
    Spare Parts [OP] New Member
    Southern Maine
    22 LR ORP
    Well, I expect to have an Off Road Premium in Lunar Rock, with Moonroof and all weather mats. Our plan is to set it up to travel cross country and take it off the beaten trail for some adventures. We will spend some time in the North Maine Woods as well. It will also be a daily driver, which is basically 20 miles typically. What do you think is needed?
  2. Apr 3, 2022 at 6:22 PM
    Spare Parts
    Southern Maine
    22 LR ORP
    Saved for projects.
    Plans
    full roof rack thinking Sherpa at the moment. Ordered 4-9-22 from Truck Brigade. Also picking up a set of awning brackets.
    https://sherpaequipmentco.com/products/crestone
    https://youtu.be/_2hRGO_yPOk
    roof top tent-hard shell, something that can carry kayaks
    suspension-wanted KDSS, but couldn’t get it. Will see what the weight is and only looking for a little lift, looking to improve road handling and increase off road abilities as possible.
    Winch/bumper- probably low profile.
    I like this look.
    Taken from https://trail4runner.com/2021/07/29/types-of-bumpers-hybrid-vs-low-profile-vs-full-plate/
    sliders?
    https://www.4xinnovations.com/2010--2022-4Runner-Bolt-On-Rock-Slider_p_157.html
    got wheels, about 10k miles on them.
    https://www.tacomaworld.com/threads/smokey-bear-2017-dcsb-v6-mt-mgm.458673/page-4#post-21705760
    When they were new.
    oil change stuff-valve, metal housing.
    https://trail4runner.com/2020/07/29/diy-low-profile-drawer-storage-5th-gen-4runner/
    communication-CB?
    on board air
    tech stream to switch between TPMS tires?
    Bob likes this.
  3. Apr 9, 2022 at 10:13 AM
    Spare Parts
    Southern Maine
    22 LR ORP
  4. Apr 9, 2022 at 11:27 AM
    nonuniform
    nonuniform New Member
    2021 TRD OR
    Depends on how off the beaten trail you want to go. Generally, I've found the stock 4R Off-Road to be fine for most dirt roads and the occasional rock staircase. Took it through Canyonlands on the west side of the river to camp on a ledge overlooking the Colorado. Have also taken it through Steele Pass in Death Valley - going North to South from Eureka Dunes to Saline Valley/Warm Springs. Only change I've made is to add K02 tires in the stock size. I may have touched down once or twice on the rocks in Steele Pass, so, an extra inch or so of clearance might have been nice, or full skid plates, but nothing damaged. Note, my stock JKU Rubicon went over Steele Pass multiple times and never touched a skid plate.
    But, I'm not carrying any extra weight except the Sherpa rack on top. If I were carrying a giant RTT and winch bumper, would probably want heavier duty springs/shocks.
    But then, once I start down that path, I'd want to swap UCA's, wider wheels and larger tires. 33" tires are sorta too inbetween, so, then I start thinking about 35's, and the mods start coming faster and more expensive. So, truck is stock.
  5. Apr 9, 2022 at 11:35 AM
    Congratulations. Good looking truck. Winch bumper. Sliders. Full length roof rack. AT tires. Sounds like you plan to go way off the beaten path, which is excellent! Are you going solo? I mean, without a second vehicle?
    Safety first. When traveling by car (and therefore less concerned with weight) I carry a nice fat first aid kit. Get some basic first aid training and build your kit yourself based on your personal knowledge. Other things: a fire extinguisher. A puncture repair kit and compressor. Cribbing for whatever jack you are using. Recovery gear. A SpotX or InReach or other 2-way satellite communicator. I have a Garmin GPSMap 66i with topo maps. It seems to have all the trails I’ve ever driven on it.
    What do you plan to put up on that rack? A roof top tent? Water and fuel? Jack and shovel? Recovery boards? Awning or E-Z Up canopy? Second spare tire? Are we talking weekend warrior or full expedition mode?
    Spare Parts[OP] and nonuniform like this.
  6. Apr 9, 2022 at 11:44 AM
    I feel your pain.
    [Dare I say it? For folks who know they’ll want 35’s there are better choices than the 4Runner.]
  7. Apr 9, 2022 at 11:50 AM
    nonuniform
    2021 TRD OR
    Ha! I almost put at the end of that message that if I wanted 35's on the 4R, I'd probably start looking at alternate vehicles. Putting 33's on there seems like a lot of $$$ for not a huge amount of benefit. I found the same to be true of my old JK Rubicon. Going to 33's required a lot of mods, but the Jeep already had nearly 10" of clearance. The 4R with 33's would get me close to the clearance on a stock JK.
    So, back to the point, which is, do what you like to your vehicle. I've left mine stock for now. Recovery gear, emergency kit and first aid kit are probably the best things to buy first.
  8. Apr 9, 2022 at 1:39 PM
    Spare Parts
    Southern Maine
    22 LR ORP
    I want to be able to operate solo, wilderness first aid in the 1900s, currently cpr cert through work.
    I don’t plan to build a rock climber, but I don want to be scared I’ll screw something up trying to get through a tough section. I would rather be safe than sorry.
    the wife already requested steps, so after I order the rack this weekend, I’ll start hunting sliders.
    I am not 100 percent on what will end up on the roof, RTT is very likely and that will determine what else fits. I have a small awning that will go up for now, but that will probably end up on the rav.
    Captain Spalding likes this.
  9. Apr 9, 2022 at 2:18 PM
    Matt83
    Matt83 New Member
    Northeast
    MSRP at Central Maine Toyota?
    Spare Parts[OP] likes this.
  10. Apr 9, 2022 at 2:20 PM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX4(Runner)60
    You can literally fit 33s on the 4R with no mods. It's tight, but they go.
    suaveflooder likes this.
  11. Apr 9, 2022 at 2:26 PM
    Spare Parts
    Southern Maine
    22 LR ORP
    YES, only charge state fee for title, so basicly no Doc fee. They played hard ball on my trade, I think I should have gotten more, I almost walked away.
  12. Apr 9, 2022 at 2:39 PM
    Do any caveats apply? Mind you, I’d be delighted if you were correct, but I’ve certainly read many attestations to the contrary and though there are dozens of threads on the topic a consensus remains elusive.
    Pentangler likes this.
  13. Apr 9, 2022 at 2:45 PM
    MeefZah
    Lexington, Ohio
    2020 GX4(Runner)60
    Always a caveat, but the oft quoted T4R.org tire fitter chart says 285/70 17 fit.
    Playndirty and GoSlow like this.
  14. Apr 9, 2022 at 2:47 PM
    Spare Parts
    Southern Maine
    22 LR ORP
  15. Apr 9, 2022 at 2:48 PM
    Great. Anyone who travels off the grid should have some first aid training.
    Many years ago I took an off-road driving course (on the Rubicon). The instructor specified that the point of the course was not to pit one’s vehicle against the trail, but rather to learn how to get from point A to point B, and then back to A. Which means not breaking anything. Safe is good especially when operating solo.
    A&P and Jackstraw like this.
  16. Apr 9, 2022 at 2:51 PM
    Spare Parts
    Southern Maine
    22 LR ORP
    Its only fair that I atleast post one of the Battle Wagon, it will be missed, but went to a good cause.
  17. Apr 9, 2022 at 2:56 PM
    Matt83
    Matt83 New Member
    Northeast
    Bought a Tacoma from them. Only dealer in the Northeast not charging a markup. The 4Runner gets North Woods duty though, great truck for the terrain. I have a stock truck except for Nitto Terra Grapplers. I air down to about 25 psi when in the woods and have never gotten stuck up there. Here are some pictures from my last trip in September.
    DSC_9738_39_40_41_42_Optimizer.jpg DSC_9705_6_7_8_9_Enhancer.jpg DSC_0046_47_48_49_50_Detailed.jpg
    Icetenka, Jere39, GrantA and 11 others like this.
  18. Apr 9, 2022 at 6:27 PM
    Spare Parts
    Southern Maine
    22 LR ORP
    Tried to get some night shots to show the color
    66ECEC6C-0404-4F96-A0DF-69B195DE87FD.jpg 5C59FD92-F83D-421E-BC88-3C4394C99BB7.jpg
  19. Apr 9, 2022 at 7:39 PM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    Rad. Id love to hop in my turd, and just drive. Anywhere. Just go. Have fun mate.
  20. Apr 10, 2022 at 1:18 PM
    nonuniform
    2021 TRD OR
    So, the 33's are on stock, suspension travel? How are 33's off-road with no mods? The people I've been with that had 33's on a stock 4R said they figured out pretty quickly they needed more mods to make the tires work off-road. Maybe they're wrong. I dunno. I'm always willing to learn something new!
  21. Apr 10, 2022 at 5:25 PM
    MeefZah
    Lexington, Ohio
    2020 GX4(Runner)60
    I can't answer that. I never tried.
    But there's a chart that lists fitment of popular sizes on stock suspension and it shows that smaller 33s fit without suspension mods... Only fender liner and mud flap mods.
    I assume legit off road use would still see rubbing under most circumstances just due to flex.
    polyguy79, GoSlow and Jackstraw like this.
  22. Apr 10, 2022 at 5:47 PM
    Literally no mods. That sounds pretty definitive.
    Perhaps you misspoke when you said “no mods.”
    Mass4runner likes this.
  23. Apr 10, 2022 at 7:00 PM
    MeefZah
    Lexington, Ohio
    2020 GX4(Runner)60
    Yeah, you got me, I guess I did; though to be fair shoving a fender liner 1" forward or unbolting a mudflap is hardly the equivalent of adding a suspension lift. I wouldn't really rate those as mods, more like adjustments, but we can mince words all day I guess...
    yotaloma, Singleminded and A&P like this.
  24. Apr 11, 2022 at 10:31 AM
    nonuniform
    2021 TRD OR
    I think it all depends on what you want to do with the vehicle.
    Drive on pavement, just like the look of bigger tires: 285's fit.
    Drive off pavement, need more clearance: 285's are a waste of time and effort.
    Again, my understanding comes from people I've driven offroad with that have shared their actual experiences, not armchair offroaders that have not tested a given solution.
  25. Apr 11, 2022 at 10:40 AM
    MeefZah
    Lexington, Ohio
    2020 GX4(Runner)60
    In this scenario am I the armchair offroader?
  26. Apr 11, 2022 at 11:38 AM
    Jackstraw
    Jackstraw New Member
    Matt
    2018 Pro Trickie Woo
    Congrats on your new rig - she looks sharp!
  27. Apr 11, 2022 at 11:42 AM
    RonRunner
    RonRunner New Member
    Is that a joke?? If you were worried about $500 and them listing it for $999 more than they told you, sell it on your own. How would it make sense to bash them, after you tell us they are good, because they listed their car for more that what they told you lol. You realize they have to try and make a profit off of it as well right?
  28. Apr 11, 2022 at 12:30 PM
    Spare Parts
    Southern Maine
    22 LR ORP
    Well during the negotiations they used it as a selling point. I was lied to. I am telling it like it is. They said they couldn’t give me any more because it was going to be listed at 33k
    Edit: to add to the story, I ended up less than what I was told my truck would get at auction. I could have sold it for more last Thursday, but thought I’d get something comparable in a trade offer, I was wrong.
  29. Apr 11, 2022 at 1:00 PM
    Spare Parts
    Southern Maine
    22 LR ORP
    Lights?
    I am thinking that I’d like to change out the rear hatch lights, to either red or green. The thinking is those colors won’t attract as many bugs, easier in the eyes and night vision. I may even change up the interior front light as well.
    but, I’m not sure where to start with this project?
    https://trail4runner.com/2018/01/13/dome-lights-5th-gen-4runner/
  30. Apr 11, 2022 at 4:47 PM
    Matt83
    Matt83 New Member
    Northeast
    Diode Dynamics has a range of various intensity LED Lights for the Interior. Fast/Free Shipping too. Have them in my 4Runner and Tacoma.
