Slow Fuel Fill Rate?
Discussion in '5th Gen 4Runners (2010-2024)' started by J31Bodie, Jul 23, 2024.
  1. Jul 23, 2024 at 1:50 PM
    J31Bodie
    J31Bodie [OP] New Member
    2023 Silver 4Runner SR5
    Having a great time with my new 2023 T4R SR5, but I'm kinda curious -- when I fill it up, I have to fill it very slowly. If I just put the nozzle in the gas tank entrance and crank it, the flow very quickly backs up and stops. Even on half-speed it stops. I have to sit and hold it at quarter-speed in order to fill up. Anybody having that problem? Here's the view down the tank, does this look different/wrong?
  2. Jul 23, 2024 at 1:52 PM
    Does it do the same at different pumps at other stations? Sometimes certain pumps are very finicky.
  3. Jul 23, 2024 at 1:53 PM
    Lost Woods
    Lost Woods New Member
    2024 SR5P
    If it's not the pump, it's an obstruction or failure in the evap system. There's a vent tube that allows air up into the filler neck and when the level is high enough to cut off airflow to the vent, it seals it off and the resulting backpressure shuts off the pump. It's usually a bad valve but it'll need to be looked at.
    CIDD, jgalt and J31Bodie[OP] like this.
  4. Jul 23, 2024 at 2:06 PM
    J31Bodie
    So far it's been all three pumps I've tried. Not a huge representative sample, I know...
    djwantke likes this.
  5. Jul 23, 2024 at 2:06 PM
    J31Bodie
    Ah, okay. Well this vehicle is Gold certified, so I'll get it over to the dealership and have them deal with it. Thanks for the info, I appreciate it!
  6. Jul 23, 2024 at 2:08 PM
    Something may be wrong as @Lost Woods stated above then. Mine will shut off right away on certain pumps once in a while, but only at first, and if I reposition the pump nozzle, it takes care of it...
    Slopemaster likes this.
  7. Jul 23, 2024 at 2:11 PM
    3JOH22A Toyota Gigolo
    That's most often an evap system problem, maybe a vent valve stuck closed.
  8. Jul 23, 2024 at 2:19 PM
    Emmantik
    Emmantik New Member
    Coquitlam, British Columbia
    2015 Magnetic Grey SR5P
    What is the white piece in the center? Mine does not have it. Maybe something added to newer models? Mine is a 2015. Pic for reference;
  9. Jul 23, 2024 at 2:54 PM
    Lost Woods
    2024 SR5P
    This or a defective/saturated canister were the usual issues when I did smog diagnostics. The valve fails closed on most and doesn't allow for proper venting so it acts like the tank is full all the time.
    djwantke and J31Bodie[OP] like this.
  10. Jul 23, 2024 at 4:11 PM
    J31Bodie
    That doesn't sound promising. I'm glad I have the warranty!
  11. Jul 23, 2024 at 5:07 PM
    Saker New Member
    21 Black T4RORP
    As stated below on others, mine does not have that white plastic piece in it.
    Can you grab that metal ring and remove that plastic piece? Thats your restriction.
  12. Jul 23, 2024 at 5:10 PM
    3JOH22A and Saker like this.
  13. Jul 23, 2024 at 8:15 PM
    LVYOTA89
    LVYOTA89 New Member
    I have noticed the same thing on my new to me 2023. Pump shuts off way before tank is full. I had to pump a lot slower. It happened on my first fill, second fill was fine, then happened again on my third fill.
  14. Jul 23, 2024 at 9:25 PM
    Yamahamer
    Yamahamer New Member
    Nevada
    2022 4Runner Off Road
    Have you been overfilling your tank? Keep activating the nozzle several times after it first clicks off, to get the tank really really full? If so, you probably saturated the charcoal canister with gasoline so it no longer vents fumes, causing pressure to build in the tank and the nozzle to pop off prematurely now.
    Startrek likes this.
  15. Jul 24, 2024 at 5:11 AM
    Grandpawmoses
    Grandpawmoses Dirty Old Man
    David
    2024 4R TRD Pro
    Too poor to buy anything now
    I had noticed the white plastic piece on mine before. I don't have any filling issue and just thought it was some static electricity insulator to prevent a spark.
    2Toys likes this.
  16. Jul 24, 2024 at 7:29 AM
    Startrek
    Startrek New Member
    this.
  17. Jul 24, 2024 at 4:37 PM
    TrailSpecial22 New Member
    PA
    take that plastic piece out. Mine doesnt have that and I dont have filling issues
    J31Bodie[QUOTED][OP] and Saker like this.
  18. Jul 25, 2024 at 9:07 AM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    That's an interesting idea.
    J31Bodie[OP] likes this.
  19. Jul 25, 2024 at 9:18 AM
    J31Bodie
    I'm hesitant to take out a stock part, as most all of them are there for a reason. Dealership is gonna sort it out tomorrow morning, so I'm looking for a read from them first. I'm gonna laugh if they fix it by pulling out that part though... :D
    TrailSpecial22[QUOTED] and 2Toys like this.
  20. Jul 26, 2024 at 12:06 PM
    J31Bodie
    Update for the Mildly Curious: Turns out it's a faulty rollover valve sensor in the base of the filler tube. Designed to engage in the event of a rollover accident and prevent (or greatly slow) the loss of fuel through the filler tube. Covered by the emissions warranty (which I didn't know it had), but apparently they have to get the parts from Mars or so, because it's gonna take a week to get them. Works for me.
    By the way, the white plastic thingie (pretty sure that's the technical name for it) in the opening of the tube is there to provide a better purchase on the gas nozzle, as well as frustrate those trying to put the wrong fuel into their vehicles. It's supposed to be there, apparently. Go figure.
  21. Jul 26, 2024 at 12:18 PM
    Saker New Member
    21 Black T4RORP
    Well, go freeking figure!
    There are far too many things introduced by the govt and auto makers to provide unwanted protection from world events, such as rolling our vehicles over.
    And now they are placing white plastic thingies so we can place the gas nozzle EXACTLY where it needs to be to introduce fuel into the filler tube. I don't remember needing any such apparatus to help me guide any of my nozzles into the proper hole for filling!.... did I really say that? :dancingbacon:
    I guess 2023 has become the age of unawareness!
  22. Jul 26, 2024 at 12:32 PM
    J31Bodie
    LOL! Can't argue that. But say that quietly... pretty sure your 4Runner heard that and it's probably already in Toyota's hands by now... :spy:
    Saker[QUOTED] likes this.
  23. Jul 26, 2024 at 3:09 PM
    Glad to hear they found a solution. I see regular fill up adventures awaiting you in the near future!
  24. Jul 26, 2024 at 7:25 PM
    PA
    strange they put that on your 2023 but not on my 2022
    J31Bodie[QUOTED][OP] likes this.
  25. Jul 26, 2024 at 9:14 PM
    J31Bodie
    Oh wow, it's not on the 2023? Makes me wonder what was happening that made them think to add it.
    Anybody else have one on a previous model year?
  26. Jul 26, 2024 at 9:20 PM
    J31Bodie
    Another update: my brother-in-law is a recently retired body work expert. He says that plastic insert is also there to cut down on the fumes and possible overspray that can result from filling the tank. Said it was an emissions-oriented thing that was possibly mandated by one or more states for their emissions requirements? I'd think all cars after a certain time would have something similar if that were the case...
  27. Jul 29, 2024 at 6:30 AM
    J31Bodie
    Sooo, dealership update: The problem is a faulty rollover valve sensor. Apparently these have a sensor that picks up when your 4Runner has rolled over, and automatically shuts down the filler tube so gas can't leak out of it. Very thoughtful. However, sometimes the sensor goes bad, and it leaves the valve in a state where it will take on some gas from the tube, but won't let anything go back out. The result? A new gas tank for me. Apparently the whole thing is a sealed unit. It's covered under the emissions warranty that I didn't know I had. Anyway, should have it fixed next week.
  28. Jul 29, 2024 at 8:01 AM
    2Toys
    Gordon
    2019 4Runner TRDORP
    I wonder what year they started putting those rollover sensors in. Would be good to know for future troubleshooting purposes.
    BS67, Saker and J31Bodie[QUOTED][OP] like this.
  29. Jul 29, 2024 at 8:50 AM
    J31Bodie
    Excellent question. I'll see if the service guys know the answer and will post what I get on here.
    2Toys[QUOTED] likes this.
  30. Jul 29, 2024 at 8:57 AM
    Saker New Member
    21 Black T4RORP
    I wonder if this becomes an issue widespread will the tanks be retrofitted to previous year tanks and eliminate those sensors.
    J31Bodie[OP] and 2Toys like this.
