Skid plate removal question
Discussion in '5th Gen 4Runners (2010-2024)' started by Ron Gusack, Feb 11, 2019.
  1. Feb 11, 2019 at 8:58 AM
    Ron Gusack
    Ron Gusack [OP] New Member
    I have a 2015 SR5 that will never see an off road trail. Is there a reason to keep the skid plate attached that covers the oil filter? I don't like dealing with it to get to the filter and I'm thinking about cutting a hole in it so I can remove the filter without taking it off.
  2. Feb 11, 2019 at 9:15 AM
    4X4Runner
    The left coast
    Road debri. Never know when something will fall off a truck ahead of you.
    My drive in this am there was sections of metal AC ducting strewn about that people were dodging.
  3. Feb 11, 2019 at 9:21 AM
    Oey12
    Oey12 New Member
    Joey`
    2017 SR5
    Eibach Pro Sport leveling shocks, Firestone airbags, and Baja Design fog lights...
    In all honesty I believe Toyota put it there for a reason so I always put mine back on. Yes it does take a little extra time and work un and re installing it, especially when I add anti-seize to every bolt, but worth the headaches for the extra level of protection. My BIL has the same exact 4Runner as I do and he has taken it off permanently without any issues. I am not sure about cutting a hole in it...I don't know of anyone who did.
  4. Feb 11, 2019 at 9:24 AM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    2004 SR5 V6 4WD 4Runner
    Like @4X4Runner said it’s protection from road debris. I would leave it in place.
    WallyT4R and SlvrSlug like this.
  5. Feb 12, 2019 at 10:23 AM
    poncho65
    poncho65 New Member
    New England
    In addition to road debris, as others have mentioned, you'd be surprised how much cleaner your engine bay will be with the skid installed. I ran my 4th gen around for awhile with the front skid removed.....I noticed a significant increase in the amount of water and dirt that got (higher) into my engine bay. Ur skid may be a PIA to deal with, but it will keep your engine bay cleaner!
  6. Feb 12, 2019 at 11:20 AM
    ManBeast
    ManBeast New Member
    Zach
    Jax FL
    2014 TRAIL
    Perhaps take it to a fab shop and have them make a oil filter door similar to the drain plug door.
  7. Feb 12, 2019 at 3:06 PM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    if you do not go off road and it is a bit on the high side not a problem to remove it.
    so why is this NOW on all vehicles a cover under the engine bay ?????????????
    it is about air flow .. if you purchased a sport car ya it will also have a cover to reduce resistance of the vehicle .
    the bottom of the engine area will have less mess be much cleaner with the covers.
    when I do the oil servicing/grease / leak checks the all covers come off .. keep off for a few days check for any leaks then put back on..
    I also spray paint safe silicone on all the rubber bushings ..
  8. Feb 12, 2019 at 3:38 PM
    Ron Gusack
    I was planning to make it like the drain plug cover but thought maybe lots of owners take them off without any issues.
    ManBeast[QUOTED] likes this.
  9. Feb 12, 2019 at 5:06 PM
    ManBeast
    ManBeast New Member
    Zach
    Jax FL
    2014 TRAIL
    Maybe just take an angle grinder and make a hole where it is and rattle can so you still protect the rest of the stuff down yonder
    HoBoDanny likes this.
  10. Feb 12, 2019 at 5:40 PM
    Ron Gusack
    Just leaving that area open is a thought but it might be pretty easy to make it a bolt in section. I'm sorta surprised that there isn't an aftermarket plate with that feature incorporated in. I guess they think there's not enough market for something like that. To be honest, I haven't looked very hard for aftermarket skid plates.
  11. Feb 12, 2019 at 5:43 PM
    4X4Runner
    The left coast
    I’m reality, how many people actually do their own maint on their vehicles? I can tell you, in an office of about 30 people I am the only person who has any practical knowledge of vehicles and does their own maint. Everyone else relies on the dealer or some quick lube place.
    I guess, is it worth engineering something like that for the very small percentage of people who do their own maint?
    WallyT4R likes this.
  12. Feb 13, 2019 at 4:10 AM
    ManBeast
    ManBeast New Member
    Zach
    Jax FL
    2014 TRAIL
    Im aure the maint shops would appriciate it
  13. Feb 13, 2019 at 7:10 AM
    j cat
    j cat New Member
    massachusetts
    just cut a hole to your liking and its done .
  14. Feb 13, 2019 at 8:13 AM
    WallyT4R
    WallyT4R New Member
    Or just deal with it and leave it alone. It's not hard to simply remove the skid every 10,000 miles. It's really not a problem is it? Every 10,000 miles?
  15. Feb 13, 2019 at 8:42 AM
    Agent_Outside
    Built 2011 T4R Limited
    Yes there are aftermaket skids with bolt in sections to do oil changes without skid removal.
    ManBeast likes this.
  16. Feb 14, 2019 at 9:00 AM
    WallyT4R
    WallyT4R New Member
    RCI
