Skid Plate Rattle
Discussion in '4th Gen 4Runners (2003-2009)' started by Huntdawson, Mar 28, 2021.
  1. Mar 28, 2021 at 5:52 PM
    Huntdawson
    Huntdawson [OP] New Member
    Hunter
    2006 Toyota 4Runner
    I recently bought a 2006 Toyota 4Runner. When I go over bumps there’s a significant metal rattle coming from underneath. I got underneath and started banging around and the only thing that rattles is my skid plate. It’s more of a vibration. I checked all the bolts everything’s tights. I was wondering if anyone had any advice on how to eliminate the the vibration.
  2. Mar 28, 2021 at 8:11 PM
    Welcome to the forum, did you check to make sure nothing is laying on top of the skid? Just a thought.
  3. Mar 28, 2021 at 8:58 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    If it's a vibration? That plate or something else under there is making contact with something it shouldn't be. Which means you need to spend some time with a flashlight scoping things out. Think safe/be safe if you're under there with the engine running.
  4. Apr 1, 2021 at 6:54 AM
    4R777
    4R777 New Member
    I had same problem. It was a loose bolt that was rusted. Had to drill out the bolt, then use tap set to create new threads in the hole. Ended up doing several bolts while I was down there. Now she is tight again and no rattle. I used a cheap tap-and-die set from Irwin Hansen off Amazon, along with some cutting fluid, and it worked like a charm. Go slow and be methodical.
