Single click when starting to drive after starting car
Discussion in '5th Gen 4Runners (2010-2024)' started by Msrponly, Sep 7, 2021.
  1. Sep 7, 2021 at 11:34 PM
    Msrponly
    Msrponly [OP] New Member
    Anyone hear a single click when they start to drive after turning on car? Happens exactly at 4mph. Rav4 and other models say abs self check happens at 4 mph..but I couldn't find anything for 4runners...
    4wheelforlife likes this.
  2. Sep 8, 2021 at 8:17 AM
    natekam
    natekam New Member
    2021 Nightshade Gray
    I am very glad you asked this question because I thought I was hearing things. Yes I hear a click and then something that sounds like a valve release...its very slight and it seems to me that its coming from the rear.
  3. Sep 8, 2021 at 9:28 AM
    interceptor
    interceptor Crash Test Dummy
    '21 ABM Venture
    Noticed this also. Can't find the thread, however per that thread, the noise is coming from a relay that is associated with the anti-lock brake system and/or the electrics associated with the brakes near the firewall and/or under the dash. I'll set a reminder to ask about it when I go by the dealership tomorrow and post-up what they say.
    Update: Found the thread..
  4. Sep 8, 2021 at 10:04 AM
    taco_runner
    taco_runner New Member
    Kev
    4Runner TRD OR Premium
    does the sound come from under the steering wheel and sounds springy?
  5. Sep 8, 2021 at 10:16 AM
    This is different the evap noise is in the rear after its been sitting.
    My 2019 Tundra does this at 4-5mph everytime when fist moving after start up. All the Tundra guys say its normal ABS check. I'm going to assume the newer 4Rs have this I just wish it wasn't so loud.
    natekam likes this.
  6. Sep 8, 2021 at 11:24 AM
    Msrponly
    Yes exactly this. Exactly at 4 mph after car start everytime.
  7. Sep 8, 2021 at 11:25 AM
    Msrponly
    But the click sound is from the front right? And thr valve is from the rear. Correct?
  8. Sep 8, 2021 at 11:28 AM
    Mine has always made a funky sound from the dash area when I first put it in gear from park.
    Kinda like a spring release sound.
  9. Sep 8, 2021 at 11:29 AM
    Msrponly
    Put it into gear or when you first start driving?
  10. Sep 8, 2021 at 11:33 AM
    MattO2786
    MattO2786 New Member
    Cleveland, OH
    Former 18 OR and 18 Limited Owner
    I’ve had two 18 T4R, one an OR and the other a Limited. Both do it. It’s normal.
    JS222STL and Msrponly[OP] like this.
  11. Sep 8, 2021 at 12:16 PM
    taco_runner
    Kev
    I asked the same question here a few months back. It has gotten louder... I went to the dealership to have them check. They said it was normal, so I asked to drive a similar vehicle... and yes, the sound was there, but mine is louder.... I have videos here I think, i will try to find them and post here..
    Edit:
    here is my thread with videos:
    https://www.4runners.com/threads/weird-sound-coming-from-under-the-steering-wheel-left-side.18747/
  12. Sep 8, 2021 at 12:24 PM
    BeavertonCommuter
    BeavertonCommuter New Member
    Mine does. As soon as I pull out of the drive way I get this noise down in the driver's footwell...every time.
  13. Sep 8, 2021 at 12:25 PM
    taco_runner
    Kev
    look at my post just above your post...
  14. Sep 8, 2021 at 12:26 PM
    BeavertonCommuter
    I did after I posted and couldnt quite hear the sound in your vids. Ill try again.
    EDIT - Yes, basically the same sound.
    taco_runner[QUOTED] likes this.
  15. Sep 8, 2021 at 1:02 PM
    Now that you mention it, I don't remember. Next time I drive it, I will make note and post, if this thread isn't buried by then. ;)
  16. Sep 8, 2021 at 1:27 PM
    hou924
    hou924 New Member
    Same noise in my 2020. I even took it to the dealer. It is the ABS. Part of the charm of the 4Runner. That and the clack when shutting down.
  17. Sep 8, 2021 at 1:36 PM
    While we're talking strange noises, I noticed that when I place the shifter in park, the cog? that engages/locks the transmission in park kinda settles in. You can hear and feel it engage, like it has more play or tolerance than other cars.
    This is parking on flat ground.
  18. Sep 8, 2021 at 1:41 PM
    thermorex
    thermorex New Member
    Name Redacted
    Swamp area
    2021 4Runner TRD PRO
    I believe it is the brake assist motor pressuring the hydraulic cylinder. I found that out when researching why this vehicle has no vacuum brake booster... 4Runners are one of a kind, lol...
  19. Sep 8, 2021 at 2:19 PM
    That makes sense.
  20. Sep 8, 2021 at 3:23 PM
    taco_runner
    Kev
    I also have this, and the vehicle slightly moves...
  21. Sep 8, 2021 at 3:32 PM
    Yes, exactly!
    I think it's ok? But the transmission park cog is much more noticeable than other vehicles I have driven.
    Having said that, this is the first automatic transmission I have owned in the last 21 years with the exception of the wife's Sequoia which I hardly ever touch.
  22. Sep 8, 2021 at 8:44 PM
    Msrponly
    Wow great job test driving other ones and confirming the sound. May I ask how much softer were the new vehicles compared to your sound? I don't think it matters at all tbh, but just curious. If there were a problem the abs light would be on.
  23. Sep 9, 2021 at 4:44 AM
    doxidad
    doxidad New Member
    Tom
    NE Ohio
    2024 TRD ORP Ice Cap w/KDSS
    Hmm... I always thought the sound was the doors locking.
  24. Sep 9, 2021 at 6:51 AM
    Tried this morning, that springy click sound from behind the dash happens once I put the car in "D" drive and moved forward from backing out of the garage.
    taco_runner likes this.
  25. Sep 9, 2021 at 1:41 PM
    taco_runner
    Kev
    Mine was twice as loud than the one I test drove. I remember hearing that softer sound when my runner was new. The one I drove is a new vehicle form the lot.
  26. Sep 9, 2021 at 5:42 PM
    Msrponly
    Yup sounds normal then, like everyone in this thread has confirmed.
    Rocko9999 likes this.
  27. Feb 22, 2024 at 5:22 PM
    John4x4
    John4x4 New Member
    Michigan
    4Runner
    None
    It's a 4runner, the moment it stops making noise is the time to be concerned.
    3JOH22A likes this.
  28. Feb 23, 2024 at 12:31 PM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    They all do it. Normal.
  29. Feb 23, 2024 at 5:10 PM
    Cajunchuck
    Cajunchuck New Member
    Arkansas, USA
    2023 TRD ORP
    Mine does it every time at 4 MPH from a start. Forward OR reverse.
  30. Feb 23, 2024 at 5:18 PM
    3JOH22A Toyota Gigolo
    Yep, the latest version of the ABS unit has an MSRP of $1400 :stirthepot:
