Sidelight not illuminating when sidelights are on
Discussion in '5th Gen 4Runners (2010-2024)' started by HellYeahBrother, Jun 29, 2024.
  1. Jun 29, 2024 at 8:28 PM
    HellYeahBrother
    HellYeahBrother [OP] New Member
    2021 SR5
    Hello!
    Not sure if “sidelight” is the correct term. It is in between the daytime running lights and full on headlights. The blinkers illuminate.
    Well, on my 4Runner, the right blinker does not turn on only when sidelight is selected. It turns on with headlights and the blinker works.
    Im thinking a fuse.
    Any ideas?
    Thank you!
    EDIT: Thanks everyone for the ideas. Upon checking again, I realized I had it backwards. The right blinker does not illuminate when the HEADLIGHTS are on, but still functions as a blinker.
  2. Jun 29, 2024 at 8:29 PM
    T in Texas
    T in Texas New Member
    FEMA Region 6
    2024 Terra TRD Pro Terra - finally got it
    if it was a fuse, both sides would be out
  3. Jun 29, 2024 at 8:32 PM
    HellYeahBrother
    2021 SR5
    I was definitely hoping it would be easy but I guess not!
  4. Jun 29, 2024 at 8:39 PM
    Are you referring to the turn signal light(s)? It sounds like you have a dead bulb. I changed mine out because they're a sorry ass 5 watt halogen bulb. I bought an LED switch back.
    Stock bulb:
    Aftermarket LED:
  5. Jun 29, 2024 at 8:39 PM
    T in Texas
    FEMA Region 6
    could just be a bulb...thats pretty easy
    in my 2011 Toyota the left DRL didn't come on...
    new bulb fixed it
    have you recently installed 常闭 brand fang lights from Amazon?
  6. Jun 29, 2024 at 9:05 PM
    HellYeahBrother
    2021 SR5
    Nope, I haven’t changed the lighting at all.
    You think the bulb would be bad if it comes on with the headlights and the blinker works?
  7. Jun 29, 2024 at 9:06 PM
    HellYeahBrother
    2021 SR5
    Yes, the turn signal light. It is on when headlights are on and the blinker works just fine, but it does not come on when the sidelights are on (the option between DRL and headlights (is it called sidelights?))
  8. Jun 29, 2024 at 9:09 PM
    T in Texas
    FEMA Region 6
    you mean the 'running lights?'
    aka, marker lights?
    I have not had my 2024 apart yet, so not sure if they are different bulbs for running lights and turn signal...
    @Borracho Loco any ideas?
  9. Jun 29, 2024 at 9:12 PM
    The DRL are different from the blinker/side marker (see my post above that shows the blinker light).
    I'm kind of confused why his blinker comes on normally, but the bulb won't stay illuminated when the stalk is set to "side lights". I'd just replace the bulb, because it's a halogen, with an LED.
    This is how bright mine is after I upgraded:
  10. Jun 29, 2024 at 9:17 PM
    HellYeahBrother
    2021 SR5
    I have been leaning that way, going full LED inside and out, but I really want to make sure it isn’t an electrical issue or a fuse/relay before I go start spending money to fix an issue I didn’t have.
    Super cool though! I’m all about bright turn signals. I want people in the next state to see me turning haha
  11. Jun 29, 2024 at 9:32 PM
    A quick way to check is to swap the bulbs. Put the left one in the right, and the right in the left one. Then test. If the problem stays the same, you have an electrical or fuse problem. If the problem follows the bulb, then you have a faulty or bad bulb.
  12. Jun 30, 2024 at 5:58 AM
    HellYeahBrother
    2021 SR5
    I like it.
    How easy is it to open that bulb up?
  13. Jun 30, 2024 at 6:02 AM
    It's not hard. But when you remove the wheel well liner, you're going in blind to pop out the bulb. Don't worry, you can "feel" it click out (and back in).
  14. Jun 30, 2024 at 9:22 AM
    HellYeahBrother
    2021 SR5
    Okay so I had it backwards. The blinker light does not turn on when the headlights are on, but still functions as a turn signal.
  15. Jun 30, 2024 at 9:25 AM
    It is suppose to come on, when you have the head lights on. That means something is (possibly) wrong with the bulb.
