Shift points
Discussion in '5th Gen 4Runners (2010-2024)' started by chadp82, Jun 1, 2022.
  1. Jun 1, 2022 at 4:50 AM
    chadp82
    chadp82 [OP] New Member
    2021 TRD Pro Premium
    This is our first Toyota and we took the 4R on a road trip this weekend. 2021 ORP 4Runner.
    I noticed that the shift points seemed somewhat abrupt at times. We were traveling through the mountains and had fairly large elevation changes.
    I have experiences with past vehicles that when making this same drive I have these abrupt shifts when changing altitude rapidly. Is this normal with Toyota also?
    It was nothing concerning, just curious ….
  2. Jun 1, 2022 at 5:00 AM
    Jere39
    Jere39 Rattlesnake Trail - Sproul SF
    Sky Island, PA
    2022 4Runner SR5 MGM
    I just came back from a trip to our mountain cabin with a fairly heavy load of tools and camp food. Most of the elevation change happens in the last hour of this drive, and on pretty windy roads. Due to the road conditions, there were plenty of down shifts as I navigated the switch-backs. But, I would not have described any of them as abrupt. I know, that is a pretty subjective evaluation. I've made this trip for several years in prior Tacoma's, the last being a 2018 automatic, and felt it handled the turns and elevation change very similarly. I often am pulling a utility trailer with a couple Dual Sport motorcycles, though I haven't done that yet with my 4Runner. On the Tacoma's there are even more shifts, though again, none are what I would call abrupt. I hope to get back up pulling that trailer with the 4Runner soon. Several years I was making the trip with a manual transmission 2.7l Tacoma - now there was some shifting. Good luck with your 4Runner.
  3. Jun 1, 2022 at 8:51 AM
    Emmantik
    Emmantik New Member
    Coquitlam, British Columbia
    2015 Magnetic Grey SR5P
    Sounds like 'downhill assist'. When going down steep/steeper hills, and you step on the brake, it activates downhill assist.
    For going up and down hills, I like to shift into 'S' mode. Keeps it in the chosen gear which reduces unwanted gear hunting.
    chadp82[OP] likes this.
  4. Jun 1, 2022 at 9:22 AM
    Altitude4x4
    Altitude4x4 New Member
    2019 Voodoo Blue TRD Pro
    My truck holds gears and "hunts" when traveling up steep grades, that's normal for these trucks as far as I know. Added weight and any wind resistance will exacerbate the feeling. The abrupt shifting you're mentioning may just be the minimum RPM needed to change gears, mine does that occasionally as well.
  5. Jun 1, 2022 at 10:26 AM
    TrailGuy2016
    TrailGuy2016 New Member
    2016 Trail Premium, Silver
    It's part of the charm!
    It's alarming for certain, but I've gotten used to it. I actually get a sore right leg when driving out West through elevations because I'm trying to feather the throttle so that it doesn't kick down 17 times when going up a 1-degree incline.......part of the deal. Uptown 1st world problems.
  6. Jun 1, 2022 at 11:32 AM
    chadp82
    I appreciate the feedback.
    again, I have had other vehicles behave similarly so wasn’t concerned. On those, and probably similar with the Toyota, it was mainly when there were rapid changes in altitude.
  7. Jun 2, 2022 at 8:57 AM
    TrailGuy2016
    If mine even sees a slight increase, it pretty much immediately kicks down at least once, and then if I do nothing on cruise, it will kick down again and scream at 3500rpm's for however long is needed.
    Sometimes downhill runs kick down also and I have to engage to make it better.
    Like I said, part of a 5th gen....
    chadp82[QUOTED][OP] likes this.
