Shift Knob Won't Twist Off
Discussion in '5th Gen 4Runners (2010-2024)' started by Colorado 4RNR, May 20, 2023.
  1. May 20, 2023 at 10:26 PM
    Colorado 4RNR
    Colorado 4RNR [OP] New Member
    Alex
    2021 Toyota 4Runner TRD
    I am having issues removing the shift knob, when I try to twist it it becomes loose and slides off the shift rod but I can't remove as it hits something and just wobbles of the rod not letting me twist off the actual knob off.
    Is it possible that the inner thread or lock was broken previously? I have a 2021 4runner TRD. If so any suggestion on how to remove the knob? I will take it to the dealership eventually but want to get some thoughts.
  2. May 21, 2023 at 9:24 AM
    MAXIM
    MAXIM New Member
    There should be no issue with this. Rod has a plain tread and knob even if it has sleeve should just twist off. Turn counter clockwise, it doesn't require much force unless some one put tread locker on it during installation. Give it hell, don't be shy - Lefty/Loosey.
    alittleoff likes this.
  3. May 21, 2023 at 9:54 AM
    Ironguy New Member
  4. May 21, 2023 at 2:34 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Is there a hidden hex set screw, maybe even under plastic if not visible like mine
    Goodluck
  5. May 21, 2023 at 2:55 PM
    Saker New Member
    21 Black T4RORP
    No hidden setscrew on any OEM shift knobs.
    djwantke likes this.
  6. May 21, 2023 at 4:31 PM
    Why are you removing the shifter?
  7. May 21, 2023 at 9:57 PM
    From my experience, I believe the oem shift knob has a plastic threaded insert inside that can break free or strip with enough twisting motion. I ordered an oem TRD shifter from Toyota, and when I installed it, it didn't seem tight enough, so I turned it a bit more, still not tight. I decided to take it off, and it just spun like you're describing. I was finally able to remove it by pulling up as hard as I could while turning it...needless to say, I didn't keep that knob.
    As said above, maybe someone used thread locker, and that insert came loose when you tried to remove the knob.
  8. May 24, 2023 at 5:09 PM
    Colorado 4RNR
    Alex
  9. May 24, 2023 at 5:14 PM
    Colorado 4RNR
    Alex
    Hey this is exactly the issue I am having, I was twisting to tighten up the shifter as it was loose, I am not sure if I broke the insert inside the knob but it spins now every time I try to loosen it. I was afraid to pull it since I don't want to break the knob. Once you pulled the knob off did the OEM replacement worked as normal again?
  10. May 24, 2023 at 5:15 PM
    Colorado 4RNR
    Alex
    I was trying to tighten the shifter as it was loosed and noticed that it spun after turning it.
  11. May 24, 2023 at 6:30 PM
    In my case, I was trying a TRD knob instead of the billet aluminum knob I got. After I couldn’t tighten it up, I got the TRD knob off by pulling up and twisting, I sent it back to the Toyota dealer I got it from, and went back to the Ellis Precision billet knob because I have no problem getting that one tight. No more oem knobs for me.
