Shift Delay and other Transmission Issues
Discussion in '4th Gen 4Runners (2003-2009)' started by kicker13, Jul 20, 2020.
  1. Jul 20, 2020 at 3:58 PM
    kicker13
    kicker13 [OP] New Member
    Hey everyone - I recently traded an 07 Tacoma TRD with 175k for an 05 4R SE 4wd with 176k after my wife and I had our son. I knew it wasn't in as good of shape as my Taco but the seller offered some cash on top of a trade and my truck wasn't moving so I took it. Replaced the rotors, calipers and pads right off the bat, followed by plugs, front wheel bearings, synthetic oil, and a K&N air filter. Threw a code one day for the 2nd ignition coil and quickly replaced it.
    None of those things were ever really red flags, but it's had a lingering shift delay on takeoff and when shifting from D to R and R to D. Sometimes it'll take a good 2 seconds to get a throttle response leaving a full stop, although the worst delay is a rolling stop. Took it into the dealership to get the transmission fluid checked and got the typical "could not duplicate," so I need some advice as to whether or not this is normal. I definitely didn't experience anything like this with my Taco with the same engine etc, in fact it got better with age.
    If it's normal, is there anything I can do to minimize it? If it's not normal, can you fine people point in the right direction as to what steps I need to take to get it corrected/repaired?
  2. Jul 22, 2020 at 12:03 PM
    MattAK
    MattAK Headin' for the hills
    Matt
    Utah
    2019 Tundra SR5 dbl cab white
    These things aren't exactly responsive to the throttle but what you describe doesn't really sound normal to me. I have the V8 so it might act a little differently for me with your V6 but they are the same transmission. I do have issues on occasion going from R -> D and vice versa; if I'm too quick on the throttle after the shift or if I didn't come to a complete enough stop before shifting the transmission doesn't like it and will refuse to go into gear until I cycle it again. Or it will go into gear but the traction control will chatter at me. Normally just takes a second to do the shift though and I don't really notice a rolling stop delay. When I bought mine I had the torque converter rumble strip issue as well as some pretty hard downshifts from 5 to 4. I had the pan dropped by a local shop (not the dealer) so it could be inspected. My fluid was extremely dirty so they did a full exchange and added some additional lubricants and shudder stop which fixed my two issues. Might be worth having a good transmission shop give you a second opinion.
    I know people like to use a sprint booster or pedal commander to get better response out of the throttle but I personally haven't found a need for one yet.
    kicker13[OP] likes this.
  3. Jul 25, 2020 at 6:42 AM
    captsolo
    captsolo New Member
    Tom
    nassau bahamas
    2005 SR5
    With the transmission do a 5 quart Drain and Fill with Toyota brand WS only. That will exchange 35% of the old you have in there now. Sometimes a transmission service will solve shifting issues.
    Some 4runner transmissions have gone over 200,000 miles without any service. Lifetime fluids are not really good for a lifetime (500,000 miles). D/F (filter too).
    Only Toyota brand WS fluid. Look up your year and buy it off Amazon.
