Sherpa Crestone leak?
Discussion in '5th Gen 4Runners (2010-2024)' started by rmrf, Jun 9, 2023.
  1. Jun 9, 2023 at 11:22 AM
    rmrf
    rmrf [OP] New Member
    Yesterday I installed Sherpa Crestone on the 4runner. There were rain overnight. My car is parked on a slight slope. After I drove to a even pavement I heard sloshing from the roof.
    Leak? Accumulated water on the roof in the gaps between rubber pads and weather stripping?
  2. Jun 9, 2023 at 11:23 AM
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    I think you should be able to see water stains on headliner if a leak. I had this same concern after rack install.
    rmrf[OP] likes this.
  3. Jun 9, 2023 at 11:26 AM
    Ripmo
    Ripmo New Member
    2022 Lunar Rock ORP
    Bilstein 5100 2” front Bilstein 5100 rear w/ 1” Cornfed spacer Sherpa Crestone roof rack RCI Skids and sliders Ironman UCA’s
    I know my crossbars hold a decent amount of water in the channels if left on relatively flat ground. The first turn I make, water will pour over the side. No issues with roof leaks though even through touch less car washes.
  4. Jun 9, 2023 at 11:28 AM
    2021venture
    Todd
    2021 Venture
    I was OCD on checking for leaks and spent time with the hose blasting the brackets and checking the headliner.
    No leaks but if I did have one wanted to deal with it on my terms quickly .
  5. Jun 9, 2023 at 11:31 AM
    rmrf
    Is it makes sense to seal gaps with silicone to prevent puddling? Or I'm overthinking?
  6. Jun 9, 2023 at 8:00 PM
    joshdub
    joshdub New Member
    2020 TRD ORP
    No. Silicone will help facilitate rust. The rubber washers and gaskets, when installed correctly, do not leak.
    Water does accumulate in the bars and will run out when driving
    Spare Parts and rmrf[QUOTED][OP] like this.
  7. Jun 12, 2023 at 6:37 AM
    i installed the sherpa crestone in January. No leaks at all. By any chance did you overtighten the roof mounts and crush those washers?
  8. Jun 12, 2023 at 6:59 AM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    KNOCK ON WOOD, I installed mine last spring, there is no evidence its leaking. I bought the Sherpa after researching based on the fact this was not an issue anyone talked about.
