Shaking at 30mph & 40mph
Discussion in '5th Gen 4Runners (2010-2024)' started by Qdelco, Feb 13, 2024.
  1. Feb 13, 2024 at 6:47 PM
    Qdelco
    Qdelco [OP] New Member
    Quanda
    2015 Toyota 4Runner sr5
    Level
    Hi All,
    I’m new to the forum, but so far it seems as though yall may know your stuff!
    My 2015 SR5 (159k miles) is shuddering or vibrating at precisely 30 & 40 mph then stops. When I switch to “S” mode it stops or if I’m already in “S” mode, doesn’t at all. The dealership wouldn’t look at it. They said new transmission $5k used or $6k new.
    Called a mechanic out to diagnose & he was puzzled.
    Mods include a leveling kit, 33 tires / 17” rims that are balanced & rotated @ 5k miles routinely.
    My baby is sick & she needs help! STAT!!!
  2. Feb 13, 2024 at 7:52 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    Welcome to the forum! I would use the search feature to find similar issues because I've seen them before.
    My first thought, given the oversized tires, would be a potential balancing issue. I *think* that is usually the culprit. Seems the 4runner is very sensitive to balancing issues.
    Second thought would be needle bearing. Really weird that S mode would prevent the shaking but if putting it in 4wd takes it away, that is usually a good diagnosis
    raimieb likes this.
  3. Feb 13, 2024 at 9:43 PM
    Qdelco
    Quanda
    Level
    My car doesn’t have 4wd, but can switch to “sort of” manual which is the S mode. I’ll definitely look into the bearing issue.
    You don’t think it’s a transmission issue?
    Thanks for your help!!
  4. Feb 13, 2024 at 11:03 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
  5. Feb 14, 2024 at 4:16 AM
    FN2187
    FN2187 Stormtrooper
    Earth
    If you don't have 4wd then you don't have a needle bearing.
    I would chase down tire issues before I replace the transmission. 4runners seem overly sensitive to balancing issues, especially if they are heavy. Your 33s are going to be much heavier than stock - especially if they are C or E load.
    Again, search the forum because it's been brought up before. I think there is a specific type of road force balancing that helps but can't remember the name
  6. Feb 14, 2024 at 5:41 PM
    scanny
    scanny New Member
    Ontario, Canada
