Shaking after lift and tire install
Discussion in '5th Gen 4Runners (2010-2024)' started by Anprice17, Mar 18, 2024.
  1. Mar 18, 2024 at 2:29 PM
    Anprice17
    Anprice17 [OP] New Member
    Isle of Palms, SC
    2019 4Runner SR5 Premium
    2.5in Daystar Spacers (Front) 1.75in Daystar Spacers (Rear) 285/70R17 Radar Renegade RT’s 5% Tint
    I had 2.5” blocks (Daystar) installed on my 2019 SR5 premium this weekend and paired it with Radar Renegade RT’s 285/70R17 on stock rims. It looks amazing. Although after first drive I got it up to 45mph and the steering wheel started shaking pretty hard side to side. I had an alignment done today and it did not fix the issue. I have read that maybe I need the tires balanced again? Any suggestions?
    thanks ahead of time!
    Toy4X4 likes this.
  2. Mar 18, 2024 at 2:37 PM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Re-balance.
    Anprice17[OP] likes this.
  3. Mar 18, 2024 at 2:39 PM
    What's the order of all you had done?
    I have to say, you're pretty much pioneering the Daystar spacers and Radar Renegade RT's. If anyone on this forum has installed those, they haven't said much about either...
  4. Mar 18, 2024 at 2:39 PM
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    I would start by rotating the tires and see if the shake follows. If so you will certainly need a re-balance. Are all of the fasteners properly torqued from the lift?
  5. Mar 18, 2024 at 2:51 PM
    Anprice17
    Isle of Palms, SC
    I read great reviews about the daystar spacers, but didn’t do too much research on pairing with these tires. Mistake I suppose…
    I had lift install and tires all installed at once. Then had the alignment done today. (2 days later). I barely drove on it through the weekend…have not exceeded 50mph.
  6. Mar 18, 2024 at 2:53 PM
    Anprice17
    Isle of Palms, SC
    I plan to have the tires re-balanced tomorrow, and take it from there. I am going to mention it to the shop what the problem is, but I have little faith in them. I was recommended the shop from another 5th gen who had the same install. Different tires but equally as aggressive…
  7. Mar 18, 2024 at 2:53 PM
    Just for context, did you do anything in the rear, or just level the front? And, were there any issues getting the alignment numbers where they needed to be? If you could post the alignment sheet, that might help.
    Anprice17[QUOTED][OP] likes this.
  8. Mar 18, 2024 at 3:01 PM
    Anprice17
    Isle of Palms, SC
    2.5 in the front, 1.75 in the rear. Although from the looks, I can’t even see anything in the rear. Here is a photo for reference of the front? Does this look right?
    https://www.amazon.com/gp/aw/d/B006...n_title#aw-udpv3-customer-reviews_feature_div
    that is the lift as well.
  9. Mar 18, 2024 at 3:23 PM
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    Find someone who road force balance your tires. I have it done all the time on my 4runner and no issues. I’m lifted with 285’s.
    hossler1788 and Anprice17[OP] like this.
  10. Mar 18, 2024 at 3:37 PM
    Manhattan
    Manhattan New Member
    Have you had Radar tires before, and did they balance well? Are they E-rated? I’m not familiar with the brand.
  11. Mar 18, 2024 at 3:40 PM
    Anprice17
    Isle of Palms, SC
    Going to have this done tomorrow…
    RusPro17[QUOTED] likes this.
  12. Mar 18, 2024 at 3:40 PM
    Anprice17
    Isle of Palms, SC
    I have not had them before. My brother had them and spoke very highly of them. They are e-rated.
  13. Mar 18, 2024 at 4:30 PM
    Fortuner
    Fortuner New Member
    CA
    2021 4Runner TRD Off Road Premium w/KDSS
    Looks great! My gut says re-balance those wheels. Find a place with a Hunter machine (you can use the Hunter site to find locations FYI) - then use @nimby's guide on how to get the balanced.
    nimby and Anprice17[OP] like this.
  14. Mar 18, 2024 at 7:08 PM
    Anprice17
    Isle of Palms, SC
    Thank you all for the input. Going to get them balanced in the morning and report back. Thank you!
    nimby and RusPro17 like this.
  15. Mar 19, 2024 at 6:45 AM
    crashdb
    crashdb How Did I Get Here?
    Dave
    Manassas, VA
    2022 TRD-OR-P
    Little Tree Air Freshener
    Will definitely recommend the road force balance. I bought some crappy tires for steel wheels (asking to have problems) and road force helped a lot of vibration/shaking issues.
    Another thing that I didn't see brought up are tire temps. Even though the tires I bought are considered a hybrid tire (in-between MT and AT), they are a mother to get heat into and keep it there. Even in 40-degree temps and a little higher, I can get an inconsistent wobble at 60 mph.
  16. Mar 19, 2024 at 6:40 PM
    saltmobile13
    saltmobile13 New Member
    NY
    2019 trd off road MGM
    aside from all issues , the rig is looking mint,good luck with everything
  17. Mar 20, 2024 at 4:14 AM
    Anprice17
    Isle of Palms, SC
    Problem solved. Took in to a different shop for a re-balance. They said all 4 tires were out of balance. Thank you all!
    Fortuner, nimby, backpacker and 3 others like this.
  18. Mar 20, 2024 at 4:35 AM
    Manhattan
    Great news! Now the important question - do they rub? ;-)
  19. Mar 20, 2024 at 4:39 AM
    Good to hear! I've found that some shops don't seem to balance tires as well as others.
    nimby likes this.
  20. Mar 20, 2024 at 7:11 AM
    The quickest way to answer that question is for the OP to turn all the way to the right (full lock) in reverse. That's how I found out that my tires rub. They're stock size, but Falken Wildpeaks. First time I heard it, I kind of freaked out. Then I saw it's kind of common.
    SlvrSlug likes this.
