Serpentine belt replacement
Discussion in '5th Gen 4Runners (2010-2024)' started by 2016Pro, Jul 10, 2023.
  1. Jul 10, 2023 at 2:14 PM
    2016Pro
    2016Pro [OP] Why all of the Pro hate?
    I'm up over 100k and will replace the Serpentine belt. Anyone done it recently?
  2. Jul 10, 2023 at 2:22 PM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    I've done a few on different Toyotas. I have a new belt but will probably wait until later this year to install. I'm at 79K.
    2016Pro[OP] likes this.
  3. Jul 10, 2023 at 2:31 PM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
  4. Jul 10, 2023 at 3:27 PM
    There's a plastic gauge to measure wear unless you see visible cracks. Maybe check it before replacing.
  5. Jul 10, 2023 at 5:10 PM
    2016Pro
    I'll just do it, shouldn't be too difficult
  6. Jul 10, 2023 at 6:18 PM
    scanny
    scanny New Member
    Ontario, Canada
    Isn't it too early? I had over 120,000 miles on my old 2010 4Runner and serpentine belt was still original.
    Rocko9999 likes this.
  7. Jul 10, 2023 at 6:37 PM
    2016Pro
    I've seen it recommended to change at 70 to 100k
  8. Jul 11, 2023 at 8:45 AM
    Guppy1301
    Silver 2019 TRD ORP
    Print out or draw a diagram of the routing. There's a couple good Youtube videos out there. Some use an allen wrench on the tensioner and some don't. I also don't change belts enough to be considered good at.......lol.
  9. Jul 11, 2023 at 11:38 AM
    2016Pro
    Is there a good YouTube video someone can point me to? Thanks
  10. Jul 11, 2023 at 11:44 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    If the rubber is good, no cracks, no need to replace it. These can go a long long time.
    2016Pro[QUOTED][OP] likes this.
  11. Jul 13, 2023 at 11:53 AM
    rickystl
    rickystl New Member
    Rick
    St. Louis, MO
    2021 TRD/Off-Road Premium
    On my previous 10' FJ Cruiser (same engine) I changed mine at 75,000, and keep the old one in the FJ as an emergency spare. As mentioned, many get 100,000 miles from these belts. They do last a long time. It's handy to have a friend while looping the new belt in place to hold part of the belt while re-applying the tension.
  12. Jul 13, 2023 at 12:06 PM
    2016Pro
    I know there is a way to lock the tensioner to make it easier. I need to watch a video and figure that out
  13. Jul 13, 2023 at 12:35 PM
    3JOH22A Toyota Gigolo
    Did mine in March: https://www.4runners.com/posts/438971
    I replaced the tensioner pulley (which has a LH threaded bolt) so I judged it was necessary to lock the tensioner open with an allen key, so I wouldn't be reefing the breaker bar against the belt.
    Depending on how much off roading you do, the idler pulleys will degrade quicker than the belt itself. The most susceptible idler, the lower one, is also the least accessible :) I think the later 5th gens like yours have a different oil cooler which blocks the lower idler pulley even more.
  14. Jul 13, 2023 at 12:55 PM
    rickystl
    rickystl New Member
    Rick
    St. Louis, MO
    At least on my 2010, the tension pully had a small hole in it the lined up with the same size hole on the front of the engine block once tension is released. A Phillips screwdriver fit in to both holes to hold the tension pully still while changing the belt. Worth a check. In fact I should check this out on my 21' 4R and see if the two holes are still there. LOL
