Seat swap
Discussion in '4th Gen 4Runners (2003-2009)' started by mastersme, Oct 30, 2024.
  1. Oct 30, 2024 at 2:28 AM
    mastersme
    mastersme [OP] New Member
    Doug
    20098 Toyota 4 runner limited
    Hi , I just replaced my front seats and now all the lights on the dash are on , the shift lock doesn't work and the lights on the running boards wont go off , when i try to lock it the alarm goes off as if something is open. I'm thinking its a programing issue . these seats are not from a limited and does not have the side airbag.
    Toy4X4 likes this.
  2. Oct 30, 2024 at 3:32 AM
    Welcome from Wisconsin!
  3. Oct 30, 2024 at 6:08 AM
    welcome. You already stated that some things are missing on the new seat that the BCM is looking for. You might need to get someone with Techstream to re flash the BCM maybe? I'm not really sure what can be turned off or not.
    mastersme[OP] likes this.
  4. Oct 30, 2024 at 6:15 AM
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    2023 TRD Pro Ice Cap
    What year? Avatar says 20098 :eek:
  5. Nov 1, 2024 at 10:29 AM
    mastersme
    Doug
    i replaced the brake light switch because the speedometer was not working unless I stepped on the brake , i have scan it and no codes so I reprogramed the ecm , I think its a bad ground some ware
    LOSTR4 likes this.
