Seals during a regear job question
Discussion in '5th Gen 4Runners (2010-2024)' started by Ctreg, Jan 21, 2024.
  1. Jan 21, 2024 at 12:58 PM
    Ctreg
    Ctreg [OP] New Member
    If the axle seals look good do they always get replaced on a regear? Does the skill of the shop have any bearing on the need for new vs re using the seals?
  2. Jan 21, 2024 at 1:26 PM
    3JOH22A Toyota Gigolo
    ^You're pulling out the axle shaft just a few inches to free it from the diff, so normally the axle seals don't get damaged.
    If you have a good amount of miles, replacing the axle seals "while you're there" is a good preventative action - leaking seal tends to ruin the rear wheel bearing, and that's a bigger job.
    Front CV seals can be replaced on-condition. Leaking seal there doesn't cause collateral damage.
