Scanned at Auto Zone. #4 coil pack and plug needs replacement
Discussion in '4th Gen 4Runners (2003-2009)' started by Abkasco, Feb 16, 2024.
  1. Feb 16, 2024 at 1:49 PM
    Abkasco
    Abkasco [OP] New Member
    alan
    07 4 runner
    My 07 4runner has been hit and miss with running rough. Since yesterday it's been running rough no stop. Stopped by AutoZone they scanned it and scan says #4 coil pack and or spark plug. Yesterday I replaced the coil pack after putting on a new one 2 days ago. My Fixed scanner and Auto zones both said #4 coil pack and theirs also indicated spark plug bad. I bought a Bosch #672 plug from their. Replaced it and put back the new coil pack. Still running rough and now seems to not want to idle. Any thoughts. She has 285000 miles on her. My 4runner is almost mint and want to keep it
  2. Feb 16, 2024 at 1:57 PM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    Maybe it's not the number four. I'd start the Runner and pull one plug wire at a time. You should be able to determine which is the issue.
  3. Feb 16, 2024 at 2:24 PM
    Abkasco
    alan
    07 4 runner
    Thanks I'll give that a try. I'm also wondering if they gave me the wrong plug....it is AutoZone
  4. Feb 16, 2024 at 3:06 PM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    I don't know about the plug but if it's a plug or coil pack it should be easy to test. Please do come back and let us know what you find.
  5. Feb 16, 2024 at 5:43 PM
    Stop buying new stuff. Don't even need to go to autozone.
    Just disconnect the coil pack and see how the engine runs. If you take it off and runs even more like crap you know it was good. Find the one that the engine doesn't change how its running.
    You sure you even replacing the correct cylinder pack?
  6. Feb 17, 2024 at 5:06 AM
    Bluesky 07
    Bluesky 07 Not a New Member
    Russell
    Northern Georgia
    Silver ‘07 Sport V6 4WD @ 263K miles
    “Deep” Satoshi grille | X-REAS delete / TRD Offroad front springs & Bilstein 4600 shocks + FJC rear springs | Weathertech front & rear mats | Tinted front windows | Floor Armor cargo mat | TPMS bypass | LED interior, tag, & reverse lights | BlueSea Systems console USB power ports | Gentex 453 autodim mirror w/Homelink & compass | Kenwood DDX373BT HU + Audiovox backup camera | Fumoto F-103S | Bazooka tube subwoofer | Kenwood speakers & KAC-M1804 amp | Philips H9/9011 headlight bulbs | Rexing V1 Gen3 dash cam | Map light mod | Breather mod | Off-road Nav Setup | Power Stop Z36 brakes | OBD Fusion diagnostics
    Should be easy enough to look up.
  7. Feb 18, 2024 at 8:34 PM
    Post the codes.
