Scangauge 2 to view transmission temp?
Discussion in '5th Gen 4Runners (2010-2024)' started by Grug556, Jul 25, 2024.
  1. Jul 25, 2024 at 8:54 AM
    Grug556
    Grug556 [OP] New Member
    Kings, Crestone Rack, Baja S8, Baja Fogs, Baja XL80s, Baja mini cubes, SPOD, ARB compressor, RCI full skids, ROAM box and stuff. ST Pros. Shrockworks sliders... GOAT armour
    Anybody get a Scangauge 2 OBD reader to view transmission temps? I have a scangauge 2 but it needs the firmware update for 4.02+ to apparently doToyotas so I thought I would ask if anybody has used this reader successfully before I buy the new board upgrade and if its easy to enter the Toyota codes to view various different gauges and temps accurately? This was going to be used for a transmission drain and fill using it for correct transmission temp range when the its on volume and you hit the mini overflow drain to drain out residual. thanks
  2. Jul 25, 2024 at 9:14 AM
    Can you not enter the x-gauge code for it to work? I know it worked on my 2010 Tacoma and others reported it working on the Runner.
  3. Jul 25, 2024 at 9:19 AM
    Grug556
    yeah but my actual unit firmware is to old to enter the codes. How easy was it to access tranny temp with the x gauge code? also did it retain the code when you powered it off or did you have to re enter the x guage to get to the temp reading each time you plug into the the data port?
  4. Jul 25, 2024 at 9:22 AM
    Once entered it is retained and populates with a value as soon as there is communication is available from the truck. Depending on the cost to upgrade, maybe consider the SG3 since adding gauges is easier with it and there's wireless updates.
  5. Jul 25, 2024 at 9:34 AM
    Grug556
    I saw the 3 listed to. How good is it? Hard to tell how good the screen is? hows the resolution. Any idea how good the mount plug is?
    Thanks for info on it storing the code.
  6. Jul 25, 2024 at 9:41 AM
    I was considering purchasing it but I didn't want more stuff than I already have in the Runner. I was possibly going to mount it to the A pillar with a Proclip mount since it will be in line of sight. I don't know much about it though.
    I ended up getting an OBD2 link and I run OBD2Fusion on my phone which also works through carplay so it's on my headunit when I want it. It's tricky to set up but it works pretty well.
  7. Jul 25, 2024 at 9:44 AM
    PJSnow and whippersnapper02 like this.
  8. Jul 25, 2024 at 9:49 AM
    My scaunguage2 is 3M taped right under the HVAC controls
  9. Jul 25, 2024 at 2:15 PM
    2020 4Runner
    2020 4Runner New Member
    Fl
    The SG3 is excellent in all ways. I have one in my 2020 Tundra.
  10. Jul 25, 2024 at 3:09 PM
    JR7
    JR7 New Member
    2021 TRD ORP
    I had a friend of mine 3D print a contoured mount that matches the curve of the top of the steering column, that gave a nice flat top to mount the scan gauge to. Out of the way and right in front o the gauge cluster, no blockage.
  11. Jul 25, 2024 at 4:31 PM
    scottiezilla
    scottiezilla New Member
  12. Jul 26, 2024 at 6:54 PM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    I have the Scanguage2 mounted on steering column with their supplied velcro. I normally have 4 tire pressure showing especially if driving fast. I requested the tranny temp X-guage installed by the Scanguage company at time of purchase. When climbing long grades I have the tranny temp, intake air temp, charging system and engine temp showing.
  13. Jul 28, 2024 at 6:19 PM
    Hungryhawk
    Southern CA
    2017 SR5
    To answer Grug556 question about the scanguage plug: there is a serial type plug that mates with the OBD2 under your dash. The quality cable has a RJ data plug type end that snaps into the Scanguage in 2 positions to assist cable placement. These RJ plugs are somewhat delicate and are like the ones on routers. The cable is long enough for most dash installs . I recently purchased a second cable so If I want to use my Scanguage to read the OBD2 of another vehicle, I do not have de-install my under dash cable where I used a few cable ties
  14. Jul 29, 2024 at 5:46 AM
    Grug556
    THanks guys. Appreciate the replies. Looks like my firmware is to old and I need the upgrade for the x gauge codes to run.
    On the Scan 3, how is the resolution on the screen? Is it touch screen or buttons? Is it worth it over the 2?
  15. Jul 29, 2024 at 9:33 PM
    Hungryhawk
    Southern CA
    2017 SR5
    The scanguage 2 screen is simple and the buttons cycle thru the many parameters available. I noticed if the screen gets too hot it goes blank. I use a sunshade in my windshield or I put a white towel over it when parkng in hot sun. Seems to eliminate the issue.
  16. Jul 30, 2024 at 5:35 PM
    T in Texas
    T in Texas New Member
    FEMA Region 6
    2024 Terra TRD Pro Terra - finally got it
    I have a Scangauge 3 for most of my cars and like it
    for the 5th gen,
    I used a 'phone' mount I got off Etsy and the Scangauge magnet mount on the 17mm ball
    mount with scan gauge mount installed, Scangauge pulled off to prevent theft
    link to mount
    https://www.etsy.com/listing/1733124752/fits-5th-gen-toyota-4runner-2014-2024
