Saker’s Ebony Build
Discussion in '5th Gen Builds (2010-2024)' started by Saker, Apr 13, 2022.
  1. Apr 13, 2022 at 5:41 PM
    Saker [OP] New Member
    21 Black T4RORP
    This what my 21 T4R TRDORP looks like as of 10-13-21​
    Bought October 23, 2020
    BFG All Terrain TA KO2 & TRD Wheels installed at dealership before I took delivery.
    Let the Mods begin!
    Buvenom4R, MTB Chris and Thatbassguy like this.
  2. Apr 13, 2022 at 5:43 PM
    21 Black T4RORP
    October 27, 2020
    Installed High Beam LED's
  3. Apr 13, 2022 at 5:44 PM
    21 Black T4RORP
    October 27, 2020
    Installed My Badges
  4. Apr 13, 2022 at 5:44 PM
    21 Black T4RORP
    October 27, 2020
    Installed Rear Blackout Emblems
  5. Apr 13, 2022 at 5:45 PM
    21 Black T4RORP
    November 3, 2020
    Installed 12V Auxiliary Circuit
    UPDATED: November 8, 2020
    Powered for current circuits. 1) Engine Compartment Light Mod 2) Raptor Light Mod
    T in Texas and ChessGuy like this.
  6. Apr 13, 2022 at 5:46 PM
    21 Black T4RORP
    November 5, 2020
    Installed Rigid Back-Up Lights
    These are wired to the trailer light back up circuit.
  7. Apr 13, 2022 at 5:46 PM
    21 Black T4RORP
    November 9, 2020
    Installed Interior & Exterior LED/COB’s
    Map Lights and Door Lights got these from Superbrightleds:
    194 LED Boat and RV Light Bulb - 5 SMD LED Tower - Miniature Wedge Retrofit - 110 Lumens - Cool White
    Part Number: 194-CWHP5
  8. Apr 13, 2022 at 5:49 PM
    21 Black T4RORP
    November 10, 2020
    Installed TRD Pro Grill
  9. Apr 13, 2022 at 5:50 PM
    21 Black T4RORP
    November 13, 2020
    Installed AVS Hood Deflector
  10. Apr 13, 2022 at 5:51 PM
    21 Black T4RORP
    November 14, 2020
    Installed FJ Cruiser Grip Handles
    I used [MENTION=215569]WAT4R[/MENTION] ‘s method with the T-Nuts pnPMPFuOj_783340d7e3b3fa90356dc2d844ee4eafb0ba1f8e.jpg
  11. Apr 13, 2022 at 5:52 PM
    21 Black T4RORP
    November 14, 2020
    Installed TRD Skid Plate
    Link: pnkrITvFj_8e24fcc14688b65b708ff8a7f3a97688d3d27dae.jpg
  12. Apr 13, 2022 at 5:53 PM
    Good to see you over here Saker, you definitely have a nice build.
    Saker[OP] likes this.
  13. Apr 13, 2022 at 5:53 PM
    21 Black T4RORP
    November 18, 2020
    Installed Engine Compartment Light Mod
    No Ambient Light Source
    MTB Chris likes this.
  14. Apr 13, 2022 at 5:54 PM
    21 Black T4RORP
    November 26, 2020
    Installed TRD CAI
  15. Apr 13, 2022 at 6:05 PM
    21 Black T4RORP
    November 28, 2020
    Raptor Light Mod
    Installed my blacked out Raptor Lights, AOB Raptor Light Switch, used a relay and used the Tail fuse location as the trigger.
    EDITED / UPDATED
  16. Apr 13, 2022 at 6:07 PM
    21 Black T4RORP
    December 14, 2020
    Installed Scuba Mod on Rear Differential & Diff Locker
    Cut the hole with a hole punch in rubber plug # 90950-01958, inserted fuel line, routed it, removed OEM one-way valve from differential, disconnected the 1/8” breather line from the diff locker, connected those to the fittings on the “tee” .
    Parts Used:
    (1) 90404-51026 Toyota 1/4" Fuel Line Union
    (1) 1/8" NPTF Brass Tee
    (1) 1/8 X 1/8 HB Male Adapter (1/8" Hose ID X 1/8" Male NPTF Adapter)
    (3) 1/4 X 1/8 HB Male Adapter (1/4" Hose ID X 1/8" Male NPTF Adapter)
    (1) 1/8" Brass Pipe Plug
    (1) 1/4" Brass Pipe Plug
    (1) 2 Port Manifold with Filter
    6' of 1/4" Fuel Line
    Hose Clamps to fit.
    Aluminum Bracket fabricated: I made mine out of a piece of 1/8" thick aluminum cut to size, bead blasted it and marked & drilled the holes.
    Brass machine screws, washers (flat and lock) and nuts to attach manifold to bracket.
    Mounted in the Bottle Jack Compartment with 1/4” SS cap screw, flat, lock washer and nut.
  17. Apr 13, 2022 at 6:07 PM
    21 Black T4RORP
    December 16, 2020
    Side Exhaust Mod............ Done
    Link with parts: pmoW31Xjj_bfc3ae0e5f4f82961a5fc05007bf447beb35fce5.jpg
  18. Apr 13, 2022 at 6:08 PM
    21 Black T4RORP
    December 18, 2020
    Installed RSG Sliders
    See
    2010+ Toyota 4Runner Angled Sliders **NO KICK OUT**
  19. Apr 13, 2022 at 6:10 PM
    21 Black T4RORP
    December 21, 2020
    Installed my Driver’s Side Grab Handle
    Today I mounted my Driver’s Side “A” Pillar Grab Handle on my 2021 TRDORP.
    As usual, thanks to a well designed lower bracket, it came out perfect from [MENTION=154554]Jasontamu[/MENTION] pnu6VSMlj_d49bb53ee3214d3a4ca129fb72817136f9e4e443.jpg
  20. Apr 13, 2022 at 6:12 PM
    21 Black T4RORP
    December 22, 2020
    Installed my Ellis Precision TRD Shift Knobs
    I received my Ellis Precision TRD etched shift knobs today.
    Thanks [MENTION=139559]Ellis Precision[/MENTION]
    Shift Knobs – Ellis Precision
    They look great!
  21. Apr 13, 2022 at 6:13 PM
    21 Black T4RORP
    December 22, 2020
    Installed Air Lift 1000 Airbags
    Part #60919
  22. Apr 13, 2022 at 6:14 PM
    21 Black T4RORP
    It took me 6 years to get my mods to this place on my .
    Except no tint, light bar and no lift/shock replacement yet!
    (Donations excepted with gratitude!) :biggrin1:
    It's been only 2 months since I took ownership of this one.
  23. Apr 13, 2022 at 6:15 PM
    21 Black T4RORP
    January 2, 2021
    Installed Plug and Play Rear Camera Override Dongle
    Thanking [MENTION=129513]bjohnston115[/MENTION] again for this mod! My install went off without any issues. Rear camera still works as normal.
    Depress the AOB Rear camera switch when in any gear, camera comes on.
    AOB Switch dims properly just as the other switches do.
    EDIT: On the AOB Switch wiring pictured, I connected the red to red on the ABC wire & the AOB green to orange ABC wire. Polarity correct!
    Wiring diagram
    Indication of Override Working
    AOB Switch Location and Functioning
  24. Apr 13, 2022 at 6:18 PM
    21 Black T4RORP
    January 13, 2021
    Windows Tinted & Valances Wrapped
    Had my windows tinted with Xpel Ceramic to 11% (metered) & my front and rear valances wrapped matte black also with Xpel vinyl.
    CraigOutside and Curt56 like this.
  25. Apr 13, 2022 at 6:20 PM
    21 Black T4RORP
    February 18, 2021
    Updated Raptor Light Switch from AOB
    From this:
    To this:
  26. Apr 13, 2022 at 6:21 PM
    21 Black T4RORP
  27. Apr 13, 2022 at 6:22 PM
    21 Black T4RORP
    April 1, 2021
    3 1/2” Infinity Reference REF-3032cfx Dash Speaker Upgrade
  28. Apr 13, 2022 at 6:27 PM
    21 Black T4RORP
    April 7, 2021
    R4T Lower Control Arm Skids Installed
    Link: DA14FA27-DA9F-48DE-80F5-301FC66E95BC.jpg
  29. Apr 13, 2022 at 6:27 PM
    21 Black T4RORP
    May 4, 2021
    Installed MESO Puddle Light Mod
  30. Apr 13, 2022 at 6:28 PM
    21 Black T4RORP
    July 29, 2021
    Removed my Vinyl Wrapped Front & Rear Valances & installed Black Ones
    Installed my [MENTION=602811]ctnewman[/MENTION] Rear Tire Carrier
    Man this thing is Awesome
    5six and Amerxon555666 like this.
