Rubbing
Discussion in '5th Gen 4Runners (2010-2024)' started by o_unit, Aug 17, 2017.
  1. Aug 17, 2017 at 5:07 PM
    o_unit
    o_unit [OP] New Member
    2015 Magnetic Grey 4runner SR5
    2.5 in Daystar Lift 1.25 Spidertrax
    Can an alignment fix rubbing on the front fender?
    I installed 1.25 spidertrax and seem to have some rubbing inside the front fender at lock turned to the right. Im still running stock tires 265 70 17 and baffled. And i also have a 2.5 in daystar lift... i thought the lift would eliminate any rubbing.
  2. Aug 17, 2017 at 5:39 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Yes, but in order to move the tire/wheel assembly rearward you'll lose caster which will make bumpsteer and wandering increase.
    Have you looked at the fender liner mod?
  3. Aug 17, 2017 at 5:48 PM
    o_unit
    Ahh i see. Yes i thought about doing a fender mod, im just not too thrilled about doing it. But what must be done, must be done. Thanks.
