Rough Country Lift removal. What do I need?
Discussion in '5th Gen Builds (2010-2024)' started by Enron, Mar 26, 2021.
  1. Mar 26, 2021 at 8:54 AM
    Enron
    Enron [OP] New Member
    Rebecca
    Missouri
    2014 Toyota 4Runner SR5
    Mayhem Voyager 17” 0 offset, Falken Wildpeaks AT3W265/70/17, Bilstein 4600 rear shocks
    I bought a ‘14 that came with 20inch wheels and a Rough Country lift. I’m replacing the wheel set with 275 or 265/70/17 tires and 17 8.5 wheels. I want to remove the lift when I get the new wheels and tires installed. What do I need to purchase to do this? Just shock absorbers? I was thinking about getting the Bilstein B6 4600 monotube shock set but I don’t know if that’s right.
  2. Mar 26, 2021 at 9:25 AM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    OP - Post #1
    "Hey guys!
    I just purchased my first 4runner and I want to replace the existing 20inch wheels. I'm looking at purchasing 17/8.5 but I'm confused with offset. CarID says the 0mm offset will fit but I don't know if this will look right with 265/70/17 AT tires. It's not lifted or anything. Please help a girl out, thanks! Oh I should add it's an SR5."
    Is it lifted or no?
    Mtbpsych likes this.
  3. Mar 26, 2021 at 9:30 AM
    Enron
    Rebecca
    Missouri
    It is lifted.. I went to the tire shop yesterday and had them check it out because I was unsure. I thought maybe the 20inch wheels were the cause of the height. This is all new to me and I’m learning so I apologize for the error.
  4. Mar 26, 2021 at 9:33 AM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    It's not an error, but for the best possible advice, it needed the clarification you have provided.
  5. Mar 26, 2021 at 9:43 AM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    First of all, congrats of removing that trash from your 4Runner.
    Now.. to help you, we need to know exactly what the "lift kit" is. Take a picture of the front shock/spring, and another of the rear shock/spring, and post them here. Be sure to get the entire assembly, from tops to bottom.
    Enron[OP] likes this.
  6. Mar 26, 2021 at 9:47 AM
    Enron
    Rebecca
    Missouri
    Okay will do!
    Singleminded likes this.
  7. Mar 26, 2021 at 11:10 AM
    Mtbpsych
    Mtbpsych New Member
    Depends. If you have a 6 inch lift on it, then it’ll have the cross member chopped so I don’t know if thats reversible. If it’s just spacers, it would be a basic remove and replace job.
  8. Mar 26, 2021 at 12:46 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Pictures will help.
  9. Mar 26, 2021 at 12:56 PM
    Per the RC site, 3" is the biggest lift they offer:
    Not to say that someone couldn't have pieced something together using this and something else, however.
    Most of the RC offerings are spacer lifts, + maybe shocks.
    I will add that Rough Country is one of the bottom feeders of the Jeep suspension world.
  10. Mar 26, 2021 at 2:23 PM
    Enron
    Rebecca
    Missouri
  11. Mar 26, 2021 at 3:04 PM
    Mtbpsych
    Mtbpsych New Member
    It’ll be a simple remove and replace job. It doesn’t look like the rear is lifted either, so you could just have the front spacer removed and it’ll have factory rake. Unless you want different shocks.
    Enron[QUOTED][OP] likes this.
