Roof rack question
Discussion in '4th Gen 4Runners (2003-2009)' started by Curt73, Feb 6, 2024.
  1. Feb 6, 2024 at 11:04 AM
    Curt73
    Curt73 [OP] New Member
    Curt
    Ohio
    2008 Titanium 4Runner SRS Sport Edition 4x4
    Rough Country 2.5 lift Front Springs and N3 Struts, Rough Country N3 Rear Shocks, Dobinson 1.5 lift Rear Springs, TRD Style 17x8 Matte Black Wheels, Toyo Open Country RT Trail 275/70R17, Black Headlight Assembly
    I see I can get the roof rack that attaches to the existing roof rack....(which mine is the factory tubing roof rack) and I also see the ones that replaces the existing roof rack. What are the pros or cons on the one that attaches to the existing roof rack? Thanks.
  2. Feb 6, 2024 at 3:14 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Hey OP @Curt56
    That's right
    I crossed this bridge about a year ago.
    Pros for bolt in:
    Stronger
    Safer
    Much more low profile
    And aerodynamic
    Full roof length available
    Pros for U-Bolt Bracket
    Often less money
    Often less heavy
    Can be a quicker install, no removal of factory rack (factory bolts up there can be difficult to remove)
    Many options for cargo baskets
    Easier to remove/revert back
    Saved money and bought a powder coated steel roof rack basket off Amazoné 1" bars. 3/4 roof length approx. 60". It mounts to your factory crossbars with U-Bolt brackets.
  3. Feb 6, 2024 at 3:18 PM
    Curt73
    Curt
    Ohio
    Does it interfere with the sunroof?
    And definitely a lot less money for sure. I haul kayaks so maybe keeping the roof rails would be better.....but I do like the low profile of the bolt on but damn they are expensive
  4. Feb 6, 2024 at 3:48 PM
    So mine was one of the longest cargo baskets I could find on Amazon, which is what I was looking for. It covers almost half the sunroof. Does it interfere with sunroof, no. But you could easily buy a slightly shorter length rack.
    It truly is, a lot, less money.
    You get what you pay for, yes low pro looks sick, especially when you know what he paid lol
  5. Feb 6, 2024 at 4:02 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
  6. Feb 6, 2024 at 4:15 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Since the bolt on one sits higher and the spoiler inherently won't be in the best position, I think it would probably net you worse mpg for the life of your vehicle than totally new solution. That could add up to the cost or more of a more expensive rack after 100k miles.
    That's a great question....what mpg hit did people see who have the bolt on version?
  7. Feb 6, 2024 at 4:33 PM
    backpacker
    2023 TRD ORP
    Worse than no basket, better than a basket attached to factory crossbars. Generally about 18 mpg on the highway.
    Curt73[OP] likes this.
