Rims for 99 4runner
Discussion in '3rd Gen 4Runners (1996-2002)' started by Gulch13, Jun 9, 2023.
  1. Jun 9, 2023 at 11:00 PM
    Gulch13
    Gulch13 [OP] New Member
    Eli
    99 4Runner sr5/92 Jeep yj
    Just lifting my baby 3 inches, looking for new rims, found a lot from new tacomas… they have same bolt pattern, will they fit?
  2. Jun 10, 2023 at 9:17 AM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    They should. Just make sure you that if you have a 4wd that you buy the rims off of a 4wd Taco. 2wd ones will not fit the front hubs.
  3. Jun 10, 2023 at 10:09 AM
    Kwikvette
    Kwikvette Kwik Fab
    Multiple
    Yes they will, plenty do.
    It's the 15" variants you want to look out for but who downgrades wheels?
    OP, I'd keep it at 2" if lift.
    That much is overkill.
  4. Jun 12, 2023 at 10:29 AM
    99 UnLimited
    99 UnLimited New Member
    David
    1999 Silver 4Runner Limited
    Does the 30 offset from a 2012 Tacoma wheel with 265/75/16 play well with a stock 99 limited fender wells?
  5. Jun 12, 2023 at 12:18 PM
    Kwikvette
    Kwikvette Kwik Fab
    Multiple
    Later generation Tacoma wheels sit inwards a bit.
  6. Jun 13, 2023 at 9:27 AM
    trlhiker
    trlhiker Lazy Bum
    I tried the 16" from a 1st Gen Prerunner on my 92 4wd 4Runner and the fronts would not fit around the hubs. I figured the hubs for the 2nd Gen 4runner would be the same as the 3rd gen.
  7. Jun 13, 2023 at 9:47 AM
    Kwikvette
    Kwikvette Kwik Fab
    Multiple
    3rd Gen 4Runners and 1st Gen Tacomas use identical spindles, wheel bearings, etc.
    The exception being that manual hub variants exist in 1st Gen Tacomas, not 3rd Gen 4Runners. With that said, that's why they'll work.
    2nd and 3rd Gen Tacomas have a different offset and most just run a spacer so they don't look funky.
    I'm not familiar with 2nd or 1st Gen 4Runners at all, not to mention pre-Tacomas IE Pick Ups.
