rim offset to fit 33x12.5 ?
Discussion in '2nd Gen 4Runners (1990-1995)' started by jeffsrunner, May 9, 2023.
  1. May 9, 2023 at 1:33 PM
    jeffsrunner
    jeffsrunner [OP] New Member
    2 wheel drive 4:88 locked and lifted
    ball joint blocks, springs, 4:88 gears, detroit true track auto locker, onboard air compressor, 140AMP cadilac alternator, H8 battery mounted over differential,
    I have a 94 4runner. Does anyone know what rim offset would have the 33x12.50x15 tire fit? (If at all)
    I have the ball joint spacer, and springs in the rear.
    I have a 0 offset wheel with a 35x12.50 on it for a test fit. It looks like a smaller 33x12.50 on a Positive 20mm will do for the back but I don't know if it's even possible for the front.
    Any Ideas, TNX
  2. Jun 16, 2023 at 2:31 PM
    RyFly317
    RyFly317 New Member
    94 4runner
    2" lift, 35s, lockers, bumpers, winch
    I have the stock 15x7 wheels with 8offset. Ran 33s no problem without a lift. Running 35s now with same wheels in 2" lift
