Right turn signal
Discussion in '3rd Gen 4Runners (1996-2002)' started by KC4runners, Sep 22, 2022.
  1. Sep 22, 2022 at 4:32 PM
    KC4runners
    KC4runners [OP] New Member
    2002 4runner SR5
    Seems like very 4runner i look at, the only way to get the right blinker to work/stay on is if you move the lever up slowly. Is this a common occurrence? Is there a fix for this?
  2. Sep 22, 2022 at 4:49 PM
    The multi function turn signal switch\stalk is probably bad. Very common.
    I got a replacement from a TOYOTA dealer for like $150 and put it in. Fixed my problem with sometimes working blinkers.
  3. Sep 23, 2022 at 12:06 PM
    PhantomTweak
    PhantomTweak New Member
    Patrick
    OREGON
    1999 4Runner, bone stock
    This is a fairly common problem Toyotas have. Many times the trouble is bent, or corroded, or both, contact in th portion of the switch inside the steering column. The contacts are right out in the open, and easy to access. Before you spend the money to get a whole new assembly, try cleaning, and/or straightening the contacts. A little Ruby cloth can do amazing things for those switches.
    There are several threads with "how to", including pictures. Just do a search of the forums for something about cleaning, or adjusting the turn signal switch. You'll be amazed at what's out there.
    Good luck!
    Pat☺
