Replacing mirrors with convex mirrors
Discussion in '5th Gen 4Runners (2010-2024)' started by whododat, Apr 1, 2022.
  1. Apr 1, 2022 at 7:41 AM
    whododat
    whododat [OP] New Member
    j4unner likes this.
  2. Apr 1, 2022 at 8:37 AM
    ShakyDog
    ShakyDog New Member
    Steve
    2021 4R TRD ORP Nautical Blue
    Yes, I popped the top of the mirror housing off to make sure I was able to get it off correctly, but that is not needed. Just adjust the mirror all the way left or right and pop it off. The hardest part is getting the heating plug removed.
    Steve
    j4unner likes this.
  3. Apr 1, 2022 at 9:02 AM
    jmkulbeth
    jmkulbeth Have you tried turning it off and on again?
    Jeffrey (KE5HDB)
    Siloam Springs, AR
    2020 4Runner Offroad Premium, Nautical Blue
    Bone stock!
    Agreed. It's pretty easy to pop them off, but you'll fight that heating plug.
    Try to do it on a warm day -- popping then off when it's cold might break some tabs on the mirror.
    j4unner likes this.
  4. Apr 1, 2022 at 9:12 AM
    whododat
    Thank you very much. Just need to wait until they are back in stock now.
  5. Apr 1, 2022 at 9:52 AM
    j4unner
    j4unner shootz brah..
    j4runner
    nCal
    21 SR5P
    I got the same ones from suma, but opted out for the blue tint..
    as mentioned above from the other members, it is really easy.. it will sound like you are damaging the mirror housing when you turn it to one side to pop off but you're not..there are 3 or 4 tabs the mirror clips into back into.. just make sure you put back the heating plug.. I made that mistake on the driver side (was too excited) put the other one on then thought to myself that I did not plug the heating element on the driver side.. total install 3 times lol..
  6. Apr 1, 2022 at 10:47 AM
    FYI, they only sell these in pairs for swapping out the driver and passenger side mirrors. Unless you want the blue tint, there is no advantage to swapping out the passenger side mirror - it's already convex. The Suma or any other convex replacement mirror gives you the same exact reflection as the oem mirror. So, unless you want blue tint, turn signal embedded in mirror, or the BSM added feature, save yourself the trouble of swapping the passenger side if all you want is a convex mirror with the heating element.
    They really should sell just the driver's side mirror to save some bucks.
    j4unner likes this.
  7. Apr 1, 2022 at 12:05 PM
    Beachguy
    2024 TRP ORP
    Not sure what you're looking for but I got these two OEM mirrors for the RAV 4 here: https://parts.olathetoyota.com/
    LH Part #87961-42D20
    RH Part #87931-42D50
    They are super easy to install and the plug mentioned was no big deal.
  8. Apr 1, 2022 at 12:54 PM
    whododat
    Just to clarify, the driver's side will make a difference, correct?
  9. Apr 1, 2022 at 1:59 PM
    j4unner
    j4runner
    nCal
    21 SR5P
    absolutely, imo..
  10. Apr 1, 2022 at 2:00 PM
    packetcollision
    packetcollision New Member
    MN
    '20 4Runner TRD-ORP
    @OP - I have a set with blue tint, defroster and the turn signal if you're interested. New in box, never installed. $150 shipped
  11. Apr 1, 2022 at 3:53 PM
    Yes. The driver side mirror will work just like your current passenger side mirror.
  12. Apr 1, 2022 at 4:04 PM
    Mass4runner
    Mass4runner New Member
    2023 TRD ORP
    Just ordered a pair of the RAV 4 blind spot mirrors off ebay, $90 shipped from Japan. I'm guessing popping the mirror glass out is pretty easy. I put aspheric mirror glass in my Camaro and it was no problem at all. I just used a trim tool and they came right out and the replacements just popped back in.
