replacement steering wheel
Discussion in '2nd Gen 4Runners (1990-1995)' started by Raptor22, Jun 30, 2022.
  1. Jun 30, 2022 at 7:57 PM
    Raptor22
    Raptor22 [OP] New Member
    1992 4Runner
    17" steelies from an FJ cruiser
    my '92 4runner is getting better and better as i replace the old and the broken, but now i think i need a new steering wheel, the one i have is a bit worn and i think a new one is in order. obviously being out of production for nearly 25+ years will make things.. difficult to say the least
    Is there a place that i could get a better than fair quality replacement steering wheel without losing the airbag,m something stock toyota, or any other wheel's that i can fit say from a corolla or other car? Ive heard the newer 4runners can do this to some degree, but im new to toyota, and customization..
    I would very much avoid using steering wheel covers. never once have I found one i like, or feel.
  2. Jul 1, 2022 at 7:44 AM
    watermelonman122
    watermelonman122 New Member
    Utah
    1994 4Runner SR5 3.4 V6 4wd 5spd
    I don't think you'll lose an airbag because a 92 doesn't have any airbags. They didn't come with airbags until 95.
    7385 likes this.
  3. Jul 1, 2022 at 6:43 PM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    No airbag in a 92. Should be able to put just about any steering wheel on it.
    7385 likes this.
  4. Jul 2, 2022 at 3:11 PM
    Raptor22
    1992 4Runner
    you sure? I could have sworn I have a driver airbag...
  5. Jul 2, 2022 at 3:20 PM
    trlhiker
    trlhiker Lazy Bum
    Show us a picture! By the way, airbags were introduced to the 4Runner when it was redesigned as the 3rd gen in 1995 as the 1996 model.
    7385 likes this.
  6. Jul 2, 2022 at 4:13 PM
    Raptor22
    1992 4Runner
    If the picture loads up here is my steering wheel
  7. Jul 2, 2022 at 4:35 PM
    wdsteven
    wdsteven New Member
    that steering wheel is Not bad a good cleaning and re-dye with SEM marine Vinyl coat or leather dye will bring that back to looking brand new! it may take a little to get the exact color you want but it works very good and will not come off on your hands
    7385 likes this.
  8. Jul 3, 2022 at 8:45 AM
    trlhiker
    trlhiker Lazy Bum
    Same steering wheel that I have. No air bags.
    7385 likes this.
  9. Jul 3, 2022 at 9:13 AM
    OverRunner
    OverRunner rebmeM weN
    Jared
    Denton, TX
    ‘21 ORP w/KDSS
    You’re looking for the SRS (Supplemental Restraint System, not a mistype of SR5) logo anywhere to confirm the existence of an airbag. Pretty sure they have to label anything that explodes in your face, lol.
    But as @trlhiker correctly points out, that’s a non-airbag steering wheel with what looks like just enough space for a clock spring and horn.
    There is a really easy way to tell though. The horn cover should unscrew from the back pretty easily, and if you get it all the way off without running into a very difficult (and brightly-labeled) electrical connector (the airbag connection), then you don’t have one and can carry on :) If you run into something that says airbag/SRS/“don’t touch without a professional” stop there and know you’ve confirmed an airbag :)
    7385 likes this.
  10. Jul 3, 2022 at 10:07 AM
    Raptor22
    1992 4Runner
    so the buttons on the wheel are faded out, any idea what it supposed to read? i know one says cruise control on one side, and it works but im not entirely sure. I haven't driven the thing on the road since I bought it and started to repair it, (cant register it without a title it seems), but the cruise and horn work atleast tell me they work but what are the buttons supposed to read? If this has no airbag, im gonna want to put in a new wheel, and add the buttons back on
  11. Jul 3, 2022 at 2:00 PM
    DIRTRCR13
    DIRTRCR13 New Member
    Jerm
    The 405
    '16 Sierra Romeo Cinco
    right single button is the cruise control on/ off. right double button is the set/ cancel. left double button is accel/ decel. If I remember correctly. Sold mine about a year ago... I may be backwards on the double buttons but Im pretty sure. And there is no airbag. Check your local Pick-N-Pulls or E-bay unless you want a "new" aftermarket one. Those will be about $150.
  12. Jul 3, 2022 at 3:48 PM
    trlhiker
    trlhiker Lazy Bum
    Other way around. Left button is on/off. Right single button is cancel. Lower button is set/decel. Upper one is resume/accel.
  13. Jul 3, 2022 at 4:12 PM
    DIRTRCR13
    Jerm
    The 405
    I knew it was close.. the things you dont really pay attention to on a daily basis and then have to remember to a T a year or more later....
    Thanks for clarifying
  14. Jul 3, 2022 at 5:49 PM
    Raptor22
    1992 4Runner
    can those buttons be removed and adapted onto a custom wheel or another non standard wheel? im thinking of buying a wheel and dremmeling out the holes for the buttons but i havent broke down the old wheel to see how they mount up to the oem one
  15. Jul 9, 2022 at 9:55 AM
    Raptor22
    1992 4Runner
    so yeah can confirm now no airbags. so now the question is. when I now replace the wheel, how can i add back the cruise control. the buttons are the cruise on/off that is a click button with a spring return, and the cancel and speed up/down. the wiring is very simple, but they are only 2 wires. does that mean i just need only 2 buttons or do i have to add back the cancel? the backing of both buttons are hilariously simple printed circuits, but the cancel and up/down are linked...
