Replacement pedal position sensor found for throttle body repair! (Sticky?)
Discussion in '3rd Gen 4Runners (1996-2002)' started by Earlr85944, Jan 18, 2025 at 8:59 AM.
  1. Jan 18, 2025 at 8:59 AM
    Earlr85944
    Earlr85944 [OP] New Member
    Sunday
    Rich
    2002 2wd , 148k super clean
    Success! I had slight extended cranking on cold start, loss of throttle response intermittently and code p0120, I replaced the throttle position sensor but then I got code p0128, I tried to repair / resolder the pedal position sensor internal terminals since the part was not avail and new throttle body was $450,,, it got worse so I was going to order a new throttle body…. Stumbled upon this pps for tundra Tacoma 3.4 v6,,, was on Amazon prime so worth a shot!!!! Replaced it but car wouldn’t start without flooring it…. A little more searching and found out to reset ecu parameters by unplugging battery 5 mins, setting tps position half way with screws loose,, started right up, no codes,,, let it warm up
    and set idle to 700rpm by adjusting tps, locked it down and running like new!!!
    this was for my 2002 4Runner
    https://www.amazon.com/dp/B0DFTM9C2L
    negusm and Ironguy like this.
  2. Jan 18, 2025 at 9:32 AM
