Replaced Rear Brakes/Rotors on 2014 SR5 - constant squeaking!
Discussion in '5th Gen 4Runners (2010-2024)' started by motorthings, Jul 16, 2020.
  1. Jul 16, 2020 at 7:11 AM
    motorthings
    motorthings [OP] New Member
    2014 4Runner SR5
    I got a set of Powerstop OEM Daily Driver pads and rotors for the rear brakes on my 4Runner (@68k miles). Brake pad wear on the original pads was even.
    I followed their instructions for installation and break-in, but am still getting a constant squeaking noise from both sides.
    I performed the following checks:
    • pulled the brakes back off
    • re-lubed the pins and backs of the pads
    • pushed the caliper piston fully back into the caliper
    • checked for debris in the caliper
    • cleaned the rotor
    • checked/cleaned the parking brake shoes and inside shoe surface of the rotor
    The squeaking noise is still there, when driving at any speed, maybe a bit less when braking.
    I have heard it is harder to break in the rear pads, since more of the braking is done in the front, but wonder what else I should check/fix to stop the noise.
