Replaced driver door lock actuator, window is binding
Discussion in '5th Gen 4Runners (2010-2024)' started by BruceKV, Jun 20, 2023.
  1. Jun 20, 2023 at 4:09 PM
    BruceKV
    BruceKV [OP] New Member
    Bruce
    2022 4Runner
    First post here guys, my wife’s 2022 4Runner driver door actuator got to where it would not unlock, so I just got through replacing it in this muggy south Alabama heat and am a little bit frustrated, watched a few YouTube videos and accomplished the feat in 37 minutes. But now the window is not letting down properly, looks like it’s letting down at an angle when it’s about 1/4 of the way going down. I put every screw and bolt back together in the proper order. Any advice will be greatly appreciated, will go back in to it tomorrow afternoon. Told her to not let window down when she pulls up at the mailbox tomorrow afternoon until I get some help on the forum, lol….
  2. Jun 20, 2023 at 4:13 PM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    Cant figure out why you are doing self service a a new 2022, Is it out of Base Warranty?.
    Or posting as introduction :)
    steelevo and Rocko9999 like this.
  3. Jun 20, 2023 at 4:15 PM
    BruceKV
    Bruce
    2022 4Runner
    Dealership would not cover it under warranty and wanted $800 plus to replace the actuator
  4. Jun 20, 2023 at 4:17 PM
    BruceKV
    Bruce
    2022 4Runner
    My mistake, typo on my part, wife’s 4Runner is a 2020 year model, but was told all we have under warranty is the power train
  5. Jun 20, 2023 at 5:23 PM
    BruceKV
    Bruce
    2022 4Runner
    Found my problem and corrected it, window channel rubber was kinked, and to fix the problem had to drill hole in door about 1/2” below the original bolt hole location to straighten the rubber out, evidently the after market actuator is slightly a different dimension
  6. Aug 28, 2023 at 1:51 PM
    crowdhater101
    crowdhater101 New Member
    There's a small motor inside the actuator that is usually the issue. You can buy them for $5 on eBay. I done 5 of them on the family Camry, and the hardest part is really just getting the actuator out of and back into the door, haven't had to do it on the 4R. The repair of the door lock actuator is simple. Just open the clips holding the actuator together, it will be obvious, the motor just rests in place.
    Slopemaster likes this.
