Replaced blinkers with LEDs - now they're blinking double speed
Discussion in '5th Gen 4Runners (2010-2024)' started by kosickim, Oct 10, 2024.
  1. Oct 10, 2024 at 9:50 AM
    kosickim
    kosickim [OP] New Member
    Matt
    2012 SR5
    One of my blinker lights went out, so I decided to replace them with LEDs. When a blinker light goes out, the blinker noise/clicking/blinker speed increases x2. Basically, it begins to blink faster to tell you that it doesn't work anymore, so you replace it.
    After replacing both of them with LEDs, both of them now blink at that faster speed. I was wondering if there was a cheat code or something I could do to reset the blinker speed back to normal.
  2. Oct 10, 2024 at 10:01 AM
    Bagman
    Bagman Dental Floss Tycoon
    Georgia
    Check the lighting forum.
    I just installed the Lasfit T3 series bulbs in the front and rear positions. No hyper flash like you're having.
  3. Oct 10, 2024 at 10:04 AM
    San Angelo
    San Angelo New Member
    Cheap bulbs without the proper circuitry. LED bulbs pull much less power vs a led, The relay is thinking that a bulb is burnt out and they do a “hyper flash” to let you know something is wrong.
    You can swap to a nicer bulb or monkey with some in line changes on the wiring to fix it. Get the better bulbs that way your not adding extra stuff or cutting wires to solve the issues
  4. Oct 10, 2024 at 10:09 AM
    You need a separate resistor or bulb with a resistor built in.
    icebear, Thacrow and Daddykool like this.
  5. Oct 10, 2024 at 10:22 AM
    Daddykool
    …or just get a replacement bulb and revert back to original.
  6. Oct 10, 2024 at 10:24 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Easiest and cheapest is to go back to incandescent bulbs. Nothing wrong with them.
    icebear and Daddykool like this.
  7. Oct 10, 2024 at 10:30 AM
    catbrown357
    Tempe
    2011 Limited 4WD
    Try cruise control on, cruise control off, hit the brake 3 times, turn the steering wheel left, turn the steering wheel right, honk the horn 6 times. All within ten seconds. It might require a couple of tries to get it right. Please post a video for others to use.
    icebear, Imdav2u, raimieb and 2 others like this.
  8. Oct 10, 2024 at 10:36 AM
    I replaced my blinkers, but the first two times I chose the wrong type. So I had hyper flashing. That's what you have. I finally found the correct ones and they work perfect now. I didn't need to install a resistor.
    I bought the switch backs.
    2Toys and raimieb like this.
  9. Oct 10, 2024 at 10:56 AM
    For me I want brighter so people can see since everyone is posting on social media or messing with their infotainment while driving instead of driving.
  10. Oct 10, 2024 at 11:29 AM
    Daddykool
    I get you, but I’ve not been in an accident where turn signal brightness came into play.
    catbrown357 likes this.
  11. Oct 10, 2024 at 5:35 PM
    Kad2112
    Kad2112 New Member
    Keith
    23 trd off road premium
    Bilstein 6112 & 5160 with ( B12 1.5 ) springs. 2.5 lift. Dobinson tubular UCA’s. Cooper AT3-XLT 285-70-17. TRD OR Premium wheels
    Be careful with adding a resistor to fix it. Care care nut has a video about a Tacoma that tried that. Cost the owner $$$. It’s Worth a watch on YouTube.
  12. Oct 10, 2024 at 6:22 PM
    catbrown357
    Tempe
    2011 Limited 4WD
    Yep. It's usually lack thereof.
  13. Oct 10, 2024 at 6:38 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    This is exactly why everyone needs 2 sets of raptor lights. To be seen
  14. Oct 10, 2024 at 6:40 PM
    catbrown357
    Tempe
    2011 Limited 4WD
    Don't forget the underglow.
  15. Oct 10, 2024 at 6:44 PM
    2 sets, why? For double the shame and double the humiliation?
    :crapstorm::duel:
  16. Oct 10, 2024 at 7:16 PM
    Headlights are brighter.
    Thacrow[QUOTED] likes this.
  17. Oct 10, 2024 at 7:17 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Light bar
  18. Oct 10, 2024 at 7:29 PM
  19. Oct 10, 2024 at 7:40 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    That was fascinating thank you.
    "You should never do this. Never ever. But we're guna do it today"
    ..yeah...a thousand amps at 120 volts...if he was accurate. That sounds insane. I guess he did say it dropped the volts down to 73 or something.
    He's even got the 6 wheeler van. Lot of win in that video.
