Replace oems for light off road use?
Discussion in 'Wheels & Tires' started by loggerboots, Apr 7, 2023.
  1. Apr 7, 2023 at 10:53 AM
    loggerboots
    loggerboots [OP] New Member
    Hello everyone,
    New member and new to off road driving.
    Use case is transportation/exploring within national forests (Wenatchee-Okanogen, near Chelan WA) sticking mainly to forest service roads (some of which are high clearance vehicle recommended). I'm not going to be doing recreational off roading or seeking out challenges intentionally, but I don't want to get stranded either. These forests are huge (4 million-ish acres) and prone to wildfires. The area gets considerable snow in the winter as well.
    Should I immediately upgrade the OEM Dunlops or just see if they're working out before swapping out for something more capable? If the latter, what are the go-to for OEM sized tires for this kind of use? I like the look of the KO2s (the white lettering would look good against my dark blue truck lol) but that probably shouldn't be a primary consideration :)
    Thanks!
  2. Apr 7, 2023 at 11:18 AM
    I'd switch to an A/T tire regardless but thats just me.
    Stoney Ranger likes this.
  3. Apr 7, 2023 at 11:28 AM
    Oakboro, N.C
    The Dunlops on my '21 were horrible in my short experience with them.
  4. Apr 7, 2023 at 1:24 PM
    TrailSpecial22 New Member
    PA
    Falken Wildpeak AT3 or MT version
  5. Apr 7, 2023 at 1:25 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Welcome, scrap the Dunlop's for sure. Find the most aggressive A/T M+S you can, some are all terrain/mud terrain hybrid actually. Stay away from mud terrain as a daily driver. Most importantly, forget KO2's they are cliche garbage
  6. Apr 7, 2023 at 2:22 PM
    Deuxdiesel
    Deuxdiesel New Member
    SE MI
    '18 SR5P
    I love my KO2's, to each his own. Definitely you will benefit from a dedicated A/T tire, and stay with the stock size and there won't be any issues. A P-metric will give a better ride than and LT rated tire, but will be less durable. I'm not sure why Toyota continues to use the Dunlop's- they don't do anything well.
  7. Apr 7, 2023 at 3:22 PM
    Stoney Ranger
    Stoney Ranger New Member
    Driftless Area
    '18 SR5 Nauti Blue
    4x Rockers/Skids-Dobi-275's-Fr/R Bpr-Winch-Stickers-ALF
    Drive those Dunlap's in the rain or snow, and you will wish you had different tires. Falken Wildepeak AT3's for the win. These are 275's.[​IMG]
  8. Apr 7, 2023 at 3:48 PM
    PA
    agreed. The Dudlops are only good for dry weather
  9. Apr 7, 2023 at 4:02 PM
    Have you owned KO2 competitors? You won't say you love KO2's after running legit competition
  10. Apr 7, 2023 at 5:04 PM
    BobbyB
    Bob
    Marietta, GA
    2021 White TRD Off Road
    OP, at the risk of being shamed by the all terrain advocates, I’ll give you a different opinion and remember it’s probably only worth what you pay for it..
    I have a 2021 OR with the OEM Dunlops and will be changing to all terrains in the next month or so as I get my rig ready for a summer trip to Colorado, Wyoming and Idaho.
    I’ve been running the OEM Dunlops since my rig was new and have done several hundred miles on forest service roads in North Georgia and North Carolina and I’ve not had any issues with the tires. Note that the forest service roads I’ve been on were in reasonably good shape. Also, I attended a 2 day off road driving course in Uwharrie, North Carolina hosted by Overland Experts where I was exposed to a multitude of obstacles that the Dunlops handled just fine with highway air pressure. The obstacles included moderate creek crossings, a few muddy low lying trails, moguls, moderate rock gardens, a few off camber ditches and a few steep climbs.
    I didn’t have any problems negotiating these obstacles with the Dunlops fully aired up. The object of the course was to teach driving skills in your vehicle as equipped. I was taught how to use what you have….
    As I said, I’m upgrading to all terrains for some serious “out west” trail running this summer but would not hesitate to continue to use the Dunlops if I was only planning to drive some mild forest service roads occasionally. I don’t think they are as bad as some say for the weather we have in Georgia. If it snowed much here, I would likely have a different opinion.
    that’s my $.02…. YMMV..
    Cheers,
    Bob
  11. Apr 7, 2023 at 6:15 PM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    @BobbyB, I think it very much depends on the substrate where you live and drive.
    Here in the Eastern Sierras and Nevada desert, there is no way in hell I would venture off-road in any serious way with the stock Dunlops.
    Big, sharp rocks everywhere. They wouldn't last an hour.
