Recovery Hooks/Points
Discussion in '5th Gen 4Runners (2010-2024)' started by morfdq, Jun 5, 2023.
  1. Jun 5, 2023 at 9:14 AM
    morfdq [OP] New Member
    Anyone recommend a recovery point that bolts directly to the frame? I see people putting shackles on the Toyota tie down points but even toyota says those arent recovery points those are simply tie down points for shipping. I saw there are bolt on hooks for the Tacoma but I cant seem to locate any for the 4R
    Foothills likes this.
  2. Jun 5, 2023 at 9:18 AM
    icyhotahs, SlvrSlug and RkyMtnMan like this.
  3. Jun 5, 2023 at 10:53 AM
    Where did Toyota say that, may I ask?
  4. Jun 5, 2023 at 1:40 PM
    mainerunr
    mainerunr New Member
    Maine
    '23 TRD ORP
    Toyo AT3's, Greenlane Sliders
    Didn't some smart person do an analysis of the loops and come to some conclusions about this?
    LCJ77 likes this.
  5. Jun 5, 2023 at 2:53 PM
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    i think most people are coming up with this deciphering the language used in the owner's manual.
    i'm sure captain has better insight on those hooks due to his career experience, so i'm assuming they aren't ideal prob due to their construction and the hardware used to bolt them to the frame. i've used the front tow hooks for a small bump out of small trouble (mud/snow). i'd do something different if i were really stuck and needed a big or long pull to get the truck out of trouble, mostly for the sake of safety and avoiding things flying around.
  6. Jun 5, 2023 at 4:22 PM
    I wish the language were more definitive. After a quarter of a century you’d think they could have reworded it to be less ambiguous. Hard surfaced? Does that mean paved? Or is it meant to exclude mud and sand? If they meant to exclude off road recovery, would it have been too much of an effort to say “these towing eyelets are not meant for off-road recovery?”
  7. Jun 5, 2023 at 4:43 PM
    LetsTacoboutit
    LetsTacoboutit New Member
    Adobe
    After all the research and some engineering assessments by an engineer here on the forum, my take away was that those aftermarket recovery brackets were in fact weaker than the original recovery points particularly in a side-pull type situation.
  8. Jun 5, 2023 at 4:49 PM
    Oakboro, N.C
    "Hard surfaced"
    I wonder how many people have encountered this exact situation and erred to the 51% side, and said Efff it.
    If you can document it in a manual, One would think it could be drilled down a little more technically in regards to ability.
    Just my .02 cents.
  9. Jun 5, 2023 at 6:39 PM
    Zal4R
    Zal4R New Member
    ‘21 LR TRD Pro
    Eibach TRD Pro Springs RCI Skids
    Saw a Tacoma winched out of a ditch. 2 winches pulling forward using the tie downs, one sideways on the frame. Came right out. Have been and have used kinetic rope with mine and others, no issues so far. I generally use a bridle and soft shackles to even out the load, but they seem fine….just my 2 cents though.
  10. Jun 8, 2023 at 2:46 PM
    Foothills
    Foothills New Member
  11. Jun 8, 2023 at 2:58 PM
    3JOH22A Toyota Gigolo
    The limitations stem from towing with the automatic transmission in neutral and the engine not running, and not from the mechanical strength of the hoops.
    JETSPD1477[QUOTED] likes this.
  12. Jun 8, 2023 at 3:21 PM
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    i can see that. that's pretty much par for the course for most cars and flat towing.
    i wonder how much hard tugging the hoops up front can take.
  13. Jun 8, 2023 at 3:22 PM
  14. Jun 8, 2023 at 3:30 PM
    I wouldn’t want to find out. I doubt they would outright break off. But they aren’t in line with the frame. I’d be worried that the radiator support crossmember would bend with a heavy pull. Especially when stuck, or with kinetic pulls.
  15. Jun 8, 2023 at 3:40 PM
    Tie the vehicle between two big trees and tighten the strap with a Porta-power :notsure:
    As for how to quantify recovery forces:
    Rule of thumb for pulling forces on level ground:
    1x vehicle weight when buried to the hub
    2x vehicle weight when buried to the top of the tire
    Additional derating factors apply on inclines or if there's a tire- or suspension failure.
  16. Jun 11, 2023 at 6:59 PM
    Startrek
    Startrek New Member
    FINALLY WE HAVE A SMART PERSON
    Branden967 likes this.
  17. Jun 11, 2023 at 7:43 PM
    like2lean likes this.
  18. Jun 12, 2023 at 12:39 PM
    My problem with all these options which add a rated eye right next to the factory tie-downs is that they put the recovery points in the wrong place. It’s almost worth getting a winch bumper, even without a winch, just to have proper recovery points in the proper place.
    Thatbassguy and djwantke like this.
  19. Jun 12, 2023 at 12:53 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Front hitch is a good recovery idea, but like buddy said, apparently what it mounts to on the Runner isn't ideal - may be less strong than factory eyelets.
    I recommend a combination.
    I bought 2x Apex Overland front recovery points, like new off local guy. Next is center winch bumper. I believe that combo will be sufficient for myself and stronger than our factory tie downs which I researched. God willing!
  20. Jun 12, 2023 at 1:03 PM
    Thatbassguy and JETSPD1477 like this.
  21. Jun 15, 2023 at 1:41 PM
    The Tacoma’s loops are a different animal. Not as robust as the 4Runner’s.
    I’m probably wrong, but doesn’t every low profile winch bumper bolt up there?
    I’ve been putting a lot of thought into this. I think the welded loops are stronger than all get out. They aren’t just welded to the front face of the cross member. They go all the way through the cross member and are welded all the way around on both the front and the and back. As for the crossmember being cantilevered a few inches below the rest of the frame - I can imagine a situation where that might happen, like snatching from hip-deep type 2 mud, but I gotta believe in that situation you’re approaching the failure point of a lot of links in that chain. I emboldened those two words as an acknowledgement that they don’t mean the same thing as “know”.
    ETA: I wonder what the purpose of these two members is. Could it be to prevent the potential bending of the crossmember mentioned above? I’m too lazy to take off the skid plate to get a good look at it.
  22. Jun 15, 2023 at 2:05 PM
    Hip-deep type 2 mud is bad news no matter what. I’d say aerial recover is your only hope in that situation. Then again, suction forces would probably overload the rotor-head assembly of the winching helicopter, and the whole mess would come down on top of you. :p;)
    Seriously though, hard kinetic pulls are where I would be concerned. The factory loops are welded in good, agree. But corrosion can be horrible in that area in particular.
    On a factory fresh truck it might be passable to put a little more than flat surface towing forces on it. In the end however, Toyota says they are suitable for towing on hard surfaces…so user beware.
    Actually, even with technically perfect recovery points, every recovery situation has the potential to impart forces that will break all sorts of things. Especially for amateurs that aren’t used to thinking of how forces can stack up and multiply.
  23. Jun 15, 2023 at 2:07 PM
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    My take is to reinforce the radiator support and at the same time reinforce the skid plate.
  24. Jun 15, 2023 at 2:15 PM
    Those brackets are an attachment point for the skidplate, but don’t think it’s to reinforce the skidplate. The skid plate already rests directly on the engine crossmember.
    The bend in those brackets make me think they are solely there to help absorb and control frontal impact forces in a collision. In other words, it looks like that radiator support member and the brackets serve as part of the crush zone. Another reason to want to avoid hard pulls in that area.
  25. Jun 15, 2023 at 2:39 PM
    I believe that's where mine bolted on. I've used it a bunch of times so far without issues. :notsure:
    djwantke likes this.
  26. Jun 15, 2023 at 3:17 PM
    My warn bumper bolted directly to the frame. They required removal of the crash bar, and the crush cans the crash bar is mounted to. I believe most aftermarket winch bumpers mount directly to the frame and don’t mount to the crush cans.
    I think @3JOH22A (below) was saying the front hitch receivers mount to the crush cans, not the frame directly. And then they are tied into the tow loops…maybe to make up for it? It’s hard to say if a front hitch mounted in this way is suitable for kinetic recovery, or towing/winching…probably worth checking directly with the manufacturer if I had a need to know.
    djwantke and Thatbassguy[QUOTED] like this.
  27. Jun 15, 2023 at 3:23 PM
    4Daughters
    4Daughters It’s how I know God has a sense of humor
    Ken
    Powder Springs, Ga
    2022 TRD ORP; Silver; too many port options...Ah well...
    TBD
  28. Jun 15, 2023 at 3:31 PM
    Oh, I misunderstood. I had to remove the crash bar as well.
  29. Jun 15, 2023 at 5:32 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    I chose the add=
    If I went that far, my next step would be mounting a snow plow.
    Regarding use of the front loops, what convinced me to go for the Apex Overland bolt-ons was photos of older frames that weren't badly rotted in general, but whose disease was worst at the corners by the loops. Hopefully I'll never have cause to understand the shortcomings of my chosen solution.
    Stoney Ranger and Thatbassguy like this.
  30. Jun 15, 2023 at 7:06 PM
    I’d never trust an aircraft that has to scratch and claw its way into the air.
